Question about Lorex Sg19ld804161 19 Inch Lcd Observation System
How do I pair up cameras when 4 out of 8 go out
Had 8 cameras working only 4 out of 8 say no signal with blue screen
  • 2,760 Answers
NEED TO CHECK THE POWER SUPPLY THAT FEEDS THOSE FOUR CAMMERA'S
Posted on Dec 05, 2014
Back up camera on 2012 f150 4x4
The blue screen indicates no signal from the back up camera.
Apr 04, 2017 | 2012 Ford F-150
Cable for hikvision camera DS-2CE56D5T is cut. I m open camera and find 5 wires: white,black,red,green, yellow and blue. Which wires is power, signal...
four power wires, used mainly in CCTV installations. The cable may power distant cameras (each two wires can be connected in parallel), or be used for cameras equipped with audio module (one pair can power the camera, second - transmit audio).
Aug 03, 2016 | Miscellaneous
Disable the blue "No signal" screen from showing up?
There is no Blue screen disable option on the camera.
Since the blue screen caused by the video heads, try to clean it up by running a cleaning cassette.
The cleaning cassette helps only for minor clogs of the Drum(video heads)
Jan 18, 2015 | Sony Handycam CCD-TRV608 Camcorder
Need to pair my udr444 cameras to my pc
Most security cameras put out an analog signal....whereas PCs need a digital signal. It may work if you find a program to convert the analog signal to digital. If I were you I would just buy a small flat screen tv and use the Audio/Video input.
Mar 20, 2014 | Uniden UDR444 Video Survailance System;...
Monitor says no signal, no picture or sound
Step 1: Move the Monitor to the same area as the CAMERA. With
the Monitor on, press the Menu button on front of Monitor and using
the Scroll button move down to the "ADD/DEL CAM" option. Press the
Scroll button to select "ADD/CAMERA".
Step 2: At the same time press and hold the scroll button on the
monitor and the pairing button on the CAMERA for at least 5
seconds. Then release.
Step 3: You should then see a picture from the CAMERA on the
Monitor.
Step 4: If this is unsuccessful, you will see the message "OUT OF
RANGE" on the Monitor screen and should repeat steps above
making sure the CAMERA and Monitor are close enough to each
other for pairing.
Jan 11, 2013 | Summer Infant Baby Care
Getting a blue screen from rear view camera, worked fine until today
Blue screen is generally no signal from camera, possibly broken camera feed wiring or bad connection, if the camera is on a tailgate, breaks occur where the wiring leaves the tailgate to th car body, good luck.
Aug 27, 2012 | Car Audio & Video
My blueantz9 v3.1 does not want to pair up with my motorolai1 what do i do
It should pair. Both are comparable. First turn your Blue Tooth on and then follow these steps -
  1. Press the "find it"
  2. Now press "settings"
  3. Now press "wireless controls"
  4. Now press "blue tooth settings"
  5. Now press the "box" next to the word Blue Tooth to scan for a signal from your Ant
  6. Now look at the bottom of the screen and wait for it to find the Ant Blue Tooth
  7. When it find the signal then press "touch to connect"
If your Ant is still not pairing then either the phone of the Ant is malfunctioning.
regards, Tony
Apr 15, 2011 | Blueant Z9 Wireless Headset
Wireing
3-pair version of (red/green, black/yellow, white/blue). But the first two pairs are not twisted
So it becomes green/red, yellow/black, & white-black/blue. G1/ R2 /3Y /4B /5*Blk/6Blue (this is what you physically see on the other RJ11 connections since this is a data connection and not a phone connection it should be a straight-through instead of cross-over connection.
These RJ 11 PINOUT assignments may be incorrect because they apply to a color camera instead of B/W
1 SPEAKER (+)
2 VIDEO_OUT
3 GND
4 SPEAKER (-)
5 AUDIO_OUT/ALARM_OUT
6 12V DC
Back of Camera
Clip up, contacts down
123456
RJ11-e starts off like a RJ45 Stranded Patch Cable.
The color code used in stranded patch cables is different from solid-conductor cables. For NorTel Digital Patch Cable (DPC), the coding is; Pair 1: Green & RedPair 2: Yellow & BlackPair 3: Blue & *Orange White\Black
*In Pair 3 the color coding is Blue & Black instead of Blue & Orange and the pair is twisted so that the Blue wire is the 6th pin instead of the 5th pin.
Jun 27, 2009 | Samsung Weather Resistant Security Camera...
Wireless speakers not communicating to Receiver
Speakers have a unique RF frequency that needs to pair with the receiver (kind of like a blue tooth headset with a cell phone). At times, the signal may reset, so, you may have to go through the initial pairing sequence. Try this:
1. Unplug rear speakers
2. Make sure the sound signal connector is plugged in to the back of the system properly.
3. Press and hold the ID button for 3 seconds until the blue LED light flickers.
4. Connect the power chord to the rear speakers.
May 03, 2009 | NexxTech DP3222 DVD Player
Lorex Sg19ld804161 19 Inch Lcd Observation System Logo
89 people viewed this question
Top Lorex Home Security Experts
Henry  Thomas
Henry Thomas
Lawrence Oravetz
Are you a Lorex Home Security Expert? Answer questions, earn points and help others
