Question about Marantz PMD660 Professional Solid State Recorder
How can I reset my Marantz PMD660 to the factory configuration?
After the swich turned on, nothing shows on screen, I can only replay a track and the light can come on shortly. I tried to unlock the Key Lock by holding dow the Shift and the Lock buttons but dothing happened. How to unlock? Are there two buttons to reset the hwole thing?
How do I recover the accompaniment?
When you press the accomp button does it show up in screen?
If not you have a button/switch issue.
Try a master reset - hold down top / highest note whilst turning on.
This will factory reset and may clear the issue.
Aug 01, 2014 | Yamaha PSRE413 Keyboard
Denon x600 want go to mac
Wrong... there are setting on the mixer that will get u on track..make sure you un plug usb FROM mixer. Turn off I'm not 100% sure ether master effect insert I know it is 1 of the insert buttons wit the right 1 hold down button turn the knob closet effect screen if right that screen should turn from PC 2 MAC when you see this hit the left BEAT BUTTON to save setting
Aug 31, 2012 | Denon DN-X600 DJ MIXER
My Ewi is playing most of the patches in Bb and some in others keys. How can I fix it? I 've reseted and nothing changes
You may need to do a factory reset. It sounds linke a transpose setting has been invoked. Read your manual under the word "transpose". A factory reset, if required, usually involves holding one or more buttons or keys down while turning on power and holding them until the reset is acknowledged.
Jul 20, 2012 | Akai Ewi4000s Electronic Wind Instrument
Yamaha MM6 Factory reset?
My Yamaha MM6 Synth is showing blank (white) screen when switched on. Keyboard sounds and banks are working. Everything looks nice but not showing any details on screen. Any help.....
May 20, 2012 | Yamaha MM6 61 Key Synthesizer
I was using my recorder and it locked up. Nothing worked, I couldn't get any of the track arming buttons, transport buttons, the shutdown button, or the mute/solo buttons to work. the only thing that...
It sounds like the hard drive has failed... cheap test, get another and reformat the new one. They are so inexpensive now. To avoid losing data, they lock things up if anything goes wrong. The unit probably can't get the ready signal from the drive and freezes...
Apr 21, 2011 | Tascam 2488mkii 24 Track Recording...
Static in background of recordings
There is not enough info here to narrow this down to far. What is the sound source? The internal mic or direct via cable? Also, does the background noise stay the same regardless of the playback mode? Supplying these details will enable me to locate the problem circuit and provide potential fixes.
Thanks,
Dan
Feb 16, 2011 | Marantz PMD660 Professional Solid State...
A screen showing figure I can't understand.
Turn it off, unplug it, take the batteries out and leave it that way for 1 half hour. This should reset it to factory mode. If this doesn't work, you may have a faulty screen.
Jul 28, 2009 | Casio Ctk 496 Electronic Keyboard with 61...
Marantz PMD660 Professional Solid State Recorder Logo
43 people viewed this question
Top Marantz Music Experts
Vito Vacirca Jr.
Are you a Marantz Music Expert? Answer questions, earn points and help others
