Question about Shark 12-Volt Cordless Hand Vac
Why does my brush turn?
The rotating brush will not turn. Everything else is working just fine.
    Master:
  • Shark Master
  • 894 Answers
HI, it's Jim from Crucial Vacuum!
There are a few factors that could contribute to your vacuums brush roll not turning. The first thing you should check is the brush roll itself.
For the most part you can fix a brush roll with a quick cleaning or by oiling it's bearings, however, once the bristles endure too much wear and tear, it is time to replace it. Do you notice any hair strands wrapped around the brush roll, how about long strands of carpet fiber or general debris? Try manually rotating the brush roll and cutting away any strands that may be caught. take a look at your brush roll and see how the bristles look. If they look worn out and the bristles look loose it's time to replace it.
Also, be sure to check your belt. Your vacuums belt should be replaced about every three months. After regular usage, the belt will stretch out, lessening the tension on the brush roll. Lesser tension diminishes the brush roll's turn rate, speed and can lead to the brush roll not turning at all.
You can purchase a wide variety of high quality Shark replacement parts for your Shark vacuum direct from Crucial Vacuum with free shipping and an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10
http://www.crucialvacuum.com/shark.html?limit=all
I hope this was helpful. If you would like further assistance, please feel free to give us a call at 877.750.9239. We have helpful and friendly customer care representatives on the line ready to assist you.
Jim Thompson
Crucial Vacuum Customer Care
Posted on Nov 17, 2014
  • 141 Answers
Most likely the belt that connects the motor to the brush has broken and needs to be replaced. A relatively easy fix.
Posted on Nov 16, 2014
Brushes will not move
Try to turn the brushes by hand. If they won't turn remove the brush assembly to see if it is seized, if it is, take it apart and clean the brushes and the gears. If it is nor seized the turbine might be seized.
Dec 26, 2013 | Hoover SteamVac Carpet/Upholstery Deep...
Model UH70086 agitator brush won't rotate. the belt is fine and turns the wheels. replaced v belt because I thought it was stretched but new belt is the same size. everything turns, the belts and the...
The brush has to be able to rotate freely in order to work. If you remove the roller and its end caps you may find it is clogged with hair or other debris. Cleaning out the debris should allow the brush to rotate freely.
Nov 05, 2013 | Vacuums
I have a Dyson Telescope vacuum. Everything works fine, except the attachment used for floors. I can feel air and suction going through the attachment, but the brush doesn't rotate or move at all....
If you have suction as you say, the tool is faulty.
They come apart so you can clean them. remove all hair and debris from the roller brush (use a coin to split it using a quarter turn on the two/three screws). Try turning the brush with your fingers. If it is stiff, it needs attention to the bearings in the tool probably. If it turns OK, then the mini turbine inside is faulty -- replace the tool.
Feb 05, 2011 | Dyson DC14 Telescope Reach All Floors...
The brush does not stop rotating when the dial is set to "hose". What might be broken or need fixing?
hi. most vaccums the brushes dont stiop turning when you use the hose. so everything should be fine. keep on cleaning. have a good day!
Jan 15, 2011 | Eureka Smartvac 4870 Bagged Upright Vacuum
The rotator brush stopped turning. it turns fine
The brush roll will only spin when your handle is not in the locked upright position, once the handle goes upright - the brushroll de-activates
Dec 22, 2009 | Kenmore Progressive Bagless Upright with...
Brushes don't spin
Remove the bottom cover and replace the broken drive belt. Check that the brush will rotate freely--likely everything is jammed with hair and dust. The brush assembly should just lift out of the case and the end bearings will pull off. The brush needs to be removed to install a new belt anyway. There should be a diagram that shows how to install the belt (it has a half-turn twist).
Jul 15, 2009 | Hoover F6212-900 / F6215-900 SteamVac...
Front wheel problem
I would send it to protechrobotics. they will test all your components and let you know what needs to be done. if the repair is more than it's worth--they will help you out too.
http://www.protechrobotics.com/
Apr 07, 2009 | iRobot Roomba 4210 Bagless Robotic Vacuum
Rotating brush will not turn on my Dyson DC07
Yes I had the same problem on my animal Dysom. There is a button on the top of the dysom that turns the cacuum on. Right beside that button is another one that turns on and off the brush!!! Good luck!!! I accidently one day bumped that button and couldn't get my brush to work but after troubleshooting it, that was my solution.
Jan 22, 2009 | Dyson DC07 Animal Bagless Upright Cyclonic...
Bissell upright vac, brush on bottom does not rotate
The front brush motor will not engage until the power is turned on and the handle is in the down position. In the upright position the brush motor wont engage. Typical faults will be the belt is broken and needs replacing or the fornt brush motor needs replacing.
May 21, 2008 | Bissell Lift-Off(R) Revolution(R) Turbo...
Shark 12-Volt Cordless Hand Vac Logo
203 people viewed this question
Top Shark Vacuums Experts
JoeVacs
Thomas Perkins
Thomas Perkins
Are you a Shark Vacuum Expert? Answer questions, earn points and help others
