50PF9630A/37 Phillips 52" plasma clicks on, 20 seconds later blinking red light syndrome. No pattern, just on/off. Replaced power supply board. Same thing. What other boards should i replace? Than
Used to be intermittent but now full time red blinking light and black screen.
    Top Expert:
  • Televison & ... Master
  • 74,384 Answers
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. http://electronicshelponline.blogspot.com/
Blinking codes details to many popular brand TVs are given. Surf the site with patience. If blinks continue without any pause, the main board is faulty.
Counting of number of blinks to Philips TVs is entirely different to that of other brand TVs. It is not a direct count procedure. The site have details about how to count the number of LED blinks [Fault Codes] to Philips brand TVs are given; along with details of the faulty circuit location.
Posted on Nov 13, 2014
premtech
  • 934 Answers
SOURCE: Red noise or flicker on bottom half a plasma screen
The old saying that a pictures is worth a thousand words could have been looking at this one... If the lower screen had been streaked in B&W or bands ran completely through the picture Old Drummer I would suspect the logic board also but that's lower y-board failure.
Bill
Posted on Nov 15, 2007
romsky79
  • 822 Answers
SOURCE: Phillips 42pf5321d/37 No picture Error code D3V3
pls. check the power inverter.
Posted on Jun 28, 2009
vinnyq
  • 157 Answers
SOURCE: 6 blinking red lights on my 50 inch phillips plasma.
If you see bad capicators, just replace the ones that appear to be bad. There are many different types of capicators on the power supply and there are different part number for each one. The good thing about capicators is they almost always list the ratings on the capacitor itself.
Check the Voltage rating (V) and the Farad ratings (F, usually μF), you can replace them with any one that has the same ratings. Make sure BOTH of them match the old ratings, you can purchase at just about any electronics store that carries electrical components such as RadioShack.
Posted on Oct 09, 2009
eagle338
  • 4889 Answers
SOURCE: Heard a popping sound unit
10 blinks on this set is not a power supply fault but rather an A-board fault(Main A/V board). Hence replacing power supply would not do the trick. I suggest you return the board and get an A-board for +50$ and I am confident that it will resolve your problem.
Sai.
Posted on Feb 04, 2011
joeguest2
  • 2080 Answers
SOURCE: Doesn't power up. Relay clicks several times,
First of all you should weight the cost benefit of repairing the set versus purchasing a new one.
Depending on the size and model of tv, it may be more prudent to simply cut your losses and buy a new tv rather than spend money swapping out circuit boards in the hopes of repairing a set in questionable condition already. Main / Power Supply / LCD Controller boards will typically run you about $100 each to replace, so weight that against the purchase price of a new tv that comes with a warranty.
Given that, if you are still intent on trying to repair the tv, and it does since you have gone out and acquired a service manual, there are steps you can take.
First of all the service manual should give you some idea what the blink pattern means on the front panel lights. Look that up first.
It does sound power supply board related, but bad capacitors are not always as obvious as the tell-tale bulging or gunk-leaking ones.
Use the manual to find out what voltages you should be getting out of which wires coming off the power supply board. In general, some will be 5VDC, some will be 12VDC, and some will be 24VDC. Test them with a multimeter and see if you are missing any.
Obviously this test requires you to have the unit plugged in and powered up with the safety covers removed. I cannot stress enough the potential dangers involved and if you are not confident with that level of maintenance, I would recommend you leave the live power tests to the trained technicians.
You said you didn't see any bad capacitors, so you may want to just unclip, pull out and then reseat all the multi-wire connector you can get to in case one of them just has a bad connection.
Good luck in the troubleshooting.
If you have any questions or require any further assistance please comment back on this page and I will do my best help you. Please provide the model number of your tv next time as well.
If this was at all helpful, please click on the 4 Thumbs Up rating icon above.
Thank you very much.
Joe.
Posted on Feb 15, 2011
Phillip 50PF9630A/37. I have a red blinking 7 times after a green light. i've allready replaced the 2 bulging cap on the bottom of power supply board and also a cap on the Y board (board on the left)...
Hello sir Jose!!!!
try to unplug the y sustain only and power ON your TV..and see what happen next..
Please reply to this tread for immediate help..
Feb 20, 2012 | Philips Televison & Video
Phillips ambilight TV Flashing red LED light--- ^ long blinks and then 3 short blinks--- picture and sound will not come on---
Check the tv power supply board for those dying parts call copactors.That the board,where the power a/c cord plug into it.These capacitors are alway bulges or puffing up on it tops.U have tools and know basic electronic?Replaced those dying soon to be dead capacitors,will fix the power supply and have stable tv power again and tv will work.Or try website like Ebay.com to buy a whole refurbish power supply board for the replacement.
Nov 23, 2010 | Philips 50PF9731D/37 50 in. Plasma...
No power to my Phillips 42 inch Plasma 42pf7321d/37, just a red blinking light
Most likely it going to be a power supply related problem. The red blinking light is a code for a TV tech to diagnose the problem on the power supply board itself or the board that regulates the power for the screen. Some manufactures call it a Backlight Inverter Board. A TV repair shop should be able to look at it for you and tell you which board is bad.
Replacement boards can be found at a good price at Shopjimmy.com
Sep 05, 2009 | Philips 42PF7320A 42 in. Plasma HDTV
FLASHING POWER RED BUTTON 7 TIMES
I believe that is a bad power supply board. You can unplug set ,open the back access panel and look for swollen electrolytic capacitors they will most likely be slightly rounded on top instead of flat top like the others.Not sure if just replacing caps is enough we mainly swap out whole board.Some models' replacement power supply is slightly different from original in that a couple of the plugs are in different spots and require an extension cable.
the tv dude
Apr 01, 2009 | Sony KDS-R50XBR1 50" HDTV
Phillips Plasma - Model #42PF7320A/37 - 3 flashing red lights
it sounds like you could have a signal board problem they are pretty expensive but there is a web site that sells refurbed parts
Nov 17, 2008 | Philips 42PF7320A 42 in. Plasma HDTV
Philips 42PF7320A blinks 3 times every time i hit the power button
The SSB is small self contained board that u connect your Antenna, and HDMI to. An error three is a communication error between the SSB and to Logic board ( located underneath the SSB on the back fo the plasma panel that is just below the power supply. U can check parts.com and see if u want to purchase a SSB for this TV. Is the 3blinking lights coming from the front of the TV. Also check the power supply and see how many times the green led blinks on the upper left of the power supply and let me know.
Apr 24, 2008 | Philips 42PF7320A 42 in. Plasma HDTV
Phillips 37FD9944/01S Plasma TV - Power Supply
dont waiste your money problem main or logic board or if shure power supply go radio shack and get one with specifications match voltage,ampers,and polarity
Mar 30, 2008 | Philips 60PP9352 60" Rear Projection...
Phillips plasma
Five blinks is a severe hardware failure supplys not working. Viper is down. You have atleast a bad power supply board could have taken out your sustain boards. If you are good with a meter you can measure voltages and see if just your power supply is dead. If you have never handled a multimeter you will need a tech and a power supply is not cheap..Power supply is about a 600 dollar board.
Feb 05, 2008 | Philips 42PF7320A 42 in. Plasma HDTV
Televison & Video Logo
50 people viewed this question
Top Televison & Video Experts
Electro Med Services...
