Question about Xante Ilumina 502 GS Digital Color Press laser toner
What happens if you pull paper jam the wrong way
What will happen if you pull a paper jam from opposite the feed direction
    Problem Solver:
  • 7 Answers
You may break any of the plastic switches actuators, which could cause a problem and your printer would not work until you replace that part that is broken. Depending on what area of the printer you broke the problem will be shown on your printer pannel.
Posted on Jan 23, 2015
What happens if you pull a paper jam from feeder, the opposite direction that your support to?
There are usually a number of paper guides and sensor arms that will tear into the paper if pulled the wrong way.
This can leave paper fragments in the fuser causing further jams, temperature sensor malfunctions, or odd marks on the print, and small pieces of paper left in the fuser usually require disassembling the unit to clean it out.
At worst case one or more sensor arms could be dislocated or broken which can be difficult or expensive to replace.
Nov 14, 2014 | Xante Ilumina 502 GS Digital Color Press...
Tip
How to maintain your ink-jet printer
In the printer market there have thousands difference brands and models ink-jet and laser-jet printer, how can we eleminate their trouble to the minimon and extend their lifetime as long as we can. The paper tray for the ink-jet printer most are open top style, therefor very easy to catch dust and other cbject and cause paper jam, paper skew, paper rinkle, some cases are easy to remove some don't,when you have those case happen, the first thing you have to do is check the paper tray inside of the bottom , looking for somethings it not belong to, then clean up the paper feed roller with rubbing alcohol. Now how can we prevent it happen, the way is when finish printing use something to cover the tray. when paper jam occure, remenber, never pull the paper opposited way, you have follow the direction let he paper go forward, otherwise you going to damage the paper senser.
How about laser printer, the laser printer it's structure much stronger than ink jet s the cost much higher too, but their maintainence much easier, when it have paper jam occure, commonly replace paper pick up roller and paper stop roller, if you hear noise from back of the machine, 90% the fusing unit have problem, if the noise come from front, the problem almost in cartridge, the cartridge, here , I like to give you advise, use brand name cartridge better than generic one. because, too much manufacture, skill all difference as well as quality all difference, be careful, be smart !
on Dec 10, 2009 | Office Equipment & Supplies
My Kodak printer wont grab the paper in the paper tray
Amandasplace:
There is a sensor that is located where the front edge of the paper sits when you load paper. If you take all of the paper out of the feed tray and use a flashlight to look in the throat of the paper feed area, you should see a small piece of plastic (in the shape of a blade) sticking up. If you do not see that sensor flag it may be broken off, or there may be a small piece of paper jammed against the sensor flag, keeping it from moving downward when you load the paper tray. That can happen if you pull a mis-fed piece of paper out of the machine in the opposite direction that the paper normally travels when printing. When you load the paper in the machine, it pushes that sensor flag down, telling the machine that there is paper loaded. either the sensor flag is broken off or there is something jamming the paper sensor, keeping it from being pushed down by the paper.
Nov 23, 2012 | Kodak ESP Office 2150 All-in-one Printer
My indicator is showing a paper jam and I have cleared all paper that I can see from the feed area. It still instructs to clear the paper jam. Do I need to try to get inside the box and if so - how should...
Once some printers report paper jam, you most must go through certain procedures, even if you have removed the jammed paper, for the printer to print again. So I suggest you follow this procedure:-
i. Put off the printer and unplug it from its power source.
ii. Open all the covers/shutters on the printer (usually you will find one in the front or top and one at the back of the printer).
iii. Site the paper (if any) that has jammed and pull it out in the opposite direction of its movement. Do not pull in the direction it was coming out. (Pulling the paper in the opposite direction is important for the printer’s mechanism. Printer must be off). Never pull out paper from a printer when the printer is powered on.
v. Close all covers at the top, front or back.
vi. Power on your printer and you should be able to print again.
Dec 19, 2009 | HP J4680 Office Jet All-In-One Printer
Paper Jam. It starts printing and stops half way through its print cycle, says paper jam, in fact their is no jam.
check if this is happening from all trays... if such clean the paper feed rollers... if still happening clean any other rollers in paper path... if still happening then you have a bad sensor that keeps tripping at the wrong time... but more than likely this is only occuring with one tray... clean your feed rollers and it should be ok... still not ok... then replace feed rollers... there is also the possibility that your fuser is shot... your can tell if your fuser is shot if... when you put your hand near it... it doesn't feel like it could burn you... if you can actually get to touch it and its cool to the touch... then you got a bad fuser...
Dec 18, 2009 | Office Equipment & Supplies
States paper is jammed...no paper jammed...tried to use feed switch, reset, turning off and on nothing works
Once your printer, for any reason reports "paper jam." It expect you go through the basic motions of clearing paper jam, else it won't procede to print. So you need to patiently follow the procedure below am giving you.
iii. Now pull out the cartridge carefully and place it on safe surface. (Be careful not to place it where it may slide and fall. This could damage the cartridge)
iv. (You may ignore this step)Site the paper that has jammed and pull it out in the opposite direction of its movement. Do not pull in the direction it was coming out. (Pulling the paper in the opposite direction is important for the printer’s mechanism. Printer must be off). Never pull out paper from a printer when the printer is powered on.
v. Return the cartridge gently and press it firmly inside so that you here it snap inside.
vi. Close all covers at the top, front or back.
vii. Power on your printer and you should be able to print again.
Dec 07, 2009 | Canon PIXMA MP600 all-In-One InkJet...
How to clear paper jam in HL 5040 laser printer
Clearing paper jam in a printer is simple almost seven step procedure.
i. Put off the printer.
ii. Open all the covers/shutters on the printer (usually one in front or top and one at the back.
iii. Now pull out the cartridge carefully.
iv. Site the paper that has jammed and pull it out in the opposite direction of its movement. (Pulling the paper in the opposite direction is important for the printer mechanism).
v. Return the cartridge and press it firmly inside.
vi. Close all covers.
Dec 04, 2009 | Brother HL 5040 Laser Printer
A paper is jammed in my printer and although it gives directions to open cartridge 1 and then take out paper cartridge then remove jam, I cant see any paper jammed, but I did hear it jam when it happened....
in right side of the printer one green color lock is there pull that luck ......paper feed unit will come out there you can see the paper ......
if you want manul send me your mail id anantakumarjena0@gmil.com
Nov 02, 2009 | Kyocera Mita FS 1900 Laser Printer
PAPER FEED DOESNT WORK KONICA MINOLTA COLOR PRINTER
This happened to me one time after I pulled out a jammed paper the wrong way. I pulled it from the paper tray. Heard the sounds, it tried to grab the paper, but couldn't. It happened a long time ago, so I'm fuzzy on which part I tinkered with...but I recall that because I pulled the paper (backwards) from the tray, it flipped a lever/feeder/roller/thing and that 's why it wasn't grabbing the paper. If you look in the paper tray as the rollers go down to grab the paper, you'll see what's not working......sorry, lame solution.
Mar 26, 2009 | Konica Minolta magicolor 2430 DL Laser...
Xante Ilumina 502 GS Digital Color Press laser toner Logo
57 people viewed this question
Top Xante Office Equipment & Supplies Experts
Ottoniel
Dudeman321
CheckitRight
CheckitRight
Are you a Xante Office Equipment and Supply Expert? Answer questions, earn points and help others
