Question about Bose Acoustimass 15 System
For the speaker outputs, is the pin or the sleeve the positive?
Or does it matter?
    Master:
  • 876 Answers
The pin is usually the positive on the RCA connectors
Posted on Nov 14, 2014
CB Plays out PA Speaker
Are you following the user manual that came with the radio?
NB-ANL/CB/PA SWITCH: When the switch is in the NB/ANL position, the Noise Blanker (NB) and Automatic Noise Limiter (ANL) circuits are activated.
The Noise Blanker is very effective in eliminating repetitive impulse noise such as ignition interference. In the CB position, the PA function is disabled and the radio will transmit and receive on the speaker that is connected. In the PA position,
the radio acts as public address amplifier. Your voice will come out of the speaker that is plugged into the PA. SP. jack on the rear panel. The radio does not operate when you are in the PA mode.
When you plug a speaker into the ext. jack does it kill the radios internal speaker? It should until you unplug it; if not and you are following the about you may have a wiring issue with the jacks.
May 04, 2014 | Radio Communications
How to change the battery in a jaguar XF smart key
1) Carefully remove the plastic silver sleeves on each side of the remote.
2) Carefully open the remote to expose the battery -- try to keep the circuit board and valet release pin from falling out.
3) Replace battery -- plus (+) side down
4) Before closing body of remote, take note of valet key release pin & spring. Be sure the spring and pin are in the correct position (see pic).
5) Carefully close body of remote.
6) Before attaching sleeves to remote body, be sure the notched end of the sleeve is aligned with the valet key.
7) Carefully slide silver sleeves onto each side
8) Test
Apr 24, 2014 | 2009 Jaguar XF
Hi....I need a wiring diagram for the stock amp in my grand am gt...its a 2003
Monsoon System Pinouts
Pin Wire Color Function
E1 LT GRN Right Front Speaker Output (+)
E2 TAN Left Front Speaker Output (+)
E3 GRY Left Front Speaker Output (-)
E4 LT BLU Right Rear Speaker Output (-)
E5 DK BLU Right Rear Speaker Output (+)
E6 BRN Left Rear Speaker Output (+)
E7 YEL Left Rear Speaker Output (-)
E8 BLK Ground
E9 BLK Ground
E10 DK GRN Antenna Relay Coil Supply Voltage
E11 ORN Battery Positive Voltage
E13 BLK Left Front Tweeter Speaker Output (+)
E14 YEL Left Front Tweeter Speaker Output (-)
E15 DK BLU Left Front Midrange Speaker Output (+)
E16 LT BLU Left Front Midrange Speaker Output (-)
F1 DK GRN Right Front Speaker Output (-)
F2 LT GRN Right Front Speaker Tweeter Output (+)
F3 PPL Right Front Speaker Tweeter Output (-)
F4 PPL Left Rear Tweeter Speaker Output (-)
F5 RED Left Rear Tweeter Speaker Output (+)
F6 DK GRN Right Front Midrange Speaker Output (-)
F7 ORN Right Front Midrange Speaker Output (+)
F8 PPL Gain Control Signal
F9 -- Not Used
F10 YEL Right Rear Tweeter Speaker Output (-)
F11 WHT Right Rear Tweeter Speaker Output (+)
F12 -- Not Used
F13 LT BLU/BLK Right Subwoofer Speaker Output (-)
F14 DK GRN Right Subwoofer Speaker Output (+)
F15 DK BLU/WHT Left Subwoofer Speaker Outlet (+)
F16 LT GRN/BLK Left Subwoofer Speaker Outlet (-)
or it is here 3rd one down
http://www.grandamgt.com/forum/forumdisplay.php?f=76
May 08, 2011 | Audio Players & Recorders
For the RCA DRC69707 monitor linking power cord, w...
My guess is you have already figured out the two cables attached to the 12v car plug each go to the DVD player and Monitor. The Monitor power input schematic shows the inside pin to be positive, leaving the sleeve to be negative. WebRepOverall ratingThis site has no rating(not enough votes)
May 21, 2010 | Car Audio & Video
The channels are reversed. The red lead is the left channel whereas it should be the right. The leads to the cartridge match their color codes with the marking on the cartridge. The wires in the headshell...
If it a PROPER head-shell the leads DO come off the pins at the rear of the cartridge.
Also if you are using EXTERNAL speaker it may be that the speaker leads are incorrectly wired to the speakers and that would simply be a matter of swapping the external speaker outputs over.
Apr 05, 2010 | Crosley CR74 Turntable
How do you remove the glass from the rear side window regulator
Remove the door panel
  1. Remove the side impact bolster.
  1. Detach the door speaker (if equipped).
  1. Disconnect the speaker electrical connector and remove the door speaker (if equipped).
  1. Detach the door latch release handle.
  1. ani_caut.gif CAUTION: Do not touch the adhesive surface as re-bonding will be impaired.
    Detach the watershield.
    • Using a suitable plastic knife (disposable cutlery), cut through the Butyl strip to enable the watershield to be peeled back.
  1. Remove the door glass top run retainer.
Vehicles with manual windows
  1. Install the window regulator handle.
Vehicles with power windows
  1. Connect the door glass operating switch electrical connector.
All Vehicles
  1. Align the regulator clamp with the access hole (power window shown).
  1. NOTE: Position the regulator operating cable to one side when drilling the retaining pin, in order to prevent damage.
    Detach the door glass from the regulator clamp.
    1. Using a suitable electric hand drill and a drill bit 8 mm, remove the retaining pin.
    1. Push out the retaining sleeve.
    1. Remove the door glass from the regulator clamp.
    • Discard the retaining sleeve.
  1. Support the glass, lower the glass and regulator to the lowest position.
  1. Position the lower part of the door glass top run outside the door.
  1. NOTE: To aid removal of the door glass, stand on the inner side of the door. Make sure the glass is removed from the inside of the door.
    Remove the window glass.
Installation
All vehicles
  1. ani_caut.gif CAUTION: Make sure vise jaw protectors are used.
    NOTE: Make sure that the retaining sleeve is central in the door glass.
    Attach a new retaining sleeve and retaining pin to the door glass.
    1. Position the retaining sleeve in the door glass.
    1. Using a suitable vise, press the retaining pin into the retaining sleeve.
  1. Install the window glass in the door.
  1. Attach the door glass to the regulator clamp.
    • Push the door glass firmly down to engage the retaining pin and retaining sleeve into the regulator clamp.
  1. Position the lower part of the door glass top run on the inside of the door.
  1. Close the window.
  1. Install the door glass top run retainer.
  1. Attach the watershield.
  1. Attach the door latch release handle.
  1. Connect the door speaker electrical connector (if equipped).
  1. Install the door speaker (if equipped).
  1. Install the side impact bolster.
  1. Remove the window regulator handle.
  1. Disconnect the door glass operating switch electrical connector.
All vehicles
  1. Install the door trim panel
Mar 11, 2009 | 2001 Ford Focus
How to install this amp properly?
The amp is a mono amp with only one output channel so it cannot be bridged. You'll use one positive and one negative per speaker. The positive speaker terminals are connected together and the negative speaker terminals are connected together so it doesn't matter which you use for the individual speakers.
Jan 09, 2008 | Kenwood KAC-9152D Car Audio Amplifier
No sound
You might have a loose wire in the mic plug, also in the plug itself there are 4 holes for 4 pins in the radio to fit into, these 4 holes have tiny metal sleeves in them to make contact with the radio pins. these sleeves are split and you can take a tiny jewlers screwdriver and slightly close up these sleeves this causes them to fit tighter on the radio pins creating a better connection. these sleeves WILL over time spread out causing the radio to lose a function such as receive or transmit I have encountered this problem several times in the past at my shop. Good luck on your problem.
Sep 07, 2006 | Maxon MCB-30 40-Channels Base CB Radio
Bose Acoustimass 15 System Logo
73 people viewed this question
Top Bose Audio Players & Recorders Experts
Electro Med Services...
Ben Armstrong
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
