Question about Golf
1998 48v club car no power to activate solenoid help
Replaced solenoid and controllor
  • 636 Answers
Pleasecheck out golf cart king out of Austin Texas. Very fun I'm willing to share their fast. But they have the products that you will leave your cart. A thumbs up would be greatly appreciated if answer is helpful for your question. THANK you and GOD BLESS
Posted on Nov 22, 2014
Hi! An elderly friend in Tadworth,Surrey lives alone & really needs to socialise as she's suffering from loneliness. Any help available? Thanks
She could join a local bowls club
She could go do a local bingo game.
She could contact local council and see if there are any day club activities run for the elderly .
She could contact a local RSL and see if they run any day club type activities.
Senior Citizen type places ?
Probus club is another
Lions Club is another
look at clubs she could join in her area .
Dec 08, 2016 | Video Game Consoles & Games
Lots of power, dash lights up but no ignition power to starter, relay changed, neutral start switch changed, fuses good.
Well, looking at the schematic, there is the IGN A (Fuse 6) in the under-hood fuse block feeding power to both the ignition switch and to the NO contact of the starter relay. Turning the ignition switch to the START position sends this voltage thru the CRANK (Fuse 8) in the instrument panel fuse block and thru the PARK/NEUTRAL position switch, thru the starter relay coil to ground. This should activate the Starter relay and pass voltage to the starter solenoid to ground, activating it. One the starter solenoid activates, batter power is sent to the starter motor, activating it. If, as you say, the fuses are good, the starter relay was replaced and is good, and the Park/Neutral position switch was replaced and is good, then then only items left are the ignition switch itself, the starter solenoid/motor, or the wiring of the circuit.
Mar 12, 2015 | 2000 GMC Yukon XL
Reduced power mode
reduced power mode is usually activated to protect the engine , have you check all the fluid levels as a starting point, as have no code to guide you
May 25, 2014 | 2004 Cadillac SRX
Club car 48 with fully charged batteries will not go
if the batteries are 4+ years old its most likely low voltage .also check solenoid.Club car is very good and not many problems with them.most likely it is minor.
Oct 16, 2012 | Cars & Trucks
Won't shift out of park
There is a brake pedal sensor that keeps you or your children from accidentally knocking the vehicle into gear. You have to press hard on the brakes to activate a switch. Once the switch is activated, current is sent to a solenoid that releases the shift lock. But if pressing on the brakes hard is not helping then the transmission needs to be checked. The gears are got worn out.it needs to be checked and replaced. Also check the power to the solenoid and brake lights. That would be called the shift interlock feature. It operates on the same circuit as the brake lights so the first thing you want to do is to make sure the brake lights are working when this problem is present. If the brake lights are working, that proves the circuit is good up to that point, then you'll have to get to the solenoid in the console. Disassemble as much as you have to to access the solenoid near the shifting mechanism. Us a 12v test light to test for power coming and going at the solenoid when the brake is applied. If power is arriving and switching and the solenoid is not triggering, the solenoid is bad and will have to be replaced. Thanks. you can rate this solution and show your appreciation.
May 19, 2010 | 2005 Mercury Grand Marquis
Cannot turn off power
Sounds like you may just have some bare wires touching,Trace the wires from the ignition switch.
Jul 22, 2009 | 3d Rose Londons Times Funny Cow Cartoons -...
Have solenoid: MOPD 125, WATT 2.3, VOLT 24/60, for Aprilaire 560 Humidifier. With a M15 Universal tester using 150mA for + & K OHMS FOR -, I get 2 ohms on scale which would be approx 200 ohms. Ohms = Volts...
I am guessing you have sent 24 volts to the solenoid directly and the the solenoid did not activate?
If you have not send power directly
If the solenoid does not activate that way more then likely needs a new solenoid.
Mar 05, 2009 | Aprilaire 550 Humidifier
95 Club Wagon Econoline will not start
make sure your battery is 100% on your solenoid there should be 2 or 1 small wires on it [ IF IT HAS 2 WIRES MAKE SURE U HAVE NOT MIXED THEM UP TRY SWAPPING AROUND ] use a test light and check for power while someone hold the key on start if u have power with the key on start then u still have problems with starter.
if u have no power then connect wires back on hold your foot on the brake hold key on start and move gear lever up and down if it starts then inhibtor swich needs adjusting or replacing see how u go let me know if u need anymore help
rate my help
Dec 18, 2008 | 1995 Ford Econoline
P0440, p1676 Evap purge solenoid problem please help!!
the computer in a buick is vary difficalt to figure out i would recomand on taking it in to the nearist GMC Pontiac buick dealer near u so they can do it for u
Sep 04, 2008 | 1998 Buick Century
Golf Logo
232 people viewed this question
Top Golf Experts
Ronald Prier
Bill Boyd
Tom Chichester
Are you a Golf Expert? Answer questions, earn points and help others
