Any idea if I can reset a Samsung da-e650 docking station, it's only been used a couple of times and stopped working?
  • 39 Answers
Try unplugging it's power cord and usb connection to the laptop. That worked the other day for someone that had that problem
Posted on Nov 25, 2014
The Machine
  • 788 Answers
SOURCE: T41 docking station release?...
Turn the machine off and press the eject button on the dock. If you locked it then you need to turn the key for it to come out. The eject button usually has a picture of an up arrow over a horizontal line.
Posted on Jan 18, 2008
Pyrhyc
  • 2028 Answers
SOURCE: Missing Docking Station key
You will have to take the docking station apart until you can see the locking mechanism. Once you can see the mechanism, you should be able to get a screwdriver ron it and release it. Make sure that it releases, don't force it, and most of all, be patient.
Posted on Jun 28, 2008
  • 3 Answers
SOURCE: How does a USB docking station work w/ a regular docking station
the older pc probably needs a usb 2.0 port to run docking station. the manual on the docking station should tell you. you may need to install a usb 2.0 pci card in your older computer for it to work.
Posted on Mar 18, 2009
brannfenix
  • 81 Answers
SOURCE: T-60 will not seat properly in 2504 docking station.
I have the same docking station and I am typing this on my T60 right now. I have noticed that sometimes it is very hard to dock my laptop and other times it just slides on instantly. This seems to be an issue with poor design. If you look a the dock connector under you laptop you will notice there is a strip of plastic in the middle of two rows of connectors. The docking station connector must be perfectly aligned to successfully connect. I would inspect it for any damages, but honestly I think it is just an issue of patients, precision and a little bit of luck. If you can not identify any damage I would just slowly try to line it up and keep trying until it clicks. Remember to never force it and once it lines up it will slide in with very little force.
Posted on Jul 24, 2009
  • 357 Answers
SOURCE: Dell Latitude 630 docking station USB ports no longer work
Try removing the laptop, unlug the power to the dock and wait a few minutes, then connect the power now put your laptop back on the dock.
I hope this helps.
Have a good day and good luck.
Posted on Nov 20, 2009
My saumsung DA-E750 is an ex display model and is stuck in 'demo mode' any ideas how i can reset this so i can get all features?
Small claims court or contact Samsung customer service to see if they can step you thru the process---usually it is holding certain buttons with unit on to exit the demo mode.
Dec 03, 2012 | Samsung DA-E750 Audio Dock
Dell duo station
I had the same issue. I tried opening the dock and could not find anything wrong. It seems the charger was delivering sufficient voltage. So I disconnected power to the charger and reconnected couple of times and it started working again. My charger has a LED light and based on the brightness of the light you can findout if the output voltage is close to 20 volts.
Sep 20, 2012 | Dell Jbl Inspiron Duo 1090 Audio Station...
My friend plugged his iphone into my docking station and ever since then the sound has stopped working when ever i plug my iphone into it? I tried to find a re-set button but couldn't. Any idea's?
Sometimes the connectors on the dock get bent. Look to see if anything looks out of place. Unplugging the unit is a reset left unlugged for a couple of hours. If you need repairs try esupport.sony.com. Hope this helps.
May 29, 2011 | Sony SRSGU10iP 2Channel Dock speaker...
IPOD works fine;but it,s unresponsive in the Bose docking station/speaker system. Remote has fresh battery. Only used a couple times. Thoughts?
I had the same problem and once I reset the ipod it started working again. Don't know if this will work for you but it worked for me, Hope it helps.
Aug 28, 2010 | Bose SoundDock iPod Digital Music system...
E5500 will not turn on after disconnected from docking station
I just want to know, removing battery and docking station, and just use the ac adapter alone still no power on the laptop? If yes please replace the motherboard.
Mar 31, 2010 | Dell Latitude E5500 Laptop
Bose sound dock - no sound comes through it but my ipod works with the ear plugs so it's not my ipod
I had this problem for the pat two days. Believe it or not I took my Ipod touch of the dock. Shut the power off to the Ipod to reset it. Also the power to the docking station. turned everything back on. Put the Ipod back into the docking station and heard the beep.. and hit play and it was working again. Not sure but shutting Ipod off does act like a reset.
Jul 19, 2009 | Bose SoundDock digital music system...
USB ports in docking station stopped working suddenly
I was having the same problem - the USB ports seemed to have stopped working so I could not use the mouse, keyboard, or printer, even though the monitors and power could still operate through the docking station. Finally, I just unplugged the docking station for 30 seconds, plugged it back in, and everything resumed working. I was surprised it was that simple, but it's working for the moment.
Aug 27, 2008 | IBM (250410U) Docking Station for ThinkPad
Computers & Internet Logo
David Payne
David Payne
