Question about Kenmore 74602 Gas Dryer
Hange light on gas dryer - Kenmore 74602 Gas Dryer
  • Kenmore Master
  • 744 Answers
Hello Robert;
My name is Peter. I am a retired field service appliance technician.
The number that you have provided is your owners manual number. This is a generic manual which applies to several models.
Open the door on your dryer and you will see a label with the model number.
What are you trying to do? Replace the light? The light assembly?
Posted on Nov 14, 2014
I just want to know how hot the clothes part getts in the maytag performance gas dryer does the regular mode reach 122 degrees
Dave, Dave here.
I would type Maytag into my box in the top of the computer screen and see if you can find the phone number of the Maytag factory service representative.
They might be able to tell you.
Another choice would be to put a thermometer ( like a candy thermometer) inside another dryer belonging to someone else and look at it when it is in the middle of a heat cycle. You would want to hang it inside somehow so it did not tumble and break.
Be blessed.
Feb 22, 2013 | Maytag Dryer. Gas Dryer. Performance...
Burning smell but not odd sounds
make sure vent is cleared MDG is a gas dryer so sometimes when theyre heating it may smell different than youre used to. blower impeller wheel has a "D" shaped hole & can round out causing it to hang up the motor which could cause a burning smell but usually will make a lot of noise B4 that will happen.
Jun 29, 2012 | Maytag Neptune MDG5500AW Gas Dryer
No heat in my gas dryer, ignitor replaced, and sensor dry level does not light? I miss my dried clothes!
It sounds like your thermal fuse blew which is very cheap and easy to replace. Unplug your dryer and gain access to the back panel. Remove the panel and locate the thermal fuse. It is usually a white piece of plastic about 1/2" wide and 1 1/2" long with two wires attached to it. (Generally located near the bottom left as your looking at it) Unplug the two wires and unscrew the screw holding it in place. Replace it with the new one and reassemble everything. Good luck!
Apr 10, 2017 | Maytag Neptune MDG5500AW Gas Dryer
Gas dryer burner intermittently lights. Foul gas
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Aug 17, 2010 | Estate TGDS680EQ Dryer
Dryer will not get hot
Tromm LG DLG5988 gas dryer
Heater not turning on Gas light on Cooling light on at the same time Heat Sensor light on
I checked gas it is on and flowing through the pipe up to the dryer
Can't find igniter, reset switch or fuses on the dryer
Jun 01, 2010 | LG DLG5932W Gas Dryer
A piece of felt like material is hanging from the inside (top) front of the dryer. What is this? Can I fix it myself?
The felt is the seal that keeps the clothes from falling inside the dryer. The front of the dryer needs to be removed and the seal replaced (you can glue it back, but this usually means the seal is worn out)
Apr 21, 2010 | GE DBXR463GB Gas Dryer
Old maytag gas dryer. Does not heat anymore, gas
Maytag dryer series 05. How do I light the pilot?
Apr 04, 2010 | Maytag Dryers
My husband is right now hanging a belt in out
angie tell him to stop relax it is a bit of a pain to do it must be done fron the front patince it will go
Jun 26, 2009 | Maytag MDG2706A Gas Dryer
Can the Maytag Neptune Gas dryer converted to electric?
A gas dryer is dedicated to the use of gas to supply its heating function. It works on 125 volts. No way can a gas dryer become an electric one. UNLESS!
you just want to hang out yer clothes under the sun and use the dryer as a way to fluuf up yer clothes OR you could place the dryer into a box and make a condenser dryer out of it. Like cool hand luke you will toss that dryer into a rigid metal box in direct sunlight so that it can be an unbearable 140 degree up in there. then grab yer clothes and toss em in there and close that tar paer lined tin box up my friend.Let the sun do its thang. I think i just invent the redneck dryer! we don't need no stinking gas. Green power to the people! LOL
Apr 08, 2009 | Maytag Neptune MDG5500AW Gas Dryer
Kenmore 74602 Gas Dryer Logo
59 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal DeAngelo
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
