Question about Toshiba 42TL515U 42" 3D 1080p LED-LCD TV - 16:9 - HDTV 1080p - 240 Hz Refurbished 42TL515
Porque TV Toshiba 42TL515U no se ve nada?
La tv se conecta al enchufe y no se ve nada de leds que indique que esta en standby, pero tampoco enciende, ni con el control remoto.
    Top Expert:
  • Toshiba Master
  • 74,383 Answers
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Posted on Nov 13, 2014
2 Suggested Answers
gopakumarg43
  • 74383 Answers
SOURCE: Control remoto de Toshiba Regza.
For more details, just type in the site name "Electro-help" to your search engines' search box [not in the address bar of your browser], and click search. It is an electronic equipments service help site.
All details you want are there. Note the position of hyphen in between words in site name, when you type it in. The site will appear as it is in web; subtitled as Service help to electronic home entertainment equipments.
Pull up older posts. You can get all details.
You can locate it either at the bottom part of first search page, or at the top of second page. Detailed descriptions are there to help you.
Sometimes, clicking on advertisements by the side and bottom of each post might help you to get details about the availability of spare parts; price etc:-
Posted on Jun 05, 2012
Plasma Panasonic TH-42PD60X No enciende
BUSCO UNA PANTALLA PARA Panasonic_TH_42PD60X YA QUE LA MIA ESTA ROTA , TODO LO DEMAS FUNCIONA , INCLUSO PRENDE Y SE ESCUCHAN LOS CANALES , O LO VENDERIA ASI PARA REPUESTOS JAIME 320 725 0204 MEDELLIN COLOMBIA.
Jan 21, 2012 | Panasonic Televison & Video
Como Reparo un Plasma Panasonic Viera TH-42PD60X no enciende ni el led de Standby
AMIGO YO TE VENDO LA TARJETA DE PODER PARA QUE NO SUFRAS MAS CON ESE APARATO , O TE COMPRO LA PANTALLA PARA EL MIO QUE ESTA QUEBRADA ,
Compro pantalla para PLASMA PANASONIC TH-42PD60X la mia esta rota, o vendo mi plasma para repuestos , tambien vendo una base para este plasma ya que tengo 2 unidades . gracias interesados escribirme a jaimolb@hotmail.com informes tel 0057 3207250204 colombia
Jan 21, 2012 | Cars & Trucks
Bunas dias , mi problema es que la tv insignia no enciende a pesar de que la fuente genera todos los voltajes, al dar power el led cambia de rojo a azul pero no hace nada, como dije todos los voltajes...
Que tal yo tambien tengo el mismo problema con mi tv insignia de 32¨ , mi problema es que la tv insignia no enciende a pesar de que la fuente genera todos los voltajes, al dar power el led cambia de rojo a azul pero no hace nada, como dije todos los voltajes estan presentes a la salida de la fuente, cambie todos los filtros de la fuente pero nada, gracias por su ayuda.
mi corre es carlitoswwway@hotmail.com
Nov 30, 2010 | Insignia IS-LCDTV32 32 in. Television
Tengo un plasma sanyo 50 pulgadas modelo dp50747m lo que tiene es que: no prende y le cambie los fusibles que estban quemados pero ahora se oye que prende pero no se ve nada solamente se enciende el...
Amigo yo tengo el mismo problema con el mismo plasma..y no encuentro solucion...Tu ya pudiste arreglarala?? Ojala pudieras decirme como lo resolviste o cualquier info al respecto...gracias.
Sep 05, 2010 | Sanyo DP50747 50 in. Plasma TV
LA PANTALLA SE PONE COMPLETAMENTE NEGRA CUANDO ENCIENDO EL AIRE ACONDICIONADO Y SOLO SE ESCUCHA
Dependendiendo donde vivas, y si esto solo ocurre cuando enciendes el aire, es simple que la misma linea que alimenta el aparato de aire acondicioneado, es la misma que esta supliendo energia al TV. El area donde vives debe tener problemas con caidas severas de voltage. Los equipos cuyo consumo de potencia es menor que la inmensa demanda de potencia que requiere un acondicionador de aire, tienden a llevar la peor parte del sunministro electrico. Te recomiendo que busques otro toma corriente para suplir el TV, y para estar seguro de que lo estas colocando en una linea que no esta con el aire, sin encende el aparato de aire acondicionado enciende el TV y ve te a la caseta de breakers, ve bajando (off) uno por uno hasta que veas que el TV se apaga, ponle una matrca a ese breaker ya que es el mismo que suple el aire. Luego conecta el TV a otro tomacorriente y repite el proceso (asegurate tambien de que la nevera esta apagada) si ves que en un breaker diferente al que marcaste hace apagar la tele, entonces dejala en ese toma corriente y con todos los breakers arriba (on) enciende el aire acondicionado) si no sufre la tele, ya resolviste el inconveniente, pero si se vuelve a poner negra, busca un multimetro o tester y asi con el aire funcionando, pon el multimetro en la funcion de voltage AC (voltage alterno) Y mete cada uno de los terminales o puntas del multimetro en un tomacorriente (no hay peligro alguno, el multimetro solo mide) deben haber 120 voltios aproximados con un descenso s ascenso de un 10%, es decir entre 108 a 132 voltios. si baja mucho menos el valor de lo que especifique, entonces tienes un serio problema con la energia que te suministran a tu casa. Si eso ocurre, me escribes y te doy una pequeña solucion a eso...
Dec 29, 2009 | Televison & Video
MI PROYECTOR EMPIEZA A ENCENDER Y SE APAGA.
buenas noches. tengo un problema con mi proyector.. hace unos minutos encendio y se veia la imagen pero luego lo desconectaron y cuando volvi a encender solo prende la luz de power pero no sale la imagen quen podra ser???
Aug 29, 2009 | Dell 2200MP Multimedia Projector
ACER ASPIRE 5100
que era lo que estabas haciendo cuando paro de trabajar? yo tengo el mismo problema con la mia, y creo que halgo esta malo con el BIOS.
Jun 15, 2008 | Acer Aspire 5100 Notebook
No se ve el video en mi TV
yo tambien quisiera los codigos me harian un mega favor, les dejo mi correo manuelgutierreznevarez@hotmail.com de ante mano gracias
Nov 24, 2006 | Yahoo YHT-650 System
TV Konka modelo K2038U. No enciende.
Muchas televisiones tienen reguladores ,si ese regulador no esta dando lo que tiene que dar hay que cambiarlo,tambien puede haber un corto en la linea y eso esta manteniendo bajo el voltaje,hay que chequiar los filtros(capacitadores).Suerte
Sep 06, 2006 | Konka K1369U 13" TV
Toshiba 42TL515U 42" 3D 1080p LED-LCD TV - 16:9 - HDTV 1080p - 240 Hz Refurbished 42TL515 Logo
275 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
