Question about Coffee Makers & Espresso Machines
I have a Solis master 5000 digital machine and I keep getting the "watertank empty" warning on my digital display. I have checked the float and it is functioning fine; I shut down / unplugged and sti
I have checked the float and it is functioning fine; I shut down / unplugged and still the same error message.
    Genius:
  • 1,274 Answers
Posted on Nov 12, 2014
encyphered
  • 11 Answers
SOURCE: Parts for Solis Master 5000
Jimle's reference to www.partsguru.com is where I found what I needed. The challenge was figuring out that the parts for your Solis Master 5000 will be referenced under the Vienna model. You will not find any reference to the Solis model on this website. But there are parts for out Solis machines, heres a link for the boiler gasket:
http://www.shop.partsguru.com/product.sc?categoryId=-1&productId=282
here's the link for a completed boiler replacement $38.00:
http://www.shop.partsguru.com/product.sc?categoryId=-1&productId=937
I ordered the completed boiler at $115.00
Good luck and Best Wishes
Lane
Posted on Jan 04, 2009
  • 1089 Answers
SOURCE: Solis Master 5000 is leaking water from underneath
HI
The most common problem for leaking underneath the machine is the boiler, but there can be other problems. If the water is dirty, there is a drain behind the brew unit that gets clogged with coffee residue, If its clear, its probably the boiler. If its the boiler it needs replacing. Check ebay.
Posted on Dec 23, 2009
SOURCE: Solis Master pro coffee machine
I hope you found your answer in the meantime. If not, here's a page of manuals from Soli. The Master pro does not seem to be in english, but your problem might be covered in a similar manual. Here's the link:
http://www.solis.ch/kundendienst/kdienst_manuals_body.htm
Collette
Posted on Dec 24, 2009
  • 1089 Answers
SOURCE: Bean and water fault(red) light blinking
HI First make sure everything is in and locked (brew unit, drip tray, and dredge drawer). Open the knob on the right and flow water through the wand. Now turn the knob in the bean hopper to 16 and push the brew button. If that didn't work you might have a clog in the grinder, and will need to clean it.
Posted on Jan 26, 2010
  • 1089 Answers
SOURCE: Our Comfort machine won't brew and constantly
Hi
The magnet in the water tanks is either upside down or has sunk to the bottom of the tank. It should float to the top of the cage it is in and it should have a flat top not rounded. If its rounded side up the magnet is upside down. This is what would cause your problem.
Posted on Sep 23, 2010
How to correct Tread climber TC5500 error code NIPP COMM (Belt Shut Down).
If you wiah to get some details about treadmill error codes and solutions then check the following link
http://electro-medical.blogspot.com/
Oct 02, 2016 | Bowflex TreadClimber TC5500
What is causing my coffeemaker to keep giving me the error message "watertank empty"?
There is probably a float in the tank to indicate water level which is no longer floating. Jam something plastic under the float and that should solve it.
Nov 12, 2014 | Coffee Makers & Espresso Machines
P1 message on screen, just dumped the bucket full of water. Machine has basically shut itself down
Unplug it after replacing the bucket. Then plug it back in again and let it reset before you try to power up. Also the float sensor may be stuck in the full/shut off position... Lemmee know!
Jul 18, 2011 | Heating & Cooling
Shut down, auto shut off light is on. Machine will not turn on. Not sure of model number.
First, turn the unit OFF and unplug it from the wall outlet. Remove the bucket and check if it's full or not. If full, empty it. If not, and yours is equipped with a float valve in the top of the bucket, be sure that the float valve arm is not stick in the UP position. Giggle the float arm to make it return to the DOWN position. Replace the bucket in the bucket holder, being sure that it fits "squarely" in the holder from top to bottom and is not tilted down at the bottom. Plug the unit back in and turn the Master ON/OFF Switch to ON. Then set the humidity extraction level at 35%. If any of the above was the problem, the unit should start and function as it was designed.
Hope this helped you to troubleshoot and solve the problem. Please let me know. Thanks.
Jun 30, 2011 | Kenmore 54501 Dehumidifier
E15 error message making a funny noise, is the a
E15 indicates the anti flood device in the base of the appliance has been activated.
Unplug the appliance.
Take the cover below the door off.
Take the insulation out of the way.
Remove any water in the base that is lifting the float.
Once removed, try the appliance again. Watch through the open inspection panel to see if the appliance is leaking.
If the float isn't up activating the switch then the switch, wiring or control board is faulty. Check the float and check the switch.
Your machine is still under warranty so you do need to be careful about what you do.
Trying to repair it on your own may invalidate the warranty.
Hope helps.
Jun 11, 2010 | Neff 24 in. S5555X0GB Built-in Dishwasher
Problem starts with "paper jam" messager. Can not shut down as light keeps blinking and "shutting down" message is on screen.
hi!!!! in your case,try to unplug the power of your printer and check the material that stock inside the printer that can cause the printer paper jam and after you check to plug it back.It is normal when the printer is blinking when the printer is paper jam because that is the error when your printer is paper jam.
May 11, 2009 | Office Equipment & Supplies
Error 232*
Error 232 Severity 16
Error message text Arithmetic overflow error for type %s, value = %f.
Explanation This error occurs when Adaptive Server detects an arithmetic overflow error during execution of a SQL statement. Arithmetic overflows occur when a variable has too few places to store the converted data. In particular, Error 232 is raised when an overflow occurs for a variable of datatype float.
Error 232 can occur during execution of the convert function. It can also occur during implicit conversion within Adaptive Server, either during a stored procedure run or during execution of a SQL statement which converts a float value to some other datatype.
Action Determine which variable is causing the problem based on the datatype reported in the error message output and the SQL statement on which the error occurred. If the error occurs within a stored procedure, an additional error message will be displayed showing the name of the stored procedure and the line number where the error occurred.
Increase the size of the variable that is causing the error. If it is in a procedure, re-create the procedure.
If this error occurs on a Sybase-supplied system stored procedure, contact Sybase Technical Support.
Versions in which this error is raised
Jul 24, 2008 | HP OfficeJet 7310 All-In-One InkJet...
Full Tank
I had the same error and the tank was not even full. I took the cover off of the unit which consisted of removing 10 screws. The water tank is on the bottom left side. I then removed the float which was a small sensor with a styrofoam float. I removed the float (2 more screws) and moved it up and down. It did not appear to move very smooth but after moving it back and forth a few time it seemed better. I put the float back in ensuring it was at the low point, screwed it back in and then tested the unit. It came on and appears to work fine now. I unplugged again putt the cover back on it has now ran 30 minutes no problems.
Jul 13, 2008 | DeLonghi Pinguino PACL90 Portable Air...
Coffee Makers & Espresso Machines Logo
71 people viewed this question
Top Coffee Makers & Espresso Machines Experts
Colin Stickland
Colin Stickland
Kolbrun...
Are you a Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
