Question about Le Pan S 9.7 Inch Tablet With 4gb Memory - White
Manual for Le Pan S Tablet
It wont power up or indicate when charger is connected
  • Le Pan Master
  • 5,631 Answers
Not a normal behaviour. Take it back where you bought it and ask for users manual, explain them the problem. It should have some warranty.
here you have a manual
http://www.lepantab.com/Download/LePanII_UM.pdf
Posted on Dec 31, 2014
I have a Le Pan tablet and i lost my original charger, I bought one at Walmart and it won't charge my tablet
if it is not the same brand chrger that u had frst then it wont work, if u buy the same brand then it will work, sorry about that
Nov 27, 2017 | Tablets & eReaders
I do I change language to english?
Hi Jill, below is a user manuals for "le pan II 9.7" tablet pc"
language settings is on page 14......CHEERS..
Mar 25, 2016 | Le Pan II 9.7" Tablet PC
I have a Mach Speed JLAB tablet. It wont power on. Just showes battery with exclamation point in the middle. Why?
That symbol usually indicates the battery isn't charged or charging. It could be a connection problem, a charger problem, or a battery problem.
If you have an extra wall charger, try that first as they don't always last forever. Make sure the plug that connects to your tablet looks clean and not corroded.
If it still won't charge, then chances are the battery needs servicing to make sure the connection is OK or the battery just might need to be replaced.
May 11, 2015 | Tablets & eReaders
I turn my tablet on then it switches it self off
Sounds like it does not have enough battery power to stay on. If you have not tried to charge it, you should try that first. If you have, it sounds like it is not getting charged or not holding a charge. Could be bad AC power source, bad charger, bad charger connection or bad battery. Take steps to confirm that each of these are good. If all of these are good, sometimes the tablet can become so discharged that it will not allow itself to charge. When they are in that state, sometimes you can trick them into charging again by repeatedly disconnecting and reconnecting the charger as follows: With charger plugged in to AC power source, connect the charger to the tablet. Pay attention to the screen or LED or whatever indicator your tablet has to let you know it is charging. You may see it momentarily indicate charging, or maybe not at all. Then unplug the charger from the tablet then immediately plug it back in and pay attention for the charge indication again. You may have to do this a bunch of times (like 20) until you see the indication that it is charging. When you do get the indication, stop unplugging and re-plugging and let the tablet charge for 24 hours (to a full charge). This trick doesn't always work. Sometimes the battery or charging circuit or an internal connection is bad and no amount of unplugging/re-plugging will fix a hardware problem.
Nov 17, 2014 | Tablets & eReaders
RCA tablet wont charge
Possible charger damage.
If you know someone with a charger you could use, you should first plug their charger into your unit to see if it works, if not, plug your charger into their unit.
If your unit will not charge with new charger, you may have serious damage, if the other will not charge with your charger, your charger is broken.
Jan 13, 2014 | Tablets & eReaders
Le Pan TC 970 9 7 Inch Android Tablet not working
Try holding the power button AND pressing the reset button. Don't continuously press the reset, just click it once.
Jun 16, 2013 | iStyles Nesting Le Pan TC 970 9.7-inch...
Le pan tablet wont charge how to reset
so my tablet wont charge but it turns on but the battery stops then turns off.so what should i do about it.
Apr 28, 2012 | Tablets & eReaders
Le Pan S 9.7 Inch Tablet With 4gb Memory - White Logo
215 people viewed this question
Top Le Pan Computers & Internet Experts
David Payne
David Payne
Are you a Le Pan Computer and Internet Expert? Answer questions, earn points and help others
