Question about Kodak EasyShare DX7590 Digital Camera
How do i remove the battery cover from my kodak easy share dv7590
    Master:
  • 876 Answers
From this manual:
http://www.imaging-resource.com/PRODS/DX7590/DX75A.HTM
is the following statement:
On the bottom panel of the DX7590 are the metal tripod mount (kudos for the use of metal here), dock jack, and battery compartment. The threaded tripod mount is a little off-center and too close to the battery compartment for quick battery changes while working with a tripod. The battery compartment features a locking, hinged door, which slides to the side to open under spring pressure.
Posted on Nov 14, 2014
SOURCE: About battery door broken in Kodak CX7330
I've got 16 of these cameras and had to replace the door on 3 of them. (I'm a teacher)
it is quite simple, but there are little tiny screws and some dexterity required!
to replace the battery door, you need a super small screwdriver (I've used both an eyeglass size and the screwdriver that came with my son's tech deck!) . you'll have to unscrew all of the small screws that hold on the back of the camera. remember which screws go to which hole - because some are longer than others. once the screws are out, you'll have to gently pry off the cover. carefully - you dont want to crack the camera case. you'll also want to be careful not to touch the sensor, which will be exposed with the case off.
NEXT you;ll have to pry the little spring out of the battery door to actually remove the old door. you'll probably have to use a screw driver to pull the spring on the new door back enough to fit back into the holes. that's really all there is to it. replace the cover and the screws.
Posted on Mar 27, 2009
BillB-SA
  • 2761 Answers
SOURCE: Kodak Easy Share V1003 camera is frozen. Turned
Your fix could be as simple as cleaning the camera's battery contacts, or it could be something more serious and expensive. Before you pay for expensive repairs that you may or may not need, check the Kodak Help Center by clicking on the link below. It uses a simple Q&A format to diagnose problems and propose solutions.
http://www.kodak.com/global/en/service/repair/troubleshooting/troubleshooting.jhtml?pq-path=6198
Posted on Aug 03, 2009
SOURCE: kodak easy share v1003 with broken lcd how i can fix this cheap
Sirs I have a Kodak easy share v1003 showing the screen completely white. How can I replace it... seems that I already find the spare part in e-bay. Can I do this replacement by mayself?
Posted on Jan 19, 2010
SOURCE: Kodak Easy share C182 Digital Camera
Please check that you have putted kodak alkaline batteries.
Posted on Apr 12, 2010
  • 141 Answers
SOURCE: Is the kodak easy share c180 digital camera webcam?
I won't say the camera is usable as a webcam because you will definitely severly shorten the life of the camera by using it as such. Firstly the camera is designed to take photos and short videos, NOT being left on continuously for use as a webcam. The heat generated by doing so could damage the delicate CCD (the part which collects light from the lens and converts it into electrical signals) Secondly most cameras are deigned to switch themselves off after a certain period of non use. Not handy for webcams.
Next there's the power issue. Unless you are using an external power supply for the camera you will be forever replacing batteries and for what an external power supply costs you could buy a proper made for the job USB powered WebCam complete with focus and sometimes zoom.
Next there's the mounting issue. Where will you mount the camera to give a well lit and steady picture of your face. Definitely not on top of the monitor due to extra heat generated by the monitor itself. Mix that with camera's heat and hello, and too soon, goodbye camera.
Webcams cost $20 if ou shop around maybe cheaper. OK your cmera will give a better picture but at the distance you're talking it won't matter. Plus you will need software to generate the webcam picture. MSN is a good webcam program. Plus depending on the output of the camera, usually only video. You may need a video capture card for your computer. The camera will give you a full screen image of what it's pointed at but you need a box to put a smaller picture in on the screen otherwise all you will see is one big face, yours.
So do you really want to wear your camera out prematurely simply because you can't afford a $20 webcam. The made for the job unit is cheap, will stay on all day and the power comes from the USB port. Everything you need and cheap. I think you know which way to go.
Good luck
Posted on Apr 22, 2010
Kodak easy share is frozen on the Easy share page
Remove the battery and the memory card, and disconnect from computer, now push power and hold for at least 60 seconds to reset the processor ic, install memory card and battery, turn on camera settings should return to normal, if not! the systems control board is the problem.
Apr 16, 2012 | Cameras
Needhelp with installation of Kodak easyshare on 7.0 system
This is the instructions on how to remove existing ESS system in order for you to start on a fresh.
Please follow the instructions:
  1. Uninstall Easy Share software:
  2. Select Start > Settings > Control Panel > Add / Remove Programs.
    For Windows XP operating systems, select Start > Control Panel > Add / Remove Programs.
  3. Select Kodak Easy Share software.
  4. Select Remove (or select Change, and then select Remove).
  5. Run the Clear utility:
  6. Visit the CLEAR Utility for Kodak Easy Share software Web page at www.kodak.com/go/clear
  7. Click the Download button, and then follow the on-screen prompts.
  8. After restarting your computer, visit the Kodak Easy Share software Web page at www.kodak.com/go/easysharesw and install the latest version of Easy Share software.
Feb 08, 2010 | Kodak EasyShare C160 Digital Camera
Can not email picture from easyshare camera
It is not possible to email directly from the camera.
If you're experiencing emailing difficulties directly from the Easy Share Software:
Please do a Clean Install on the software:
Jan 19, 2010 | Kodak EasyShare One Digital Camera
MY COMPUTER CRASHES EVERY TIME I TRY TO UPLOAD PICS AND THEY WANT UPLOAD HELP THIS HAS SHORT VIDEO CLIPS AS WELL IT WILL GO THROUGH THE PROCESS OF SEEING IF THERE ARE DUPLICATES AND AFTER THAT IT ACTS LIKE...
Please reinstall your version of Easy Share software:
Jan 12, 2010 | Kodak Easyshare C813 Digital Camera
All of a sudden my Kodak Easyshare 530 will not transfer pictures to my computer, I have reinstalled software, still does not transfer. Can you help me?
Possible solutions:
Remember you need to turn the camera on when transferring.
Try a different USB outlet
Try a different cable
Try a different computer.
If all fails please contact KODAK in order to arrange a repair or order a new cable. Remember your USB cable is covered under the same warranty as your camera, so remember your serial number when calling:
http://www.kodak.com/eknec/PageQuerier.jhtml?pq-path=14563&pq-locale=en_US&_requestid=3490
If you suspect it could be directly related to your software.
You need to follow the instructions:
Jan 10, 2010 | Kodak EasyShare C315 Digital Camera
Recieved Kodak Z915 for Xmas. Follow directions
  8. After restarting your computer, visit the Kodak Easy Share software Web page at http://www.kodak.com/global/mul/service/downloads/DownloadLookup.jhtml?pq-path=15222/15223&product=EKN036302 and install the latest version of Easy Share software.
Jan 06, 2010 | Kodak EasyShare Z915 Digital Camera
I have a Easy Share C530 and I have Visa the two programs are not working together
You need to upgrade your version to be compatible with Windows Vista: Please do a Clean Install on the software:
Dec 21, 2009 | Kodak EasyShare One Digital Camera
Can't get easyshare to start download
If this fault message is on your computer starting Easy Share Software: Please do a Clean Install on the software:
    1. Select Start > Settings > Control Panel > Add / Remove Programs.
    2. Select Kodak Easy Share software.
    3. Select Remove (or select Change, and then select Remove).
  2. Run the Clear utility:
    1. Visit the CLEAR Utility for Kodak Easy Share software Web page at www.kodak.com/go/clear
    2. Click the Download button, and then follow the on-screen prompts.
  3. After restarting your computer, visit the Kodak Easy Share software Web page at www.kodak.com/go/easysharesw and install the latest version of Easy Share software.
Dec 16, 2009 | Kodak EasyShare V1003 Digital Camera
Device driver was not successfully installed. Why?
I?m not sure if you?re fault code is showing on the computer, Easy Share Software, or the camera itself. Therefor I will list 2 possible solutions: If the fault message is on the LCD on the camera: There is no firmware available online for this camera model. Therefor you do need to set up a "repair" with KODAK directly. An Out of Warranty repair for this model for this fault is about 88 pounds + shipping. KODAK also offers a Trade up option where you will have the opportunity to trade up to a newer model 25-30% cheaper than the market price. In order to arrange your repair/Trade up: Contact KODAK: http://www.kodak.com/eknec/PageQuerier.jhtml?pq-path=14563&pq-locale=en_US&_requestid=3490 If this fault message is on your computer, Easy Share Software: Please do a Clean Install on the software: Please follow the instructions: Uninstall Easy Share software: Select Start > Settings > Control Panel > Add / Remove Programs. For Windows XP operating systems, select Start > Control Panel > Add / Remove Programs. Select Kodak Easy Share software. Select Remove (or select Change, and then select Remove). Run the Clear utility: Visit the CLEAR Utility for Kodak Easy Share software Web page at www.kodak.com/go/clear Click the Download button, and then follow the on-screen prompts. After restarting your computer, visit the Kodak Easy Share software Web page at www.kodak.com/go/easysharesw and install the latest version of Easy Share software.
Dec 06, 2009 | Kodak EasyShare V1073 Digital Camera
I have a Kodak Easy Share Camera C340 and the Battery Cover won't close due to the latches are broke. Is there any place where I can send it to be fixed or isn't this possible??
there are service to centres across the country...you can take your cam to repair it.but it may be expensive..google search for service centres nearest to your location
May 22, 2009 | Kodak EasyShare C340 Digital Camera
Kodak EasyShare DX7590 Digital Camera Logo
63 people viewed this question
Top Kodak Cameras Experts
Tony
Are you a Kodak Camera Expert? Answer questions, earn points and help others
