Question about Kenmore 74602 Gas Dryer
<!-- from fixya rte -->How do I change the light in gas dryer - Kenmore 74602 Gas Dryer
    Sergeant:
  • 303 Answers
There is likely an access spot on the back of the dryer that allows you to change the bulb without taking the entire dryer apart. the most you may need to do is remove the back panel of the dryer to access the light socket. it should either pop out with a clip or twist out 1/4 turn like the headlamps of most cars then you can replace it with a high temp appliance bulb as they last longer than standard bulbs
Posted on Nov 24, 2014
Ignitor works, lights the gas, then when the ignitor goes off, so does the flame.
Hi Stanley,
the problem with the dryer flame going out is caused by defective coils on the gas valve and the gas valve coils should be replaced
Dec 03, 2011 | Speed Queen Dryers
I have changed my theremal fuse twice in the last three days. it seems that the dryer is getting too hot. When i change the fuse it works for one load, then the burner will not light any more. is there...
Yes, the thermostat needs to be replaced at the same time...
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Dec 10, 2010 | Roper RGX4634KQ Gas Dryer
We have a Kenmore gas dryer model #76832500. The ignitor glows and the gas will light for a short period of time and then go out. Once the dryer cools down it will light again. Our manual shows there...
The 3 pin coil is your booster and holding coil and it ignites the 2 pin secondary coil. Is the flame blue or yellow? I would change both. Coils are a lot cheaper than the whole gas valve assembly.
Make sure to check the dryer's airflow. If the dryer is ducted, pull the machine away from the duct and try starting it again. Does the dryer have some sort of electronic control which is sensing an error and terminating the heating circuit? If there is it would be a box type thing located near the gas valve and it would have lights flashing on it. If that's the case, it's a new problem in itself as you would need an error code listing to begin looking.
Assuming air flow is good and gas supply pressure hasn't dropped (also check that gas inlet hose is kink free) and it is the coils that are failing, change both and fix your problem
Aug 29, 2010 | Kenmore Dryers
Gas dryer
changed bad thermostate glows but won't light
Jul 01, 2010 | Kenmore 74602 Gas Dryer
I have a gas Whirlpool dryer. I have changed the
no way to visually inspect that i know,but is the gas valve opening? you may have to replace the magnetic coils tat opens the valves.also tap on the gas valve lightly,could be sticking shut.
Sep 08, 2009 | Dryers
How do I replace the gas valve coils on my maytag atlantis gas dryer?
usually the gas valve is not the issue on these dryers after ten years of doing service calls i have only ever changed one. have you replaced the element that lights the gas? they have to see a certain resistance before they will open the gas valve. these will usually develop a hairline crack they will still glow red but not open the valve. when you replace it make sure you do not touch the element as this will shorten its life.
Apr 27, 2009 | Maytag Atlantis MDG6400AW Gas Dryer
Ran out of gas, how to restart dryer
All new dryers come with electronic ignition sources.
There is no pilot light to be lite on this type of gas dryer.
Feb 19, 2009 | Maytag Neptune MDG5500AW Gas Dryer
Burner wont light
If you have replaced the igniter and the thermacouple. Your next item is the gas valve. This is not that hard to change out, but is probably the most expensive part on the dryer.
Please rate this solution
Aug 02, 2008 | Whirlpool LGR7646E Dryer
Kenmore 74602 Gas Dryer Logo
66 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal DeAngelo
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
