Question about Home
What areas of the Regency wood stove do I clean so that the fan blows stronger?
    Legend:
    An expert who has written 200 answers of more than 400 characters.
  • 484 Answers
Many times, the fan blades themselves are the cause of lowered air flow. Think of the blades edges as though they were the cutting edges of a knife. You know a sharp knife cuts its products better than a dull knife....transfer that concept to airflow. A clean blade is sharper and slices through the air much better than a thick edged dirty and dull fan blade. I've seen extreme cases where the edges were 1/8" thick and the area between the blades nearly filled with lint, dust, dog hair and the like.
Service the blower blade first and while removed inspect the inside of the stove in front of the fan with a flashlight and small mirror. That will tell you if additional cleaning is required. If your motor is a cheap little 'shaded pole' motor, it could just be dragging and operating at a lower rpm than designed, delivering less airflow. If so, it may have to be replaced. There are no oil ports on most of these small motors.
Posted on Dec 12, 2014
Does anyone have any information on the Pine Ridge 500 wood stove? I'd like to know who the manufacturer is and what the EPA specs are.
PDF]installation and operation manual - Wood Pellet Stoves ...
www.pelletking.com/...stove-manuals/whitfield-advantage-iit-pellet-stove...
Services) and the listing mark is Warnock Hersey. Testing: In accordance ... The assembled pellet stove model Advantage II-T C FS and. Advantage II-T C INS ...
[PDF]INSTRUCTION MANUAL - Ignite Dealer Portal - Regency ...
manuals.regency-fire.com/getattachment/.../R12-R14-R16-Manual.aspx
Tested by Warnock Hersey ... LISTED FACTORY BUILT FIREPLACE ACCESSORY HEARTH STOVE ... it is important that you read this manual throughout.
Nov 01, 2015 | Home
Where is model number located on regency wood stove
Hi chery;
There should be a plate or decal on the back of the stove.
It will have the make, model, serial #, and clearances required from combustibles.
Oct 24, 2015 | Home
How is air supply regulated in wood burning stoves?
To regulate air flow, there are damper devices built into the stove, flue and stove pipes. Keeping the air flowing correctly through a wood-burning stove is essential for safe and efficient operation of the stove. Fresh air needs to enter the wood compartment to provide oxygen fuel for the fire; as the fire burns, the smoke must be allowed to rise through the stove pipes, and exit through the chimney.
May 07, 2013 | Home
I need a regency woodstove model r6 owners manual
I just sent Regency's a request for the same manual via their site but haven't recieved it yet. You could try the same or email me at rogerthibaudeau@hotmail.com and I'll forward whatever they send me. Here's the link :
http://www.regency-fire.com/Company/Contact-Us.aspx
Have a good one... Roger (Wood\gas stove and fireplace installer)
Oct 13, 2011 | Cars & Trucks
I need the new hole cover for my wood stove
Look in your areas phone book for wood stove speciality stores . Also you might want to put an add in a local paper stating what you are looking for. Rural antique stores might also be a solution.
Mar 10, 2011 | Stoves Heating & Cooling
We do not seem to be getting as much heat from the stove this year as last year. The stove makes a loud clanking sound when it heats up and cools down. It is a regency wood stove Model R3/R9/RA3. There...
That stove has a metal baffle on top of an air tube that can warp with age. It might be changing shape as it heats up and making your sound. If this is the case it can block the path for the stove pipe and cause performance issues. The baffle plate and insulating blanket on top can be easily replaced.
Dec 07, 2010 | Stoves Heating & Cooling
We have a pellet stove -seems to be working ok except that we have a smell of smoke like that of having a fireplace. We think everything is sealed correctly. Any suggestions?
From what I have read on these things, never had one, but they have 2 fans, maybe one, plus an auger and thermostat. The one fan would **** fresh air in from the room to fuel the fire, while the other fan would blow the heat back out from a sealed area. The auger spins constantly, slow, dropping pellets on the fire determined by the thermostat. If this is right and relates to your stove, I can see where the smell of smoke would come from. The second fan is pulling in smoke from the fire. Check the gaskets in that area. I was wondering if it wasn't just the new stove smell you were getting?
Feb 23, 2010 | Napoleon Auburn Pellet Stove Heater
I have a regency wood stove, and when i push the damper in to low it acts like it isn't on low. it is still sucking air
the damper may have to be operated manually back and forth to free up any obstructions between the rod and the flu pipe
Nov 26, 2009 | Heating & Cooling
I need to wire a 24 volt double pole double throw relay to operate a fan in a furnace parrell with a wood stove.
Your problem has really got me interested in what you are attempting to do. So are you looking to diable the FAU while the wood stove is heating or activate the blower motor for the FAU when the wood stove is hot?
Oct 30, 2009 | Goodman GMS90703BXA Heater
Home Logo
73 people viewed this question
Top Home Experts
Donni Steen
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
