Question about Pacific Laser Systems PLS5 Automatic Laser Plumb Level And Square
How can i get mannual for plp 180 leaser level make profil plp 180
Center bubbles will not level to center when it was turn to 180 degrees
Fix the instrument to a solid tripod. Level the vial. Turn the instrument 180 degrees. If it is out of level. Adjust half of the bubble's error with the foot screws, and the other half with the 3 adjustment screws around the vial itself. Continue to go back and forth 180 degrees until the two sides match.
It will take some time to get the hang of. But is not hard to accomplish.
Jan 02, 2014 | Topcon At-g2 Auto Level
I just put 3 new battery's in and leaser light will not come on.
Check for green corrosion on contacts and clean them A dab of WD40 on a Q tip will may help clean & improve the connection and provide extended protection.
Aug 25, 2013 | CST/Lasermark Self-Leveling Rotary Laser...
I have a nokia 5200 cell phone. I am trying to save gprs configaration setting but it's said =only 70 sets allowed. when i am trying to set up gprs setting mannually it is said memory full. but mobile is...
I have a nokia 5200 cell phone. I am trying to save gprs configaration setting but it's said =only 70 sets allowed. when i am trying to set up gprs setting mannually it is said memory full. but mobile is completely empty. i don't have any other old settings n profiles. please help me!
Nov 06, 2010 | Cell Phones
Cant change volume or ring tone have lost mannual
hi,
Please first go to settings
& then click on to profile settings
& then click on to to customize
& then then select ring volume from their
& adjust the ring volume & save it.
thanks
Aug 02, 2010 | Cell Phones
I need 1320 HP leaser printer Setup for instalitaion how I get it
Go to HP's web site, find the support pages and download what you need after entering your printers model number. Good luck
Jul 18, 2010 | HP LaserJet 1320 Printer
The Toshiba Satellite Laptop ater shutdown and
Get it with windows 7, Vista has too many problems
Mar 15, 2010 | Toshiba Satellite Pro L300 Notebook
On My CST berger 32X automatic level unable to hold vial bubble center as instrument is rotated 180 degrees - instructions say to use vial adjustment screws to correct this problem...this does not seem to...
take a topedo level and get the tripod base as level as possible. attach your level to the tripod. put all screws in the middle and level it. turn 180 degrees, level it. turn 180 and check. if withing the bubble, turn 90 degrees and level. turn 180 and so on and so forth. the adjustments should be slight from turn to turn. make sure the feet are secured firmly in the ground. If this does not level the automatic level, it needs sent in for calibration. I dont know the web address but I hope this helps
Dec 21, 2009 | RTO CST/Berger 55 - SLVP32N 32X SAL...
Please could someone help with error code E 100
First off , how in the world do you expect us to help you.
We need to know the Make and Model number first before assisting you.
Do you make sure that the Laser Unit went back into the Home Position ?????
Mar 05, 2009 | Canon Office Equipment & Supplies
Pacific Laser Systems PLS5 Automatic Laser Plumb Level And Square Logo
56 people viewed this question
Top Pacific Measuring Tools & Sensors Experts
Vuk B
Tom Chichester
Are you a Pacific Measuring Tool and Sensor Expert? Answer questions, earn points and help others
