My menu button ir channel button doeant work?
  • 3 Answers
Your remote needs to be taken apart and cleaned. There is a circuit board on the inside that needs to be cleaned. There may be screws holding the remote together or it may have snaps. Hope this helps.
Posted on Nov 26, 2014
Toshiba tv 40rv525u has started to change channels
My TV 40RV525U changing channels, menus itself for few months ( I use antenna).
my son tried to stop the channel scrolling by enter weird number into the channel to stop it scrolling such as 555, 777..
later, it turn on off by itself and unable to hold on a channel
I call Toshiba customer service and they ask money $25 for troubleshooting but I denied since I do not want to waste money and time.
Now, I found how to fix it myself.
In my case, something was wrong with the signal comes from the button control on the left side of the TV.
What I did
unplug the power cord.
Remove back cover.
Look into the motherboard ( biggest green at the center).
First, I disconnect a connector on the motherboard come from the IR board that receive the wireless signal control ( meaning the remote is disable).
I turn on the TV, press on Menu button on the TV side. Menu is still scrolling.
I turn off TV, disconnect power cord and connect the IR connector back to the motherboard.
I then disconnect the nearby connector that comes from the side control buttons.
Turn on the TV by remote, press menu button on the remote to check. The menu stays.
DONE.
I use electric tape to seal off the connector and let it hanging there.
Close the TV back panel
I have been watching TV for 3 nights without menus/channels scrolling.
NO AVAILABLE red message when watching DVD is no longer existed.
Hope this help someone else.
Jan 20, 2012 | Toshiba 40RV525U 40 in. LCD TV
Turn off fpa lock without remote
Install an IR Remote App in android phone. The app link below worked for me to remove the fpa lock on. Configure the App for your RCA TV. Set TV as Device type, RCA as the brand. and choose the model (e.g., TV 20 F420T) also, select the Alternate IR Driver.
All the options of the command may appear in a list form. Close that and an actual remote with buttons should appear.
Then Power your tv will turn ON. Press the Menu. Pressing the Channel Down/Up Button to navigate to Preferences. Press OK button on the screen.. Then Navigate to FPA Lock. Press OK again. THis will turn the FPA Lock to Off.
Then you could use your on-TV buttons ZappIR Universal IR Remote Android Apps on Google Play
Nov 23, 2011 | RCA TruFlat 27F520T 27" TV
Can't change the channels
Whenever a remote is not working to change channels thefirst thing to check is the batteries. Even if some buttons on the remote areworking, it is possible that low batteries are the cause of not being able tochange the channel. Once the remote has fresh batteries, you'll want to makesure that the remote is in the correct mode. This can be done simply bypressing the 'SAT' button and it should light up. The next thing to do isre-address the remote to the receiver. First, press the 'system info' button onthe receiver (or access system info through the menu). Once the system infoscreen is showing on the TV press the 'SAT' button once and release then pressthe record button. The remote should then be working with the receiver.
Kaia S
DISH Network
May 20, 2010 | DISH Network IR Remote Control
Toshiba 40rv525r screen says NOT AVAILABLE
I've had the same issue! This is caused by the control panel telling the TV what to do - does it change channels on its own, too, or turn off or on on its own?
What you need to do (if you've not already done it) is lock the control panel out, which you can do under the LOCK menu.
What may help is running the factory reset on page 54.
Mar 22, 2010 | Toshiba 40RV525U 40 in. LCD TV
Can you buy a universal remote for TV 2 to change the channels? My remote for SAT DISH stopped working the lights on the top come on but I can not change the channel, view the guide etc...
The remote is an Ultra High Frequency remote and most universals are IR MAKING THEM INCOMPATIBLE.
Take the TV2 remote into the TV1 location and using the TV1 remote press MENU-MENU. You will now have a screen up that has remote addresses at the bottom. Take the TV2 REMOTE AND PRESS AND HOLD the SAT button on the upper left of the remote until all lights on top illuminate and release. Now key in a two digit number between 1-16 that is not either number on the screen currently and press the pound sign. The SAT button will flash three times now press the record button until the remote addy for tv2 changes to the new number.
You can cancel out of all of these screens with the TV1 remote. Now go to TV2 see if it works. If not try at the receiver. If it works there have Dish send you a new remote.
Thanks for using Fix Ya.
Feb 01, 2010 | DISH Network IR Remote Control
Harmony One remote won't input channels very well
Most DirecTV receivers are able to be controlled with IR (infrared) or RF (Radio Frequency) signals. DirecTV receivers are usually set to be controlled by RF.
To control a DirecTV PVR / Satellite, it needs to be set to respond to an IR Remote:
1. On the original DirecTV remote press the Menu button
2. From the Menu press Select on Settings
3. Select Remote from the left menu
4. Press Select on the IR/RF Setup button
5. Use the Up or Down arrows to change from RF to IR
6. Press Select to save
Note: Some models of DirecTV may have different steps to enable IR. You may need to refer to your user manual
Harmony Remotes only control IR signals. so this is not the issue. The Harmony Remote should control the tv. the original remotr needs to be tested for IR or RF.
The device we are working on that is not being controlled by the Harmony Remote could be operating on RF (Radio Frequency) signals. Harmony Remote can only control the devices that operate on IR (Infrared) signals. Most devices that work on RF signals can be changed to operate on IR signals, and this usually could be done by changing the remote control command mode to IR from RF.
Please follow the steps listed below to test to see if the device is being operated on RF or IR signal:
1- We need to use the original remote for that device to complete this task
2- Using your hand or a thick and wide object (wall, pillow, book...), cover the top part of the original remote. In other words block the direct positioning between the original remote and the device.
3- After you cover the top part of the original remote (or used an alternate way to block the direct communication of the original remote and the device), try pressing the buttons on the original remote to see if it can still send commands that can be received by the original remote. You can try powering on/off your device using the original remote when the original remote is being blocked by your hand or another object.
4- If you still can control the device using the original remote without a point of sight, your device is being operated on RF signals. If you cannot control the device without a point of sight, then it is IR operated.
5- If the device is RF operated, please change the command receiving mode to IR rather than RF and test the Harmony Remote.
6- If the device is IR operated, please contact us again by replying to this email and let us know if none of the commands or some certain commands are not working for that device.
You can usually find the information on how to switch the device to be operated on IR signals rather than RF signals, through the user manual for your device, or by contacting technical support of the manufacturer for that device, or even sometimes reaching the information simply by doing a basic research over the internet.
Mar 31, 2009 | Logitech Harmony One LCD Touchscreen...
Cannot control Vip222 with sling classic
I have read elsewhere that Slingboxes required the Dish Network receivers to be set to Primary Remote Address 1.
To try a fix:
Using the Dish Network Remote Control -
1. Press menu 2 times to get to system info page
2. In the system info page the Primary Remote Address is in a white box (bubble) followed by a Green TV (1)symbol that says IR and indicates the channel to which remote control 1 is configured.
If the Primary Remote Address of your Dish VIP722 Remote control 1 is not set to channel 1, here is how to change it:
1. While displaying the system info page, press and hold the SAT button on your dish network remote until all other modes are flashing, about 3 seconds.
2. then press the '1' button on the numeric pad of your dish remote
3. then press the '#' button on the numeric pad of the dish remote
4. then press the 'record' button (red dot button - stores setting)
5. At this point you should see a number 1 in front of the primary remote address on the dish system info page
Ensure you enter the corresponding IR code into your slingbox remote control per the instructions in the Slingbox documentation.
Feb 05, 2009 | Sling Media Slingbox AV Remote Control
TV cable tivo series2
you have to program the ir blaster on the tivo to new tv/! it should say how to do this in manuel
Nov 22, 2008 | JVC Televison & Video
IR Sensor Does Not Seem to Function
Hi
Try to go into the menu of the tv and reset all the settings to factory. This may work.
If this does not work then there may be a problem with the IR module itself.
/SPH
May 19, 2008 | Philips 27PT81S 27" TV
Hp media center pc 2002 remote stopped working. The ir lights up when any key is pressed on the remote, but computer won't respond to it. tried to roll back one day but didn't fix it. Tried to roll back...
If the menu button is on the remote and the unit is not responding to remote.....
try changing batteries and clean the remote and receiver lens.
Mar 16, 2008 | Computers & Internet
Televison & Video Logo
26 people viewed this question
Top Televison & Video Experts
Electro Med Services...
