Question about Garden
M9960 kubota tractor pto wont engage. Dash reads error code 11 please help and what does error code 11 mean
  • 32 Answers
This could be a low voltage problem. Check the voltage output with a volt ohm meter at the stator output.
Posted on Nov 26, 2014
Kubota zd28 mower was running fine put away but now PTO wont engage.
if your saying that pto wont do anything , that's either an electrical short or a broken belt , in rare cases the clutches go too , now if your saying the pto engauges and stalls the engine or makes horrible noises , then that's a bearing , im betting the deck shaft bearings are in need of some serious grease work
Mar 04, 2017 | Kubota Garden
I have a kubota 9000 tractor, when I engage the pto the tractor dies
You may have a faulty safety switch in the seat.
Oct 08, 2016 | Kubota Garden
PTO lever engages in the wrong position in a Kubota ZD323.
Check and make sure that any links are not bent and make sure that the switch that engages the PTO is not out of adjustment.
Jul 14, 2016 | Kubota Garden
I have a kabota tractor and the Pto will not engage on the bush hog
pto is on the tractor, not on the bush hog, if it won't engage you have pto problems on tractor, needs to be serviced
Dec 01, 2015 | Kubota T1600H Mower tractor
Kubota F3680 stalls when PTO is engaged
there is not enof power so olter the tick over
Jun 28, 2015 | Kubota Garden
Kubota L 3300 rear PTO will not engage when very cold weather solution please
Try using a lighter gear oil - some oils are thicker in really cold temps - like molasses while its warm drain it and use a lighter grade, - check the manual and go with a thinner type - ask local car parts store. sometimes the manual will give a type for colder weather. Good luck
Nov 30, 2014 | Kubota Garden
Pto onmy kubota zero trun zg 23 wont work
Check to make sure you are getting power on both sides of the switch. Check the connectors going to electromagnetic engagement PTO unit. This is mounted right on the base of engine. Check ground wire coming from unit to make sure you have agod grounfd connection.
Feb 27, 2014 | Kubota Garden
I have a Kubota TG1860 G riding mower. the blades have stopped engaging. I have replaced the push/pull switch, didn't work. It clicks like it wants to work but doesn't engage. What else can I do?
belts,solenoid,ignition switch and the PTO, you can hook 12v directly to PTO and see if it is engaging, the ignition switch feeds 12v to the PTO, the switch/solenoid engages with the help of the pulleys and belts, just a matter of figuring if its the belts(or in may cases the tesioner pulley) Hope this helped Tim
Apr 18, 2011 | Garden
Garden Logo
278 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
