Question about AM Auto Parts 1997 to 1999 Ford E150 Van Air Flow Meter with Housing for V8 5.4L
What is the SPINDLE in the front brake system?
  • 3,961 Answers
In the average brake system this refers to the tapered stub on the front suspension knuckle, which mounts the front hub and bearing assembly. It has a thread on the end for the front hub nut (not wheel nuts).
The actual appearance varies widely from car to car.
http://www.ss396.com/mm5/graphics/00000001/FM-3712.jpg
Posted on Nov 12, 2014
How get off rear drum brakeoff 1500 silverado
Turn adjustement wheel through backplate hole to loosen the brake shoes. Pound off with a hammer and some wood so you don't damage drum.
Feb 26, 2014 | EBC Brakes 2006 Chevy Silverado - 1500,...
GE Adora microwave worked 20 minutes ago. Now, totally dead. The lights, fans, turntable motor, microwave cooking elements, nothing.. works. AC power to the outlet is just fine.
Sometimes if a lot of steam has been produced while cooking, water may collect under the turntable plate and run down the spindle into the turntable motor. This can short circuit the motor and it will take the fuse out with it.
The fuse is usually housed in a plastic tubular case about 2inches long. Split the tube apart and replace the fuse if necessary (it's something silly like about 7000 volts). Switch on and check to see if anything else is not working like the turntable, lights, or fan etc and replace as necessary.
Feb 16, 2014 | General Electric DVM1950SRSS 505 Adora...
Brake light comes on when braking
If you have a high level brake light, that may be the problem location
Dec 13, 2012 | Hyundai Hynda XG350 2003othrYrs/Mds...
NO TAIL LIGHTS 1996 F450
tail lights work off different wire than brakes hazards, etc. .It could be in the wiring, or simply the tail light side of the bulb itself has blown. Check the bulbs, it will have to separate filaments, if one of them is burnt into, tail lights will not work
Nov 27, 2012 | Ford F 450 Super Duty Cars & Trucks
Machine is very noisy especially on silent mode.
Check the fan bearing. Lubricate with spray grease on the spindle but be prepared to replace if no better.
Apr 05, 2012 | Oreck XL Professional Air Purifier
It is making a lot of noise. I believe it is the fan and I have oiled significantly with silicone spray on both sides of the fan motor and it resulted oin only a small improvement.
you will need to remove and clean but as a last try use a good deggreaser to wash off , try and use WD40, the use light oil-SAE40 to the fan spindle points and check out.
It will improve a lot but repeat the process a few times ,then switch on and repeat.
If sucessful, dont forget to vote
Sep 02, 2010 | Ecoquest Fresh Air Air Purifier
I was just wondering if the fragrances contain oil in them?
You simply remove the spindle and wash it out, and the spin wheel too if ot gets a build up. I use an antiseptic sort of smelling scent in mine and it helps capture dust. That is part of the build uop on the spindle. Simply turn it on the spin wheel and remove it and then wash it under hot water and let the hot water course through the spindle to clean it out.
Feb 09, 2009 | Rainbow Rainmate Air Purifier
Cleaning the fresh air purifier
You have cleaned the purifier. Now on the front there is a reset button next to the power button push that to reset cleaning cycle.
Oct 10, 2007 | Ecoquest Fresh Air Air Purifier
AM Auto Parts 1997 to 1999 Ford E150 Van Air Flow Meter with Housing for V8 5.4L Logo
53 people viewed this question
Top AM Auto Parts Air Purifiers Experts
David Payne
David Payne
ray gallant
Are you an AM Auto Parts Air Purifier Expert? Answer questions, earn points and help others
