I'm lock out of my Dell 3yvw9t1-1d3b please can you help me I need to finish my work
    Scholar:
  • 175 Answers
I am not sure if you mean you can't login because you forgat password if so look at this link http://null-byte.wonderhowto.com/how-to/recover-passwords-for-windows-pcs-using-ophcrack-0135358/
otherwise explain what you mean
Posted on Nov 17, 2014
Began to beep in intervals. Changed batteries and it worked a couple of times then beeped twice then touchpad will not work, Five minutes later it beeped steadily for 10 seconds than stopped. Will not...
Why is my Powerbolt 1000 unit beeping?
This is the relevant excerpt from the Powerbolt programming and troubleshooting instructions:
"To determine why your lock is beeping abnormally, please follow these steps:
Take out batteries and unplug powerstrip.
Let it sit for 1 minute, then put the batteries back in and wait another minute.
If it does not beep, the keypad needs to be replaced (17733-1).
If the unit continues to beep, the powerboard needs to be replaced (A17734-3,3 Powerboard 1470 brass finish; A17734-3,26D Powerboard 1470 satin chrome finish; A17734-3,5 Powerboard 1470 antique brass finish)."
Since you've already gone through the battery change, try the battery remove-reinstall recommended above. If that doesn't work for you it suggests that you need to replace the appropriate Powerboard for your lock.
So this is the link to Weiser Customer Support Page, where you will find the appropriate number of your location:
http://www.weiserlock.com/en/CustomerService/ProductSupport/SupportContact.aspx
I suggest calling the appropriate toll-free number and having a conversation with a representative about this problem. You will want confirm that you need the part before you go through the expense, and that it's worth it. You will need to know the "finish" of your lock. Try to talk them into warrantying the part, in spite of the age (one year warranty on electronics), as a matter of good customer relations. They will help you get the correct part on order.
Good luck--and please provide feedback if this helps!
Sep 22, 2011 | Weiser Lock Powerbolt 1000 Lock
Ked pad dont work gives a long beep if i try for a while
Navigate to the complete page that I cut this from can be found by cutting and pasting this link into your browser search bar:
http://www.weiserlock.com/Support/Faq/50160000000HhhZAAS.aspx
Then go to: US & International/FAQ Categories/Keyless Entry/Powerbolt 1000/Search Results/ How do I troubleshoot my Powerbolt 1000?
I suggest calling the appropriate toll-free number and having a conversation with a representative about this problem, first of all to confirm that you need the part before you go through the expense. Secondly, your lock may be new enough for you to talk them into warrantying it, and thirdly, they will be able to get the correct part on order for you.
Aug 28, 2011 | Weiser Lock Powerbolt 1000 Lock
My pwerbolt is about 3 years old and has stopped working. I changed batteries and it worked about three times and does not respond when pressing the "lock" button or unlock when locking...
Aug 23, 2011 | Weiser Lock POWERBOLT ELEC DEADBOLT
How long should I expect my lock to last? It is app. 3 years old will only lock & unlock app. 3 or 4 times then dies when the batteries are replaced... The batteries still have a full charge.when...
Aug 15, 2011 | Weiser Lock Powerbolt 1000 Lock
My lock works for awhile then stops. The beeps sound all the time, then stops locking & unlocking using the keypad. Then a day or two it works again.
Here's a link to the Powerbolt 1000 frequently Asked Questions page:
You will find this answer on that page:
  1. Take out batteries and unplug powerstrip.
  2. Let it sit for 1 minute, then put the batteries back in and wait another minute.
  3. If it does not beep, the keypad needs to be replaced (17733-1).
  4. If the unit continues to beep, the powerboard needs to be replaced (A17734-3,3 Powerboard 1470 brass finish; A17734-3,26D Powerboard 1470 satin chrome finish; A17734-3,5 Powerboard 1470 antique brass finish).
Feb 10, 2011 | Weiser Lock Powerbolt 1000 Lock
Even after i replace the batteries, the unit keeps beeping and then the keypad stops working
Dec 31, 2010 | Weiser Lock Powerbolt 1000 Lock
Locks up and screen freezes. Will work after I push on it.
I think 6 flashes means memory issue. You might want to try and remove and re-insert the memory. Usually found underneath in a compartment held in with 1 screw. If this don't work, I would try and purchase new memory. This would be the cheapest and first thing to eliminate.
Mar 12, 2009 | Dell Latitude D600 Notebook
Touchpad on my 8200 insprion stop working
Try to test it using 32 bit diagnostic
tap F12 (just after Dell Splash Screen)
select Diagnostic partition
wait for test to finish
select Custom test (may need to use TAB and ENTER)
select pointing device
if it work here, it is likely a driver issues - got to support.dell.com and download latest pointer drivers (Alps under Input Devices?) You may as well do this first since it is easier than testing see http://support.dell.com/support/downloads/driverslist.aspx?c=us&cs=22&l=en&s=dfh&os=WW1&osl=en&catid=&impid=&SystemID=INS_PNT_P4_8200
If it does not work her, you'll need to pop it open and see if cables are tight, if they are the touchpad is broken and you'll need a replacement palmrest (included the palmrest)
see the manual at support.dell.com for info on disassembling your model if required.
Feb 02, 2009 | Dell Inspiron 8200 Notebook
Computers & Internet Logo
35 people viewed this question
David Payne
David Payne
