My TV says no RGB signal - Televison & Video
    Problem Solver:
  • 11 Answers
Your TV is on the PC input. Change to whichever input has a source connected. (Typically HDMI 1)
Posted on Nov 19, 2014
I can't get a signal because this tv don't have cable antenna terminal the tv has rgb terminal. I don't know what to do?
RGB is for a computer screen display signal and has nothing to do with TV display of channels. You must have a Component hook up, it is a yellow cable, a red and a white one. Yellow is video signal, the red and white are sound.
Sep 12, 2016 | Panasonic TH-42PWD7UY 42 in. EDTV-Ready...
KEEP GETTING MESSAGE ON TV (RGB ON TV SCART HAS BEEN ENABLED)
trouble shooting common problems when using RGB ...
https://www.retrogamingcables.co.uk/trouble-shooting-guide-for-rgb-sca...
No video or sound on tv when using RGB SCART cable. Check that the SCART socket you have plugged the SCART cable into is an RGB enabled port (this is ... Some TVsets display an 'RGB' message in the top right of the screen for a short ...
SCART - Wikipedia, the free encyclopedia
https://en.wikipedia.org/wiki/SCART
WikipediaThe signals carried by SCART include both composite and RGB (with composite ... A VCR will often have two SCART sockets, to connect it to the TV ("up", ... SCART enables a device to command the TV to very quickly switch between signals, ... The box can instead ask the TV to stop displaying the normal signal and ...
How to use your TV as a computer monitor for gaming, videos
www.cnet.com > Home Entertainment
CNETJan 26, 2012 - Many modern video cards have an HDMI output. ... The trick, of course, is finding a TV with RGB-PC inputs. ... You can also send him a message on Twitter: @TechWriterGeoff. ... (Or just enable game/graphic mode) ... As yet I've been unable to find anything online that lists TVs that do or don't work with PCs ...
Scart fully RGB enabled? ' AVForums
Feb 09, 2016 | Televison & Video
What is a RGB signal
RGB means Red,Green,Blue it is an old system for supplying video signal to a screen..
Feb 01, 2016 | Televison & Video
How to turn on rgb from lap top to tv.
In order to connect your laptop to your TV using RGB, you need an RGB adapter. RGB is also known as component video; it breaks up a video signal into red, green and blue. laptops do not have RGB outputs. However, many laptops have VGA, DVI or HDMI outputs. An RGB adapter connects the single VGA, DVI, or HDMI cable to an RGB cable, which is actually three different cables tied together. INSTRUCTIONS:
1. Connect either the VGA, DVI or HDMI (in the order of increasing video quality) cable to the VGA, DVI or HDMI port on your laptop, depending on what is available. 2. Connect the other end of the cable to the side of the RGB adapter with the single input. 3. Connect the RGB cables to the red, green and blue ports on the other side of the RGB adapter. 4. Connect the other end of the RGB cables to an available component input on the back of the TV. 5. Tune the TV to the component video input you used through your television's menu. 6. Turn on your laptop. The laptop should now display on your TV screen.
May 30, 2011 | Computers & Internet
How do i get 1080i, my tv shows im only in 480i. i think i might have it hooked up incorrect. my other tv of another brand is much newer so all i did was connect the hdmi cable from the tv to the cable box...
Hello
Your TV will display all High Definition signals as 1080i True HDTV™ and all standard definition signals will be displayed as 480p.
Component Inputs 1-2
YPbPr(480i/480p/1080i)
These inputs can be used for the connection of A/V equipment with component video outputs, such as a DVD player or external HDTV receiver. Please see Appendix B for signal compatibility.
Input DTV (480i/480p/1080i)
This input is used to connect an external DTV receiver, and can be configured for YPrPb and RGB plus H&V signal types.
As a special feature, you have the ability to adjust the red and blue light beams in reference to the fixed green light beam. This process is called convergence. There are two separate memories for convergence. One, for SD 480i/480p signals; the other for HD 1080i signals. SD convergence should be adjusted while watching an SD source and HD convergence should be adjusted while watching an HD source.
Wide Expand: Enlarges the picture, cropping some of the image on both sides. This Expand format is useful to remove or reduce black side bars on HD broadcasts of 4:3 images with black bars. Available for analog 1080i, digital SD 16:9 and digital HD signals.
InputDTV
This input is compatible with most standard DTV and satellite receivers with component video (YPbPr) outputs. Compatible DTV signals are SDTV 480i/480p, and HDTV 1080i. All other DTV signals, such as 720p, need to be converted by the DTV receiver to one of the compatible signal types. Please check the DTV receiver specifications before connecting.
This input is compatible with some DTV receivers using RGB with "separate H and V sync". Compatible DTV signals are SDTV 480i, 480p, and HDTV 1080i. All other DTV signals, such as 720p, need to be converted by the DTV receiver to one of the compatible signal types. Industry standards for DTV RGB signals (systems, synchronization, timing, and signal strengths) are not currently established. These inputs will not be compatible with all DTV receivers that offer RGB, HV outputs. RGB, HV signals with less than 5 cables are not compatible.
If your DTV receiver offers both DTV component video signals and DTV RGB, HV signals, we suggest you use the DTV component video signals. Check the DTV receiver specifications before connecting.
Ok.
Feb 05, 2011 | Mitsubishi WS-73909 73" Rear Projection...
Hooking up my Sony HD Tv
Couple of items come to mind.
In the menu of the receiver, is there a way to choose video and RGB?
Set the receiver to SAT
Connect the HD Cable Box to SAT
Check the TV is on Monitor RGB.
Check the input being used by the monitor RGB cables is selected on the TV.
Have a picture? NO, receiver has issues.
Yes? Do this with each input to confirm they work.
You can reset the whole receiver to factory by holding the tone button down and holding the standby button for three seconds. (This clears your speaker setups, too.)
Apr 02, 2010 | Televison & Video
Vizio light is on on the front of tv, but when you turn it on it says no signal and turns off. VX37L
Your TV may be in RGB mode. Immediately after turning your TV on, press the TV button on the 'input' section of the remote. Hopefully that works for you. Your TV is designed to turn itself of in RGB (monitor) mode if no signal is present.
Jan 02, 2010 | Vizio VX37L Television
Using TV as computer monitor
Same problem!!! Inspiron E1505 connected to a year old LG 47" 1080p lcd. My rgb used to work fine, plug and play with my pc. No luck with my laptop though. I've tried setting up duel monitors, updating all(atleast I think all) of my drivers, and rechecking all connections!! Please Help.
May 06, 2008 | Televison & Video
Trying to use rgb input
Cable TV: Connect the LCD TV to the cable with CATV and Digital cable. Preset the cable TV channels into memory with Auto Scan function when using a cable TV system. Make sure you set the INPUT SOURCE properly (TV, VGA, S-Video, etc)
Mar 10, 2008 | ViewSonic VPW425 42 in. Plasma HDTV
Green Picture
The problem sounds like one I had. If so, the cause is as follows.
The Daewoo ouputs synchronisation information on the green channel of the RGB outputs (which are pins in the SCART socket) The Panasonic TV automatically preferentially selects the RGB input in the SCART rather than the composite video signal in the SCART. The video circuits in the Panasonic should ignore the sync on the green channel but instead interpret the sync as green signal information which means the adjustment of the green channel is upset leading to a very green picture.
Possible solutions:
1. From the TV, manually select composite video input, not RGB. This may not be possible - I think the TV automatically goes for the RGB if it is present.
2. Disconnect the wire to pin 16 in the SCART socket. This is the signal from the VCR/DVD to indicate that RGB is available. Disconnecting it means the TV defaults to the composite video. This is what I did.
3. Connect the TV to the VCR/DVD using component or S-VHS leads only.
Jan 13, 2008 | Daewoo DV-6T955B DVD Player/VCR
Televison & Video Logo
27 people viewed this question
Top Televison & Video Experts
