SOURCE: the cd player in my 1997 jeep grand cherokee is
yes. check the fuses in the dash before you do this tho. The fuses in the dash will go out before the one in the stereo will. Hope this helps and saves some trouble.
SOURCE: Factory cd player doesn't play aftermarket burned cd's
What format are you burning them in? CDA or MP3 most Factory units will only play CDA format, just pick you up a copy of Nero and choose Aduio CD, it will convert you MP3 format to CDA and you should be able to playthem with no issue, the CDA format also works in the old portable CD players as well...
Hope this Helps,
David
If my solution was helpful please rate accordingly.
SOURCE: 1991 jeep wrangler trouble starting and stalling
It could be a fuel filter clogged up or it could be a fuel pump going bad. Does the jeep start back up after it stalls? Is there any more symptoms?
SOURCE: Clock in radio will not display or radio station
I won't sware this will cure yours but I took the front cover off mine and where the little metel slot things plug into your radio i took some steel wool and cleaned and shined them up. The cover should come off by gently prying on the ends. Mine even had a spring that when you pushed on it it poped out a little. But becareful not to pry to hard. If it won't budge the get someone who can help you pull it off. You should see the metel contacts that almost look like you could take it out to prevent theft of the radio. Let me know if this helped. Just a guess mind you. Please no bad marks, Good Luck, Raz
SOURCE: 99 Jeep Grand Cherokee. Radio
yes but why fix a 12 year old player ? something else will just go wrong after that heck cd players are cheap today and fit right in that opening
