Question about Cycling
How do I find the age of my baikal hammer gun
    Master:
  • 706 Answers
Try local gun shop. These guns are Russian made, their website is Baikalcanada.com
Posted on Dec 04, 2014
I have a Baikal MP-514K air rifle, new just out of the box. Before I did any reading I cocked it, taking the barrel to 90 degree angle where is stuck, how do I get it back down.
Take it to a gun shop , you have over cocked it and now it needs stripping down , if it's a spring firing gun you need to undo the spring tensioner and with the pressure of the spring against you you might not hold it when unscrewing the tension bolt ps if the spring fires out you could loose your sight or injuring others around you shop please and good luck colin
Jun 14, 2017 | The Optics
Hubby has a Thompson center 45 cal Hawkins black powder gun and the hammer wont stay cocked, what should he do?
possibly carefully file where the hammer is held back to ensure that the edge is sharp to engage the lip of the lock edge
probably worn round from use and age
Dec 10, 2016 | The Optics
My newish SIP TN3/100D v twin compressor will not pump above 100psi !!??
100 psi is capable of running the gun
what the problem is the volume of air supplied to the gun
check the specification requiring the air usage for the gun against the volume supplied by the compressor
if you gun requires 20 c/ft of air /min and the compressor is only capable of 15c/ft of air /min, then the volume is too low so the pressure will not build up
modern impact 1/2 guns will operate quite well on 80 psi unless the gun is leaking internally
another point is this-- impact guns come in two configurations-- single hammer and double hammer
double hammer give 2 hits for each revolution of the air motor and there fore use less air to do the job
add the fact with 2 hammers , the torque applied is generally higher than single hammer units
the reality is this , the compressor capacity in c/ft/min should be 2 times that required or used by the tool
Sep 20, 2016 | Air Tools & Compressors
Im looking to buy a air hammer. what is the difference between Chicago Pneumatic model cp716 and cpt 716? sometimes the cp716 is refered as a zip gun. . is there a difference between a zip gun and a...
It looks like Amazon came up with a name "zip gun hammer" A zip gun is a low profile gun with bullets. The cp716 is a good model. Make sure to get the bits with it. These air hammers do not come with bits most times.
good luck
Joe
Feb 19, 2011 | Chicago Pneumatic Heavy Duty Zip Gun® Air...
My gun will not shoot staples after loaded I thin there is a part missing
Staple gun are simple device and the 'shooting' mechanism is just a sring loaded bar that hammers the staple out: the problem is usually a jam/stuck staple where the staple in the orifice where the staple comes out. Just use a small screwdriver and /or plier to remove the stuck staple which could be jammed against the hammer bar. You may need to force the hammer bar backwards with the help of your small flat head screwdriver.
Hope it helps!
May 02, 2010 | Stanley CT10C Heavy Duty Staple Gun/Cable...
My hammer drill got overheated
Hello. If the gun has cooled down and still will not start up then the gun will have to go into a Bosch service center for a repair. Here is the owner manual with the pertinent info
http://mdm.boschwebservices.com/MDMCache/English%20[US]/t10/0000000/r00018v-1.pdf
please rate my answer as very helpful. thanks.. Joe
Apr 26, 2010 | Bosch 1199VSR 8.5 Amp 1/2 Inch Hammer...
Matco Air Hammer works intermittently ??
Use some wd 40 to clean the gun.Put it in where the air goes in,a lot of it.Put a bunch of it in the gun.Then use some transmision fluid to finalize the cleaning.If this helps the gun,then oil the gun with air tool oil.If this dones not work,then a rebuild would be the next step.
Oct 15, 2009 | Ingersoll Rand Air Hammer - 2 9/32in....
Cannot load staples
At the back of the staple gun is a flat shaped metal piece. It's at the bottom. Push in, pull down, then pull the mechanism out. You'll see it's a metal rod with a spring, that is attached to that flat metal piece. The spring pushes against another flat metal piece, that has a hole in it, and travels back, and forth on the rod.
The flat metal piece that the spring pushes down the rod, pushes against the staples.
Remove this spring mechanism, slide the staples down the rails. The staples will be in the position of an upside down U. Replace the spring mechanism, and lock it back into place. (Push in, pull up)
Should, your question be in reference to the fact that you have staples loaded, but upon pressing the trigger nothing comes out:
In the front of the staple gun, is a flat metal piece that pushes down on the staples. One staple at a time. The flat metal piece is shoved down by spring pressure. The spring pressure is applied to the flat metal piece each time you squeeze the trigger. (Flat metal piece = Hammer)
Sometimes, Two staples try to come out. When they do, this flat metal hammer is stuck up in the gun. To free the flat metal hammer, remove the spring mechanism out of the back of the staple gun. (The spring mechanism discussed above) Remove any staples in the gun.
Try to use a flat blade screwdriver, and see if you can shove the flat metal hammer in the front of the gun -> UP.
(DO NOT have the staple gun pointing at your face! DO NOT squeeze the trigger! DO NOT use excessive force)
If this method is of no avail for you, you have to disassemble the gun, and remove the metal hammer, and stuck staple/s.
Jul 29, 2009 | Arrow T50P ARROW STAPLE GUN
Compare staple guns
A hammer tacker is a device somewhat similar to a staple gun, except that the mechanical energy from the user's muscles is stored — as in a hammer — as momentum of the gun itself, rather than as compression of an internal spring. This type of stapler is typically used for insulation, roofing and carpeting.
Aug 27, 2008 | Do it Best Imports/ Jaun Yei 326409 Cable...
Cycling Logo
49 people viewed this question
Top Cycling Experts
Michial Gueffroy
John Egan
John Egan
Are you a Cycling Expert? Answer questions, earn points and help others
