Question about Whirlpool Duet Steam WFW9700V Front Load Washer / Dryer
<!-- from fixya rte -->What is a flashing F23 Error - Whirlpool Duet Steam WFW9700V Front Load Washer / Dryer
  • 46 Answers
What is a flashing F23 Error - blank.gif F23 Pressure switch failure Should the main electronic control unit detect that the wash level contact (or level) is on and the switch level for wash heater safety is off for any more than ten seconds during a wash this error code will be displayed.
Resetting the program may clear this error but unlikely.
  • Check the pressure switch or sensor for operation and electrically
  • Check the wiring from the main electronic control card to the level sensor
  • Check all connectors between the main controller and pressure switch
  • Run test program
  • Also see F08 and F12 as heater failure can cause this error to occur
Posted on Nov 12, 2014
  • Paul Heneghan
    Paul Heneghan Nov 21, 2015
    How do you run the test program?
  • 35 Answers
This is the pressure switch or the heating
Bosch shx36l05uc/21: After running diagnostics the 'wash' button keeps flashing, can someone tell me what the problem is?
Hi Jeff, As you can see there's 3 different Bosh washing machine models, Hope you can find your error code.... CHEERS..
Bosch Washing Machine Fault Codes
F16 - Door lock error
F17 - Inlet valve error detected
F18 - Drain error detected
F23 - Anti flood device has been activated
F34 - Door lock error
F42 - Motor fault
F43 - Motor fault
F44 - Motor fault
Bosch WAE Range Washing Machine Fault Codes
F16 - Door lock problem
F17 - Inlet valve
F18 - Drain pump
F21 - Motor
F23 - Anti flood system activated
Bosch WFP Range Washing Machine Fault Codes
F01 - Water intake timeout
F02 - Heating timeout
F03 - Draining timeout
F04 - Motor fault
F05 - Uncontrolled motor startup
F06 - Short on NTC Detected on hot water intake
F07 - Open circuit NTC Open circuit wiring
F08 - Door open when program started
F09 - Unexpected heating
F10 - Communication error
F11 - Overheating
F12 - Short circuit
F13 - Mains voltage too high
F14 - Mains voltage too low
F15 - Faulty temperature sensor on motor PCB
F16 - Faulty rinse sensor Displayed only in test
Mar 30, 2016 | Bosch Dishwashers
What does f23 error mean?
Display shows an error code - Front-load washer ' Whirlpool ...
https://www.whirlpool.com/...error-code...w...
Whirlpool Home AppliancesCheck the following answers for error-code related issues you can correct: ... Duet SportTM washer - F01, F11, F23, F24, F27, F28, F29, F30, F31, and F33.
What does error code f23 flashing mean on a Whirlpool ...
Nov 30, 2015 | Washing Machines
F23
PRESSURE SWTICH ERROR
The wash level and level heater safety are switched on at the same time F23
Possible Causes/Procedure
1. Unplug washer or disconnect power.
2. Check wire harness connections to pressure switch and Central Control Unit (CCU).
3. Check connections of the CCU board within the housing.
4. Check the pressure switch for worn or failed conditions .
cheers
Jul 18, 2017 | Whirlpool WFC7500VW Washer
F23 on whirlpool washing machine
Seems that your heater has failed. Check continuity of the element, wiring to the element and test the voltage from the controller panel board .
Click this link: error codes
Jul 04, 2012 | Whirlpool Washing Machines
Kenmore HE3 Gas Dryer F23 error
Well the F23 error code is an exhaust thermistor error. It indicates the thermistor is shorting out. This occurs after the thermistor heats up and that is why it happens after 2 minutes. Remember to unplug the power cord so there is no voltage present while servicing.
All you need to do is to pull the dryer out from the wall and be able to get to the back. If you can do this then you can replace the thermistor.
you can check out the below link for more information -
http://media.fotki.com/1_p,wksdqrtgsdbddsdxgtqsskgwtqkq,vi/wbrfdqtbtxwkrtsktgt/1/1303472/5961857/image59719img-or.gif
The thermistor part number is 8577274.
Good Luck!!
Thanks for using FixYa!!
Jul 07, 2010 | Kenmore Elite HE4 Electric Dryer
My Kenmore dryer is flashing a code F23 what does this mean?
F33 Possible Cause / Procedure 1.-Unplug washer or disconect power  2.- Check for wire harness condition to the pump and Central Contral Unit (CCU). 3.-Plug in the
http://www.scribd.com/doc/7075573/Whirlpool-Kenmore-HE2-Plus-Troubleshooting-Tech-Sheet-8540259
Was this helpful?
May 12, 2009 | Kenmore Elite HE3 Steam 8674 Dryer
The error F23
This error occurs when heater fails in the unit .
Try this
  1. Unplug power chord to the washing machine .
  2. Check connection to water heater .
  3. Check resistance of heating element .
  4. Check the water temperature sensor and connection to it.
Hope this helps .
Feb 21, 2009 | Whirlpool Washing Machines
ERROR CODE F71
The following list of codes indicates an electronics communication problem with the washer:
Duet HT® washer - F01, F03, F06, F11, F23, F24, F27, F28, F29, F30, F31, F32, F35, F42, F61, F62, F63, F64, F65, F70, F71, and F99
Duet® washer - F05, F07, F09, F10, F11, F13, F14, F15, F21, F22, and FdU
To remove the error display, press Pause/Cancel twice.
If Pause/Cancel does not work:
  1. Unplug washer or disconnect power for one minute.
  2. Plug in washer or reconnect power.
  3. Re-select the cycle and press Start.
NOTE: If the error remains on the display, call for service.
Dec 11, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet Steam WFW9700V Front Load Washer / Dryer Logo
606 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
