Question about Dryers
My buddy's coin-op dryer kicks out after 20 seconds and panel indicates door
  • Dryers Master
  • 16,037 Answers
Either the latch is worn out or the switch is loose. You have to disassemble to see if the switch is bad.
Posted on Nov 13, 2014
Dryer will not start. Power light is on. No coins are stuck in drum liner. No blockage. Recent repair replaced mother board at a cost of $500.00. The same repairman rep
Without a complete model number it's hard to say which direction to go. You might need a door switch, some door switches with an interior drum light will be a 3 wire switch allowing the interior light to come on but not the dryer start when the door is closed. Some dryers had a start relay mounted inside the control panel, which is controlled by the main board, failure of these relays can cause a no-op situation. Pleazer Appliance...
May 06, 2014 | Whirlpool Dryers
GE commercial coin op dryer only runs when start button is depressed. The second you let off the buton the dryer stops.
hows the timer unit on doing when you push on it the timer is suppose to start..
Apr 15, 2011 | GE Dryers
How can I adjust the run time per $1 on my maytag coin operated dryer. I would like it to run about 15 minutes per $1. Now is runs about 45 minutes on one $1.
Download this manual:
http://www.fowlercompanies.com/servicemanuals%5CMDG16SERVICE.PDF
The mechanism adjustments start on page 20. Note that the maximum number of slider cycles is 3. If you have a PD coin drop model the Max you can get is $0.75 per load I would have to assume that a different coin op mechanism may have to be used or one that will accept 2 coins per cycle for 2 cycles. On non PD models you can adjust the slots for as many as 4 coins per glide / slider cycle.
Thanks for choosing FixYa.
Kelly
Oct 20, 2010 | Dryers
I have an old speed Queen coin operated dryer and I would like to remove the coin function. Can this be doneMachine detail on request.
you can get it to run by installing coin plugs in the slide are assembly or leave the top lock panel open and push the spring arm before each load for personal use.
May 22, 2009 | Dryers
Coin-op dryer: changing the length of the cycle
that is correct, there a re multiple "cams"/discs that will increase/decrease times, they should be inside the lock box atop the machine, they come with the unit when delivered and that s the likely storage spot for them
Mar 25, 2009 | Whirlpool ET8CHEXSQ Dryer
I have a coin op dryer modle cem2760kq0 i put im a new timer in but it dose not stop runing?
mechanical coin op timers come without the shut off cam installed
there are slots around the edge corresponding to different times, that take a pin cam. the pin cam is in the box for the installer to insert to the owners specification, between 24 and 60 minutes in 6 minute intervals usually, hope you retained the packaging, or the old timer which should have its cam pin still in it
electronic coin op timers have to be programmed
Aug 28, 2008 | Whirlpool Dryers
Whirlpool coin operated washer and dryer
you need to take the coin slot out by using a socket wrench. then you need to flip the slot over and take the screws off. there is going to be two more screws to unscrew. take off that piece and also the claw like coin catcher. form here on out you should be able to remove as many slots as you need to.
Sep 06, 2007 | Washing Machines
Coin in dryer
The coin is probably rattling against the blower fan. First, unplug the dryer or turn off the main breaker. There are live voltages present inside a dryer even with the power shut off. Then, follow these steps: 1. Take out the lint screen. 2. Remove the lower kick panel under the door. There are a couple of screws under the front. The panel should pull straight down then come off. 3. Remove the blower fan housing. There will be 2 to 3 screws holding it in place. NOTE: If you did not take out your lint screen in STEP 1 you will know why I told you to take it out. The blower fan housing won't come off with the lint screen in place. Once you have the panel off you will be able to access the blower fan, and anything else that as gotten trapped inside the housing. This would be a good time to clean as well. Reassembly in the reverse order of what I just explained to you. Good luck and I hope this helps you.
Jul 31, 2007 | Whirlpool GEW9250P Electric Dryer
Dryers Logo
44 people viewed this question
Top Dryers Experts
