Question about Whirlpool GI7FVCXWB (27 cu ft) Bottom Freezer French Door Refrigerator
Water under front of refrigerator
How can this problem be fixed?
    New Friend:
  • 49 Answers
Dose water gather inside the fridge, if so, it may be the drain in the inside back of the fridge is blocked, try cleaning it through with a long pipe cleaner,
or if it has a water dispenser on the front, try removing the plastic plinth at the bottom of the unit and checking the water connection,
Good luck
Posted on Nov 12, 2014
How to fix water leaking under front of refrigerator
dose water gather inside the fridge, if so, it may be the drain in the inside back of the fridge is blocked, try cleaning it through with a long pipe cleaner,
Good luck
Nov 12, 2014 | Whirlpool Refrigerators
I HAVE A MAYTAG AUTOMATIC ELECTRONIC DEFROST CONTROL REFRGATOR MODEL MSD2272VEB00. EVERY FEW DAYS WATER LEAKED FROM UNDER THE REFRIGERATOR ONTO THE FLOOR FROM WHAT APPEARS TO BE AT THE FRONT RIGHT SIDE OF...
Inside of the unit is a drain hole that will drain out water to the drip pan. The drip pan is located under the unit and it uses the heat of the motor to evaporate the moisture that collects in it. The drain hole is plugged. Go on youtube and you can watch a video on how to fix it. Very easy.
Semper Fi,
Z
Apr 27, 2017 | Refrigerators
Have side by side 10 years leaking water on floor in front of refrigerator there is no water connected to refrigerator, cant find an overflow pan under neath...
clogged drain causing the water that cant reach the drain pan underneath to leak on the floor. Unplug fridge and open doors for 24 to melt ice likely clogging up drain. If that doesnt fix, you'll need to call refrigerator repair service
Jul 26, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
Kenmore Elite Refrigerator water dispenser mechanism will not turn off. I turned off the water from the valve under my sink that is connected to the water line, however, I can hear the dispenser still...
most panels have 2 screws under the edge . remoce them and the panel will come off . there must be a bad sw or something caught in sw .. sw do go bad .. mm hope this helped feed back pls .
Feb 04, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
Side by side refrigerator leaks water from left front
your defrost drain is clogged,
on the freezer, side take off the back wall
look at the bottom under the coil
you should see hole,,,, defrsot drain
whats happening with that clogged all the water from defrost runs right out the door
Oct 04, 2009 | Refrigerators
Mine collects water under the crispers also.
Self-defrosting refrigerators dispose of the water generated during the defrost cycle, usually via a tube or channel that directs the water to a pan at the bottom of the refrigerator. From the pan, the water normally evaporates.
If the tube or channel is clogged or obstructed, the water backs up and leaks into the inside of the refrigerator compartment. Then the water builds up at the bottom, inside of the refrigerator. When the water has built up for a time it may spill out of the front of the door opening. To fix this problem, clear the drain tube or channel and allow the defrost water to flow down to the drain pan.
Aug 17, 2009 | Kenmore 64802 Top Freezer Refrigerator
There is water collecting inside my refrigerator.
The drain for the water to get away when defrosting is frozen shut...
Checkout this tip to help you..
http://www.fixya.com/support/r3780310-water_running_in_refrigerator_from
heatman101
Aug 11, 2009 | Maytag MSD2756G Side by Side Refrigerator
Water accumulating under the vegetable boxes in the refrigerators
Jul 06, 2009 | Refrigerators
Side by side refrigerator has puddle under freezer
Check and clean door seal, chech defrost drain tube ad a cup of water and clorine into tube, Check drin pan and clean under refer.
Sep 08, 2008 | Sub-Zero 690 Side by Side Refrigerator
Whirlpool GI7FVCXWB (27 cu ft) Bottom Freezer French Door Refrigerator Logo
56 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
