I'm having many dots on the top left corner on my display from the projector
  • Joseph Setaro Nov 19, 2014
    It may be the DMD chip. Have you noticed that the spots are multiplying? Also, do you get the spots when you unplug any source from the projector? If you have the spots and there is no source, then it is the DMD chip. They can be replaced for around $100-$400 depending on the projector.
    Genius:
  • Office Equip... Master
  • 2,432 Answers
Check the film you are using ,you will find small dots scratched on several frames, they are used as markers to change from one projector to another. they can be covered over with a filler. If the dots are there all the time you may have something on the lens.
Posted on Nov 12, 2014
4 Suggested Answers
projdoc
  • 2236 Answers
SOURCE: DS125 LG projector - only displays top left hand
if resetting the settings to factory default doesn't work, it might be the light tunnel. it would need to be replaced.
Posted on Dec 28, 2009
SOURCE: a violet like color appears
MAKE SURE THERE IS NOTHING MAGNETIC AROUND THE PROJECTOR - MAGNETS CAUSE DISTORTION IN PROJECTORS
Posted on Feb 25, 2010
  • 6 Answers
SOURCE: Panasonic video projector, via Composite video in.
You may need to adjust your overscan.
To do this you will need to press "MENU", choose "POSITION", now adjust the "V-POSITION" and move it only until the white line disappears.
The line that you see at the top sounds like SMPTE code, which is used by broadcasters for many purposes. http://en.wikipedia.org/wiki/SMPTE_time_code
Posted on Feb 28, 2011
Image is bright but there is a slight issue - on the left hand side a purple line displays vertically. Anybody knows why is this fault appeared and how could it be solved.
There is three LCD in the projector red, green and blue. If green LCD make any fault mean line or dot or dots then screen show these line or dot in purple color:
If line is very straight and sharp edges then green LCD is faulty and need to be replaced.
If line is not straight and faded edges then some thing in LCD block so your projector need service
Feb 22, 2011 | Sony VPL PX40 Multimedia Projector
Polarview 211e
Go to:
System Preferences (you can get there by clicking on the Apple Menu in the top left corner) -> Displays -> Detect displays
After you click "Detect Displays" your G3 should automatically send the display image to your projector.
Feb 27, 2008 | Polaroid Polaview 211E Multimedia...
When I turn on my nuvi 200 it says press dot. When I press the dot it just moves around the screen to different location.
To calibrate the touchscreen on your nuvi 200 series follow the steps below:
  1. Have the unit turned OFF and unplugged from power.
  2. Slide the power switch to the ON position and hold for about 45 seconds.
  3. A message will display on the screen: Press Dot.
  4. Once this message displays, release the Power button.
  5. Press in the center of the Dot.
  6. Keep pressing in the center of the Dot as it moves around the screen.
  7. Once this is complete, there will be a message: Calibration Complete.
  8. Touch Ok and the unit will restart.
The touchscreen will now be recalibrated.
*Note if unit is running software version 6.00 or newer you will want to follow steps from below.
To calibrate the touchscreen on your nuvi 205 series follow the steps below:
  2. Place your finger in the top left hand corner of the touch screen and apply pressure.
  3. Slide the power switch to the ON position. Once unit powers on release the power button.
  4. Hold pressure in left corner until the Press dot message appears.
  5. Once this message displays, remove your finger from the screen.
  6. Press in the center of the Dot.
  7. Keep pressing in the center of the Dot as it moves around the screen.
  8. Once this is complete, there will be a message: Calibration Complete.
  9. Touch Ok and the unit will restart.
//changed this line from 'solution1description.innerHTML' to use getElementById //to prevent FF warnings. They both appeared to work, but this is cleaner. solution = document.getElementById('solution1description').innerHTML; Last modified on: 09/30/2010
Oct 23, 2010 | Garmin nuvi 205 GPS Receiver
Friend has a problem with his Garmin nuvi: when typing the letter to the left appears. what can be done?
It needs to be calibrated
To calibrate the touchscreen on your nuvi 200W follow the steps below:
Aug 14, 2010 | Garmin nuvi 200W GPS Receiver
Garmin nuvi 205, sometimes it won't respond to my touch. Sometimes when I go to give it a name or address it just keeps repeating a letter, "aaaa, or jjjj. then when I touch the botton to go back or clear...
Your touch display is shorting out....BAD
Replace Unit
BUT try this first:
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} To recalibrate the touchscreen on your nuvi 200 series follow the steps below:
To recalibrate the touchscreen on your nuvi 205 series follow the steps below:
Does this help? Let me know. Thank you...
Nov 03, 2009 | Garmin nuvi 205 GPS Receiver
Black dot on top left corner and center of photos
This is dust on the sensor. Google the words...cleaning a digital camera sensor. You'll find instructions and sources for supplies.
Oct 02, 2009 | Nikon D80 Digital Camera with 18-135mm...
TI 84 plus calculator, flashing dot in upper left hand corner
When you turn the calculator on, its screen is cleared, save for a small square on the top left corner. This is the cursor and it is blinking: The calculator is waiting for you to order it to perform some calculation.
Try this simple operation
[1] [+] [1] [ENTER]. The calculator will display the result one line down justified to the right.
Hope it helps.
Aug 26, 2009 | Texas Instruments TI-84 Plus Calculator
The screen on my Garmin Nuvi 200W won't respond. I tried the recalibration but the screen doesn't respond when I touch the dot. I also tried a hard reset and that didn't help either. Help please!
There is more than one calibration procedure, but for the 200 it is:
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} To recalibrate the touchscreen on your nuvi 200 follow the steps below:
If this doesn't work you have two choices
Buy a new one
Or
Send your in for repair. Go here for this option
http://www8.garmin.com/support/outofwarranty.html
Aug 23, 2009 | Garmin nuvi 200W GPS Receiver
DS125 LG projector - only displays top left hand corner of my screen on the wall.
May 18, 2009 | Office Equipment & Supplies
I'm getting inaccurate letter entry on the letters I type. For example, when I type a B an M appears - I'm noticing it on the bottom row of letters at this time. Solution?
Are you sure you pressed the correct location on your screen???
If so, you may need to calibrate the screen.
Do this:
Dec 26, 2008 | Garmin nuvi 260W GPS Receiver
111 people viewed this question
k24674
