Can I find a drawer for the Panasonic electric pencil sharpener?
We lost the pencil shavings drawer for the sharpener.
  • belgin guckiran
    belgin guckiran Feb 29, 2016
    pull the front part of the sharpener
    Genius:
  • 1,274 Answers
I'm betting amazon.com or ebay.com
Posted on Nov 12, 2014
Tip
How to sharpen a pencil so the tip doesn't break
When I was in school it would always frustrate me that the tips of the pencil were always breaking in the sharpener. It took many tries of turning the pencil and turning the sharpener, different amounts of pressure and I finally found the secret.
Sharpening a pencil is a very easy thing to do. When you are using a hand sharpener, either a small plastic one with a cartridge to catch the shavings or the really small ones that don't catch the shaving, your put the utencile end of the pencil into the sharpener keeping it has straight as possible.
Applying a little pressure turn the pencil in the clockwise motion (you can turn either the pencil or the sharpener both will work). The shavings will begin to fall off and you keep turning until either you are satisfied with the sharpness of the tip or the shavings stop coming off. Make sure that you don't put more pressure on the pencil to make the shaving keep coming off because that will make the tip break and get stuck in the sharpener.
Pull the pencil out and clean the sharpener, it should be good to go. What I discovered was that if I had dropped a pencil a few times then the lead inside the pencil would be broken and this would cause the tip to break after sharpening. Treating your pencils nicely will keep them from breaking tips when you sharpen.
on Jan 30, 2014 | Office Equipment & Supplies
What kinds of pencil sharpners are there?
There are many kinds of pencil sharpeners that have been developed through the years.
The most common ones, the manual sharpners, can be of the following kinds:
Mechanical sharpeners: a portable variety, usually small and in the shape of a rectangular prism. The blade inside rotates around the pencil, sharpening it. The shavings emerge through a slot.
Blade sharpeners: small and portable, hold replaceable shaving razor blades or permanently fitted blades. They work similarly to knives, but in a more convenient and safe way.
Cylindrical cutters: larger variety, stationary, powered by a crank. One hand holds the pencil, the other turns the crank.
Another common pencil sharpener found often in offices is the electric sharpener. It works on the same principle as the manual sharpener, but the blade rotates quickly thanks to an electric motor, either powered by batteries or plugged into the electrical system.
There are still people, mainly artists, that sharpen their pencils with a knife.
Oct 06, 2013 | Office Equipment & Supplies
When was the pencil sharpener invented?
Before the pencil sharpener was invented, pencils were sharpened by shaving away the wood with a knife. The first pencil sharpener was invented by Therry des Estwaux in 1847.
What is a pencil sharpener?
A pencil sharpener is "a device for sharpening a pencil's writing point by shaving away its worn surface. Pencil sharpeners may be operated manually or by an electric motor." (wikipedia)
How do I open and empty the shavings from the Panasonic Auto-stop Electric Pencil Sharpener model # KP-350
I don't have solution advice, I'm searching for it. How do you open it/the device?
Jun 29, 2013 | Garden
Where can I buy a shavings receptacle replacement for my X-Acto School Pro Electric Pencil Sharpener Model 167X. Mine got dropped and broke.
This is a new answer for an old question. Just today, I emailed the Xacto company (contact us on their website) and they responded with " a courtesy replacement will be sent to the address below."
May 06, 2013 | X-Acto XActo School Pro Electric Pencil...
When I insert a pencil into my brand new school pro sharpener, the blades spin, but do not sharpen.
The website says to check and make sure its not jammed with pencil lead or something else. unplug it take the shavings bin out and flip it upside down so you can look into the sharpeners. Rotate them by hand till you can see the open side of the blade then use a unfolded paper clip and slide it in the path the pencil would usually take. This should knock anything loose the would be jammed in there. If it passes through to where you can see the point you should be clear. If you didn't dislodge anything or it still doesn't sharpen but the blades spin when you try to use the sharpener, then there is a tab that can get jammed back that needs to be in the foreword position. The tab is located where the tip of the pencil would point if it was actually being sharpened. if you run the paper clip through the machine (just like when trying to dislodge something) the tip of the clip will touch the tab. make sure its not jammed back (away from the opening/pencil) it should be as far forward as possible for the blades to engage. I hope this helps! This has been jammed many times by pencil shavings or gunk on my wife's (elementary school teacher) pencil sharpener.
Sep 22, 2011 | X-Acto XActo School Pro Electric Pencil...
My automatic pencil sharpener stopped working after only 2 days. When pencil inserted, it does not turn on at all. Emptied shavings holder and replaced it in base. What do I do?
First, check and make sure it is still plugged in and that there is power to the plug.
Second, check for any fraying in the cord connection.
If you still have problems, you may need to return it to the store you bought it from or the manufacturer. Sometimes, a machine comes off the line that is broken.
Apr 26, 2011 | Staples Electric Pencil Sharpener
Stopped working
This happens with a lot of pencil sharpeners for various reasons, from the sensor going bad, to the motor going bad, or even the circuit shorting out. If you are a tinkerer you could probably open the pencil sharpener, by removing the screws, and look to see the problem. If not, I would advise sending it in for warranty repair, Panasonic is usually pretty good with this process. If you need help with the Warranty repair process I would advise calling them at 800-211-726.
Mar 22, 2011 | Panasonic Kp 410A Standard Electric Pencil...
623 people viewed this question
jasbo
jasbo
