Question about Garden
I recently bought a kubota m5400 tractor and it wont start, i put a new battery in it and it started right up but as soon as i turned it off it wont start back up. what do you think the issue is?
  • 114 Answers
Filters-plugs--bad fuel
Posted on Nov 20, 2014
SOURCE: Husqvarna Riding Mower won't turn over
It could be a combination of things... it could be a loose earth lead from your ignitor pack or your timing could be out, check your key way that will be in the centre part of the magneto.. too see if its ok will need to remove the magneto to see the key way if its brocken it will not fire up and sometimes will back frie through carb if its bad enough, also check your gap between the ignitor pack and magneto should be around the .20 too .25mm by feeler guage...
Jay QLD AUS
Posted on Feb 24, 2009
dennymulford
  • 1055 Answers
SOURCE: hooked battery up wrong when jump starting lawn tractor
there a fuse in the power wire you probly blew it!!
its in the wire coming from the + side of the battery too the switch then too the starter!!
Posted on Apr 13, 2009
  • 110 Answers
SOURCE: craftsman riduing tractor turns over but won't
If you have spark and compression, the only thing left is fuel.
Check that fuel is being deluvered to the carb (remove fuel line to carb and make provision to catch ejected fuel. Crank engine. Fuel should be pumped from the tank and out the open line at a good rate.
If this checks out (or there is no pump fitted, but there is fuel issuing from the pipe), check the electrical connector on the bottom of the carb. There should be battery voltage on this conection for the engine to run - if not - that's the problem.
If that checks out, the cut-off solenoid (fed by the connection you just checked) is suspect.
Posted on May 09, 2010
  • 4 Answers
SOURCE: I have massey ferguson 383 tractor that sat for 3
I would check to make sure that you are not getting air into the fuel system. With a tractor sitting that long I would also be concerned with 1. bad fuel, 2. bad fuel injector pump, 3. clogged fuel filter, 4. water in fuel system, 6. intake/exhuast valves siezed. You will just have to start with a process of elimination.
Posted on Aug 19, 2010
daneinwv
  • 124 Answers
SOURCE: I have a 2003 (old) riding mower. Just recently,
My name is Dane and I'll try to help you with your problem.
I think you have a bad coil. A coil will operate fine on initial startup, but go bad after warming up. Get a cheap coil tester from an auto parts store an install it between the spark plug and the plug wire. Be careful on the next step because the engine can start. Turn the engine over and check for a bright light on your tester. If the light is dim or not producing at all, replace the coil. If the engine starts, allow it to run until it dies then recheck. If your coil checks ok, the other possibility is that your float isn't allowing the fuel to enter the carb fast enough to keep up with the demand of the engine. Thus, the engine sits idle, the carb bowl fills and it will run for a while until it goes dry again. This is caused from bad gas and deposits in your carb. You will probably need to remove, disassemble, soak, and use compressed air to blow out the jets in your carb. Pay close attention to how the carb is attached to the engine and disassembled. Make a drawing if you need to or take some pictures. Disassemble the carb as far as possible and put it in the cleaning solution. Do not place rubber parts in the solution. Allow it to soak in cleaner overnight, and then blow out the ports and jets with compressed air before you assemble and reinstall it.
I hope I've helped. If you found this information useful, please leave feedback as deserved. Thanks! Dane
Posted on Dec 03, 2010
Testimonial: "Shocked at the quick (free) response. I think I've found a new link I'd actually use."
B7510 kubota hst 4wd stalled when stood up off seat now wont crank over to restart
What is happening when you try to start the machine? Any noises at all? Have you made certain that you have all safety switches contacted? Make certain that all attachments are turned off.
Feb 06, 2016 | Kubota Garden
My m105s kubota tractor wont start -fuel prolems
Glowplug may bbad or the fuel injectionpump. Chec utube ir git a shopmanual
Dec 27, 2015 | Kubota Garden
Kubota L 4060 wont start full charg battery
Try taking off the cables and shining up the battery terminals and the insides of the cable connectors with a piece of sandpaper and reattach the cables and try to start again. If this doesn't work, next try removing the spark plugs and shine up the spark area (center pin and sparking arm) with your .sandpaper and replace. If still no luck, it could be a fuel issue. You will need to check whether fuel is getting to the cylinders. Remove one spark plug and briefly turn over the engine and then shut it off. Do this very briefly for the sake of safety. If the open cylinder is wet (feel in the open spark plug hole with your little finger), it is getting gas. If it is dry then the fuel is not getting to the cylinder and there is a fuel plug somewhere in the system. This is more difficult to diagnose as it could be a problem with the carburetor, the gas line filter or the gas line may be plugged.
Dec 11, 2014 | Kubota Garden
#1 my kubota gr 2120 diesel lawn tractor wont start in todays minus six degrees even I used the glowplugs. #2 i wanted to push the tractor out of the barn wont budge?
Throw a tarp over the tractor. put electric heater under tarp and warm the tractor up. #2 Most hydrostatics have a release lever that allows them to be moved.
Nov 20, 2014 | Diesel Garden
I recently bought a 1995 kubota m5400 tractor, when i got it it wasnt running. i put a new battery in it and attached the postive and negative wires to it and bam it started right up. i drove it around the...
As it went for a period of time I suspect that the fuel system has a problem. I take it that it is a diesel being a kubota. When diesel sits unused for a period of time gunk grows in the fuel tank. I suspect that this gunk has now blocked the fuel filter or that there is air in the system that has to be bled out. I would also check that the stop solenoid on the fuel pump is working to allow it to start.
Nov 12, 2014 | Cars & Trucks
Find the relay on a kubota
jump starter with battery if starts look for bad ignition switch or battery dosnt have enough amps or bad contact in silinoid you have to buy one to find out
Sep 12, 2014 | Kubota Garden
Kubota tractor got of seat and now won't start
Most seats contain a safety switch.
go online (like I just did) and type in "Kubota tractor seat safety switch" then scroll through the pics to see where the safety switch is. This switch is to prevent one from getting off the tractor while it is operating. DO NOT REMOVE IT. It will only put you and someone who doesn't know it is gone to have an accident maybe a serious one.
Feb 20, 2014 | Motorcycles
Kubota m59 hyd system not strong
Check your hydrolic fluid. If low, be sure there are no leaks. If your fluid is topped off and there are no leaks then your pump may be going bad.
Sep 16, 2013 | Cover My Tractor Tractor Cab-Enclosure for...
I have a kubota bx25 that won't start. it has power to the starter on battery side
you need to have power to the small wire on the starter for it to crank over
Sep 03, 2012 | Woods Kubota Bx 24 Bx 23 Bt610 Bh75 And...
Garden Logo
146 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
