Dynamix power trainer 1507HA1-C has just started beeping and flashing on its own - does this mean battery needs changing?
2BR2H(YM-1507HA1-C) has just started bleeping and all the figures are flashing - have tried turning it on and off but it keeps happening - does this mean new battery needed?
  • 44 Answers
Try to remove the battery and then put it back in.. let us know the results
Posted on Nov 21, 2014
  • Daisy Underwood
    Daisy Underwood Sep 19, 2017
    Did you get this fixed? Mine has started doing it and I don t know where the batter bit is
Kegtapper
  • 94 Answers
SOURCE: battery
Generally yes! That battery may be toast.
One or more cells in the battery cannot take a charge or is shorted..
Posted on Jul 04, 2008
  • 33 Answers
SOURCE: My TOSHIBA laptop won't turn on
flashing three times means something physically wrong with ur laptop. could be fault with ur power supply, Hard drive or ram.
- with the battery, plug in ur power supply and check if ur LED is glowing and the laptop is charging well.
if the problem persists,
- reset the RAM and the Hard drive, [ for this take out the ram and Hard drive and put them back again].
if still the problem persists, take it to repair. ---------------------------------------------------------------------------------------------- u dont have to worry bout the backup in ur laptop. a simple solution would be to get a 2.5 inch hard drive enclosure, install ur harddrive into that, connect it to a different computer and back it up!, but be sure what type of Harddrive u have , is it a IDE harddrive or a SATA harddrive.
cheers suraj
Posted on Oct 10, 2008
chrisgoforth
  • 55 Answers
SOURCE: I put a 1gb expansion
Remove the 1 gig chip. Pull you battery out and unplug the laptop. Hold the power button in for 10 seconds. Put the battery back in and plug the laptop back in again and try booting it up. This should reset the BIOS and allow it to boot. The beep codes you are talking about are a memory beep code and it is normally caused by adding memory or a loose memory stick. Also try pulling the existing memory and resetting it.
Posted on Dec 20, 2008
  • 191 Answers
SOURCE: Black screen 4 beeps at start up
refurbished motherboard may have corrupted bios inside
Posted on Sep 13, 2009
midwan
  • 55 Answers
SOURCE: I have an Acer 6920
Hello Carla, It seems that there is a power problem, only it's not very clear where exactly it lies. Does the laptop power up with the battery only (unplugged from the power supply)? If it does, then it's probably a power supply problem and that could be replaced rather cheaply with a new one. If it doesn't start using the battery only, then it's most likely a problem on the laptop itself, which means it should be serviced by someone with the appropriate technical skills.
Posted on Mar 13, 2011
Manual for dynamix 2 In 1 Magnetic Elliptical Strid
If you wish to get some details; check the site linked here. Pull up older posts.
http://electro-medical.blogspot.com/
Jun 05, 2016 | Exercise & Fitness
Power Light Flashes 5 Times Won't Boot Up
If it uses AMI bios then 5 short beeps means motherboard failure.
  1. Remove RAM memory, Graphics card, other Plug-in cards, and Drive cables from your mainboard.
    Only CPU + Fan + Power cable are installed on the mainboard.
  2. Power on the PC, and listen to the beeps:
    • no beeps => Power supply, CPU, mainboard or BIOS is most likely defective.
    • some beeps => remember the beeps and next step.
  3. Power off the PC, and insert the RAM memory.
  4. Power on the PC, and listen to the beeps:
    • no beeps => RAM incorrectly installed.
    • same beeps as before => RAM is most likely defective.
    • beeps have changed => next step.
  5. Power off the PC, and insert the Graphics card.
  6. Power on the PC:
    • some beeps => Graphics card is most likely defective.
    • blank screen =>Graphics card is most likely defective.
Nov 15, 2015 | Gateway Ne56r15u Pentium Dual core B950...
Dynamix UPS 650HP beeps every 10 seconds and fault light is on. What does this indicate?
How old is the unit ? You may have to replace the unit the batteries may be too old to hold a charge -
Dec 22, 2014 | Computers & Internet
I need a manual for a dynamix cross trainer
http://www.allproducts.com/sports/diamond/Product-2007919144422.html
Jan 09, 2013 | Exercise & Fitness
With power button push in the light comes on and fan comes on but in 5 seconds it turns off. I've tried with battery out and just with power plug , still the same results.
Can be one of the following
  • Remove battery and power lead - press and hold the power ket for 60 seconds. put in power lead and it may start.
  • If you are getting beeps or lights flashing then you have a Power On Start up Test (POST) error. This means you have a hardware failure in the system. The actual error depends on the motherboard and the error beeps. Solutions vary depending on the error, can be from replace memory to motherboard is shot. Please let me know if you are getting beep codes, this may need professional repair.
  • Does not start and no beep codes, then the power or the motherboard has failed, this will need professional repair.
Jan 19, 2011 | Toshiba Satellite M65-S809 Notebook
PC start directly
Explain what you mean when you say 'when i open the pc from main switch'.
Also, something you should try is updating the CMOS, or in other words flashing the BIOS firmware. Go to your motherboards manufacturers website and see if there are any BIOS updates for it.
Mar 03, 2009 | Intel PENTIUM-4 865GV CHIP MOTHER BOARD...
Beep - Beep - Beep - but No Picture
1. If the camera can not focus on a subject, or can not determine the appropriate exposure setting, the camera will beep and disable the shutter button. This is to avoid improper processing of the image. This is usually due to either poor lighting conditions or movement. 2. The camera Flash Element requires ten seconds to recharge between images. Although the camera is ready to continue capturing images almost immediately in bright (daylight) settings, if you are using Flash photography the Flash element will need to charge between shots. If you try to take a picture before the Flash is charged, the camera will beep and disable the shutter button. Once the Flash unit is fully charged (10 seconds), the camera is ready to continue. 3. The batteries may be running low. LCD Display, Flash, and Playback use much more power than taking pictures. It is possible to quickly consume battery power, even if you are not taking many pictures. Try turning the Mode Dial to the OFF position to recycle power. If the camera beeps and will not take a picture under normal conditions, you may need to change batteries. Please refer to the section pertaining to Battery Life.
Sep 11, 2005 | Toshiba PDR-M25 Digital Camera
Sep 11, 2005 | Toshiba PDR-3320 Digital Camera
Computers & Internet Logo
62 people viewed this question
David Payne
David Payne
