Holly LSI forced air heater burners will light, fan will not blow. Fan works with on switch on, everything normal except fan not working on auto.
  • 2039 Answers
SOURCE: Heater blows cold, and fan switch only works on 4 and 5
working on 4 and 5 speed that the resistor that broken cold air you got to move the selector to see the motor that move the trap hot and cold sometime when the motor was not move to the hot side for a long time its jam the motor on the passager side under dash put to hot and gently tap the motor tanks pierre
Posted on Nov 09, 2008
  • 85 Answers
SOURCE: Heater no longer works on auto fan, only manual fan
When you call for fan in auto ensure your getting 24 volts at pin on control board, if it is not energizing then there is a problem with the relay.. Before you change out the expensive control board, try the therm..
Posted on Dec 09, 2008
carldc3
  • 82 Answers
SOURCE: question on a day and night gas forced air heater
it very well sounds like your fan switch , does your fan work at all, like in ac mode on by turning the fan on/auto switch on the thermostat to ON. If the fan does come on its the more and likely the limit switch. if it doesnt come on it could be the motor or the run capacitor. the limit switch has a dial on it that as it heats up it spins clicking on at a desired set temp ussually about 120 to 150 degrees F. turning on the fan if the fan doen't come in the the next setting clicks off the gas valve turning off the burners ussually set at about 220 degrees F. now if the fan is working when the heater is satisfied there is a setting at about 90 deegrees F. that shuts the fan off hope this helps
Posted on Jan 05, 2009
jamaicanmech
  • 17 Answers
SOURCE: My 1999 Ford F150 Heater only blows out cold air
guys have you checked for a vaccum leak????? there is a little plastic ball with a vaccum line going to it that controls the outside air coming in. check for a leak in this line
Posted on Jan 08, 2009
SOURCE: remington 60 portable forced air heater 60,000 btu
I had the same problem. I took the nozzle head off and blew through it with air. I also blew through the air line, this is the one that goes to motor. It has worked fine ever since.
Posted on Jan 16, 2009
I have a rudd UHLA-3617JA high achiever air handeler, works fine except the electric heater will not come fan starts normally, is this a fuse/breaker or failed electric element problem, how can i tell
It is either the element, sequencer (or contactor/relay), or power to the switching element. 5KW Elements normally Ohm out @ around 10 Ohms when they are good. Everything you need to check requires a multimeter.
Jan 21, 2015 | Heating & Cooling
94 thunderbird heat or cold air doesnt blow
if you saying the fan wont blow it may need a fan motor not uncommon it might be a speed switch if it has one some time you can hook a wire on the back of the speed switch plug in to get it on high use a 14 gauge wire or bigger a small jumper bent in a loop with the rubber peeled off the ends and shove them in the switch plug find the 12 volt ht wire on the plug with light or vom then try the other wires one at a time til fan runs with ignition switch on
Dec 24, 2017 | 1994 Ford Thunderbird
My Coleman direct vent forced air furnace 7995-656/D will fire up but the auto fan does not come on. I can cheat this by cutting the fan to on after the burner heats up. Whats my problem?
two things the pressure switch not working or the fan control afc not working could need cleaning at the back of the afc try this the afc works on temp rise to bring on the fan afc temp fall to shut of fan so it sound like the afc is not coming on at temp rise, also check if air filter is clean
Jan 19, 2011 | Coleman Propane Forced Air Heater...
Blower inop on auto or manual. burner inop.
Hi check out the fan control afc see if it is clean , check out pressure switch and the flame sencer
Feb 21, 2010 | Coleman Propane Forced Air Heater...
Have 30,000 btu Dayton heater m#3e3665 when reaches temp. fan
Hi blow heater out with air line flame sensor could be dirty check out pressure switch jump this out see if it lights
Feb 09, 2010 | Dayton (3E379) Heater
Question on a day and night gas forced air heater
Jan 05, 2009 | Honeywell L4064B2236 Fan/Limit Control...
Blower fan will not come on when set on Auto in heat mode.
the fan is controlled by a fan center or a stack switch. as burners light and heat up the spring sensor on the bulkhead above burners heats up and turns and a a point energizes the indoor fan if it gets to hot the burners go out on safty. sounds like a fan control is bad tap on them gently and they sometimes break loose but if not then have a pro replace fan control and test heat exchanger.
Oct 24, 2008 | Ruud UBHC Air Conditioner
Heater work when switch to fan on but doesnt work when swithed to auto but the ac works on auto or on, conufused please help
When switched to on does it make heat or is ir just the fan blowing? Take the first cover off the thermostat and see if there is a jumper wire from RC to RH. If not you need to add one. Also, the heat doesn't come on instantly like the A/C, it takes a couple of minutes for the pilot to lite, the burners to come on and then the time/temp delay relay will click on the fan motor, this may take a few minutes.
Dec 16, 2007 | Ruud Handler Air Conditioner
Heating & Cooling Logo
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
