Question about Advantech IPC-6806SB-15ZBE: Industrial Desktop/Wallmount Chassis 6-slot
How i correct problem in boot up
Im having problem during boot up after i change some bios settings
    Genius:
  • 2,460 Answers
The bios settings control where you boot from. That is hard disc , DVD , USB stick, reset the bios settings to original, then go to settings and follow instructions to set boot options , most computers have different settings
Posted on Nov 12, 2014
Testimonial: "Im sorry but my problem is i cant no longer go to bios setting as my pc is no longer boot up..monitor is black and flash"monitor in sleep mode".."
Where are the bios settings located?
Depending on what make & model of computer you have, right after the first beep during boot-up you will need to hit the "DEL" key or a function key. Watch the screen closely during boot-up and you should see a message that says "Hit DEL during startup to access BIOS." Dell computers usually use the "F2" key. You may have to tap it a few times to get into the BIOS. BE CAREFUL when you change settings in the BIOS. You can make the computer stop working if you change the wrong settings.
Aug 30, 2015 | Computers & Internet
Cd start server primergy b210 fujitsu siemens
In order to change the boot drive you have to change the boot settings in BIOS, or sometimes you can get a separate boot menu which allows you to change this setting on a one-off basis. During the boot sequence you need to press the "F12" button during the POST testing to bring up the boot menu if one is available, otherwise you need to press the "Del" or "F2" button during the POST process to bring up the Bios screens. Navigate to the BOOT option and alter the boot sequence, save the settings, exit BIOS and reboot.
Feb 18, 2014 | HP Compaq ProLiant ML110 G4 Server
How to save BIOS and change mother board CR2032 Lithium battery
if you only take 5 to 20 sec you might not lose any bios Cmos settings
im not sure what or why you want to save the settings for
once the Cmos battery has been removed for more than 30 - 60 sec your cmos settings will be restored which means no password and failsafe defaults
you could just restore failsafe or optimised defaults if you lose any Cmos settings
you will need to reset the password and the time and date
Restart your computer
During the boot process you will see on the screen to press a certain key to enter setup
Press and hold that key during the boot up process to enter BIOS using the arrow keys load failsafe defaults or load optimized defaults press escape then press f10 to save to cmos to restart
hope this helps you
Oct 16, 2011 | Computers & Internet
Please help me recovering password for WD 500GB HDD
recover your hdd using recovery software (e.g. Hiren's boot CD)
Aug 16, 2011 | Computers & Internet
Codes on how to change a password using php..
im not sure what you mean by php ??
When you boot up to the log in screen type in administrator as user to log in if you cant log in
during the boot up process you will see on the screen for a short amount of time press a certain key to enter set up press and hold that key during the boot up process to enter BIOS scroll down to set user password or supervisor password you can change or remove your password from there hope this helps
also
The most common way we know on how to reset or clear the BIOS password is to physically remove the power from the computer by disconnecting the power plug and then removing Cmos battery for 30 minutes from the motherboard. Another way is to reset the clear CMOS jumper on the motherboard itself. Both of the 2 methods mentioned works because most motherboards use a battery to sustain the BIOS/CMOS settings for the motherboards PROM chip. So by cutting off cmos the battery power, the BIOS/CMOS settings will be erased. Hope this helps
Jul 03, 2011 | Computers & Internet
Desktop Acer M1641: 1 IDE optical drive+ 1 SATA HDD. When SATA disabled,both drives appear in Bios n boot sequence. When SATA enbled, only optical drive in Bios. When both are present (as said before)...
Press and hold that key during the boot up process to enter BIOS the scroll down to advanced bios features press enter change your first boot device to IDE-1 means Pri slave escape then press f10 to save to cmos to restart
you will have to have master with slave set up
you can find the jumper location next to the power on a hard drive and the settings for plastic jumper location is usually printed on the top of a hard drive
IDE-0 means Pri master ?
IDE-1 means Pri slave ?
IDE-2 means Sec master ?
IDE-3 means Sec slave ?
Hope this helps
May 18, 2011 | Computers & Internet
I got a computer off ebay with a 741GX-M motherboard and the operating system is really old in linspire 5.0 and cannot get updates so im trying to boot a Ubuntu linux live CD. I change the BIOS settings to...
Press and hold that key during the boot up process to enter BIOS the scroll down to advanced bios features press enter change your first boot device to cd and the second and third boot device to cd press escape then press f10 to save to cmos to restart
(note after you have loaded the operating system you must go back and change the first boot device to your hard drive)
The BIOS is AMI. Under ADVANCED SETUP:
The options listed for 1st,2nd ,3rd Boot device include:
hope this helps
May 04, 2011 | EliteGroup 741GX-M Motherboard
. The drive is the Maxtor
Press and hold that key during the boot up process to enter BIOS the scroll down to advanced bios features press enter change your first boot device to cd,press escape then press f10 to save to cmos to restart
Master/Slave designation is determined by jumpers on IDE drives. Most drives have adequate markings on them to identify these jumper positions. If not marked clearly, you will need the manufacturer's data to determine that designation.
If you are curious about a working system just power-up in set-up mode (usually by depressing (f1-or-f2) during boot-up sequence, your system-bios will display this information for you.
Apr 25, 2011 | Quantum Fireball Plus AS (QMP20000AS-A)...
Actual problem is that i forgot my windows xp login password. how can i solve my problem? and another problem is that when ever i inserted any bootable cd in cd-rom it displayed compaq logo only. how...
During the boot up process you will see on the screen press delete to enter set up
Press delete during the boot up process to enter BIOS scroll down to set user password or administrator password you can change or remove your password from there
During the boot process you will see on the screen to press delete to enter setup
Press and hold delete during the boot up process to enter BIOS the scroll down to advanced bios features press enter change your first boot device to cd,press escape then press f10 to save to cmos to restart
hope this helps
Oct 26, 2010 | Compaq Presario 2100 and 2500 ,NX 9000...
The screen won't turn on during boot-up
i had this problem on a certain brand of laptop,i finally refered to the owners manual to find FN-F5 toggled from the screen to external monitor depending on 1 click or 2 etc and that Fn-F1 put the screen into sleep mode the same way---im not suggesting your machine uses the same sequence keys but it might be worth a try finding out if you have accidently toggled your keys.
you could also be missing your OS or your bios boot sequence is incorrectly set--Press F2 whilst booting to get into boot sequence option of bios)-there navigate with tab or arrow keys--save and exit or reset settings to default and exit--dont change any thing in bios settings until you are familiar with how to navigate and select changes OK!
Oct 02, 2010 | HP Compaq Presario CQ50-110US Laptop
Advantech IPC-6806SB-15ZBE: Industrial Desktop/Wallmount Chassis 6-slot Logo
74 people viewed this question
Top Advantech Computers & Internet Experts
David Payne
David Payne
Are you an Advantech Computer and Internet Expert? Answer questions, earn points and help others
