Question about Plumbing
How can i have my jets repaired in my whirlpool tub? I have 2 caps that have low to no pressure and the caps are continuously coming off. Are there Delta repairmen that help with this problem
WHERE OR WHO CAN I GET TO FIX THE PROBLEM ASKED
    Master:
  • 560 Answers
Contact the manufacturer for a local service person..
Posted on Dec 28, 2014
4 Suggested Answers
  • 68 Answers
SOURCE: low pressure on Delta 1400 series shower head
The Shower Valve is regulated to give only 2.2 gallons a minute. If you have the shower head off test how many seconds to get an approximiate gallon running in the middle hot/cold position. If longer than 30 seconds either the stem in the valve is clogged or the water lines to the valve are too small or kinked.
Phil
Posted on Dec 09, 2008
  • 23 Answers
SOURCE: Delta tub tap only cold water no hot water or pressure for shower.
take handle off and adjust the nylon set ring it is to prevent kids from getting burned and is probably set wrong youll see teeth and a pointer just pull it out a little and turn it in the oppisite direction then push back in
Posted on May 12, 2009
  • 1015 Answers
SOURCE: After a recent water main break, our Delta Model
Check the screen at the hose connection under the sink. Check the hoses for any large debris in them. Verify that the water pressure coming from the water outlets under the sink is good. There is obviously a restriction somewhere...you just need to locate it.
Posted on Sep 26, 2009
I have a whirlpool tub and need to find some caps to cover the jets. Not sure what brand tub is, sides are all covered. Can you help?
try a plumbers shop as it is a whirlpool tub
you state that it is a whirlpool tub then you say don't know what brand of tub it is
whirlpool is a brand name
any way the plumbers display of bathroom units and tubs will help you as the jets used are generic and not specific for the tub
Nov 16, 2015 | Whirlpool Home
We have a whirlpool tub with jets and the mice have eaten the plastic air tubing. what can we do
All of the parts of a Whirlpool tub are replacable. you can go to Whirlpool.com and call customer service to get part #s and order or you can patch the hose with applicable materials from a home repair store such as Home Depot or Lowes.
Jun 12, 2011 | Whirlpool Home
I BOUGHT A FORCLOSED HOME AND IT HAS A CORNER STYLE WHIRLPOOL BATH- SINCE I DONT KNOW A THING ABT THESE CREATURES I HAVE 2 QUESTIONS. I HAVE A DRIP STYLE LEAK FROM AN ITEM THAT ON THE INSIDE OF THE TUB...
Inline heaters for whirlpool bathtubs will not and cannot maintain any comfortable water temperature. Their sole function is to slow the time it takes for the water to cool off. The myth of their capabilities has long been a misleading sales propaganda joke in the industry.
Not all manufacturers put their model numbers on their tubs. Those that do will almost always post it on a label in the area of the tub where the back usually rests in the region of the motor but not on the motor itself.
I believe your quarter size cap is an air control for you jet. It controls the amount of air coming out the jet when the tub is full of water and the motor is on. You should see the difference in swirling water turning it from right to left or the other way around. If yours has a leak then I certainly hope you find the Model number. Good luck.
Nov 08, 2010 | American Standard Home
Fill tub, press button, hear motor but no bubbles,etc coming from jets
Are the jets open? The center of the jets turn to adjust the pressure of the jets. If this is not the problem, there may be a problem with the impeller in the pump assembly. If you here the pump turning and not buzzing, it could be an air bubble in the suction tube. This tube is the one coming from the front of the pump, if the pump is higher than the tube coming from the tub, or if there is a high spot in the tube, an air bubble is a real possibility. If the tube is level with the pump, there should be no problem with air bubbles and the problem lies in the top part of this paragraph.
Mar 10, 2010 | Whirlpool 5' Jacuzzi Tub Bathtub Cetra...
I have an air tub with and aquaflo tub master pump
probably already solved this but yes, you can put a heater on any bathtub that has water jets.
Feb 02, 2010 | Aqua Flo Aquaflo Tub - Master Tmcp 3/4 Hp...
Aqua glass whirlpool tub leaks. looking for closure caps to close off the jets for good.
To my knowledge there are no closure caps for your tub; you can however purchase new jets with new seals if the tub is leaking through the jets.
Aug 29, 2009 | Home
We've had a whirlpool tub with jets for 2 years. About a year ago, the jets stopped working--i.e. you push the button and nothing. Whe have it hooked up to one of those cool water circulator things that...
check behind the access door for a air tube that goes from motor switch to button if either side has come off you have to re attach it just cut off 1/4 inch of the tube before you do. that will make it fit tighter
Jul 20, 2009 | Jacuzzi - Bathtub - Alcove - Navona -...
Lasco whirlpool tub leaks. Water runs out on
Sorry, the tub will have to pulled out to find out what is leaking so it can be fixed. There is just no other way UNLESS you can open up the wall on the blind side of the tube. (but its probably and exterior wall...if the house is vinyl sided, it can be done. If brick, you'll have to pull the tub). If you just wanted to convert to a tub only, maybe Bathfitters has an insert solution...
Jul 11, 2009 | Whirlpool Lasco 7460621R Dossi-32 , White
Whirlpool tub, jets come on and won't shut off. No water in tub.
Is it a jetted tub, or a air bath tub with holes or jets in the floor? If it has holes or jets in the floor, the control box is bad and needs replaced. If it is a jetted tub, there may be a water level sensor, if so the sensor may be bad causing the tub to turn on.
Jun 13, 2009 | Whirlpool 5"x36" White Bathroom Drop-in ...
Leaks from jets along outer wall
This is a hard fix, The jets are glued on to the back of the tub with an epoxy type material. the jets should spin on and off from the inside of the tub. You need to determine if it is the hole where the jet is that's leaking or if it is the jet assembly and tubing that is leaking. If it is the jet hole that is leaking, spin the jet off and use aquarium grade silicone (Lowes carries it)
spread this around the piece sticking thru the tub and spin the jet back on. This is a hit or miss fix. No easy fix if it is the tubes or jet assembly, full access necessary for this repair.
Apr 24, 2009 | Home
Plumbing Logo
Top Plumbing Experts
Paul Carew
Tom Chichester
Are you a Plumbing Expert? Answer questions, earn points and help others
