Question about Dryers
My dryer keeps catching drawstring. I do not see how to stop this
    Genius:
  • Dryers Master
  • 2,553 Answers
Just tie them up before putting them in.
Posted on Nov 12, 2014
  • Bethany Johnson
    Bethany Johnson Nov 12, 2014
    I have tried, several different ways of tying the string.
My Hunter Ceiling fan will not turn off!!!
Either drawstring switch is bad or wall switch.
Sep 10, 2017 | Hunter Dryers
M'y kenmore dryer start for 15 seconde and stop for 60 seconde and start again and stop again.what si th? probl?me?
Most likely, the thermostat is bad and the heater is getting too hot. It shuts off to keep from catching fire, then cools down and works again.
Feb 19, 2017 | Kenmore Dryers
They Samsung dryer is letting a lot of lint outside that is not being caught by the lint trap.
yeah, no dryer is gonna catch it all, but if you want to keep from making that mess outside, fasten some old hosiery to the outlet of vent to catch that escaping lint
Mar 09, 2013 | Dryers
My Frigidaire front load dryer is ruining my clothes. I can only guess loose straps, strings... get caught on lint trap on door and with the continually spinning o the drum, they eventually break. I...
If you take front of dryer off, there is a half moon shaped piece of felt on top of door opening that most likely has worn and leaves a gap between drum and where that felt is. Replace that for right drum fit.
Sep 11, 2017 | Dryers
My amana DLG330RAW dryer won't stay on. it has a combo timer and start dial turn the dial to the timed settinG and push...dryer starts part way through the cycle, the dryer...
Hello PB,
What i would most suspect as being the problem of why the dryer just stops randomly before the cycle is done,is a problem with the door switch or the door catch...does the dryer restart as soon as you restart it?? if yes i would check that the door catch was broken so the door will pop open stopping the dryer. Also check the door switch using a meter set to measure ohms and see if the contact is burnt ( a good door switch will be zero ohms resistiance)
GENE
Sep 17, 2011 | Amana DLG330RAW Gas Dryer
When i open the game i have massge error during Bable initialistion
Instructions
Things You'll Need:
* Electrical tape
* Wooden dowel
* String
1. Place a strip of electrical tape over the latch of the dryer. If your dryer loads from the front, simply locate the latch and place a strip of electrical tape over it. This will stop the door from "catching."
2. Put a wooden dowel on the base of your top loading dryer and prop open the top, the same way you open the hood of your car. This will keep the dryer door open quite easily.
3. Tie a piece of string to the knob on the dryer door. Then tie the other end of the string to something else sturdy in your laundry room. Make sure the string is taut. This will also keep your dryer door open.
Feb 22, 2011 | Dryers
Start but will not stay running
Some dryers have a broken belt micro switch mounted where a lever will stop the motor from getting into the run mode. They do this to keep the heater from catching fire. If your dryer is a DOT dryer (dryer of tomorrow) made by maytag for kenmore then it certainly has such a switch. If your dryer is a plain jane whirlpool manufactured one then you needs a motor replacement most likely friend. Sowwy.
Jan 29, 2009 | Kenmore 63942 Dryer
Clothes and sheets come out wrinkled and twisted
Try not to wash large items with small items the large items like sheet will twist around the small item. causeing twisting and wrinkling. Also If you are overloading the clothes or underloading the clothes they will come out wrinkled. I would try to do some testing wash a load of only towels then wash a load of only t-shirts and other light weight items that you may have. Then do just a load of your jeans. What happens? Please let me know
Jan 10, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Dryers Logo
50 people viewed this question
Top Dryers Experts
