Drum wont turn even by hand
Wf407anw/xaa
  • 25 Answers
May be a bad bearing
Posted on Nov 26, 2014
2 Suggested Answers
chrispolkele
  • 4342 Answers
Our people make the difference
    Verified Fixya Pro
    SOURCE: drum wont turn but the moter does
    Hello Deanna - This particular issue could be caused by a variety of reasons. I would suggest trying the following steps:
    1) Verify a circuit breaker isn't tripped
    2) Advance the timer control dial slowly 360 degrees-
    If the washer starts spinning, then that means the motor and drive belt are fine but that there is something wrong with either the timer control dial or the agitator solenoid. Call in a professional for this.
    If the washer doesn't budge, then verify that the drive belt(s) is attached and not broken by removing the back panel. If the belt is broken, replace it. If it is loose, then tighten it by loosening up the bolt holding the motor and moving it on its swingarm (much like a car alternator) until there is a 1/2 to 3/4 inch deflection in the belt.
    Some washers use reversing motors. It's possible the motor works on the spin cycle but not on the wash cycle. If so, call a pro.
    3) Visually inspect the lid safety switch- Is it loose or cracked? If so, the washer might work intermittently, stopping at different cycles.
    4) Check motor and drive belt- Remove the main access panel (usually in the back). Is the motor spinning, but the drive belt isn't? If so, then you have a drive belt problem.
    Posted on Oct 03, 2012
    Samsung Dryer Model DV419AEW /XAA Dryer will not
    I doubt its the main board. Try seeing if the drum is tight and seeing if the belt broke by spinning it by hand. If the drum is real sloppy and you can't feel motor tension, you need a belt. I would rule out the mainboard until last because the belt is like 89 cents.
    http://www.amazon.com/341241-Whirlpool-Kenmore-Dryer-Belt/dp/B00064NH6E
    http://www.youtube.com/watch?v=zNATJ8qyqP4
    Sep 27, 2013 | Samsung Clothes Dryer Control Panel Main...
    Samsung dv419aew/xaa turns on but drum does not turn, Belt is good and drum retates easy by hand
    Can you hear the motor running at all? Do you feel any heat?
    Jan 28, 2013 | Dryers
    Samsung DV210AGW/XAA Dryer, drum wont turn nor heat up
    hi all, thanks for your comments. to note, it's my dryer not my washer so the suggested solutions wont work. Also, forgot to note, the unit is only 14 months old and just out of warranty. What I've done so far:
    - vacuumed the filter
    - striped the dryer, meaning removed top. front and small exhaust panel in the back
    - vacuumed everything
    - checked the belt, tight, not loose, broken or off the roles
    - child safty not enguaged, toggled it anyway to be safe
    - the checked micro switch next to belt by motor, not engaged
    put it all back, turned on with nothing, tried every setting in auto and manual tied high to low temps and times, the time is noted, such as 40 min, but does not time down, over time, the unit sound the I'm done tone, if left as is, continues to chime then end like it did something. all along, the drum never rotated nor did it heat up.
    Does one impact the other, such as if the drum does not roll then the heater wont start or vise-a-versa. Could the control panel have taken a hit or are there sensors that might have shut down to prevent the unit from starting are there fuse's that I didn't see that might have been tripped.
    Jan 04, 2013 | Samsung Washing Machines
    Put new belt on dryer but it wont turn and i can smell burning and the drum wont turn
    sounds like the belt may be bound somewhere, I would take it back apart and see if I can turn everything by hand. If everything turns freely then I would reinsert drum, hook belt up and see it I could turn the drum with my hands, it will turn but not to freely. Hope this helped tim
    Sep 19, 2010 | Dryers
    We just purchased a new Samsung Dryer model #DV218AEB/XAA the lights will come on but when you attempt to start the dryer there is a hum, the dryer does not spin, then the hum goes away after a few...
    Could be a couple things causing this problem. If you can turn the durm by hand without much resistance then the belt may be too loose. This could be because the spring on the tension pully came off or the belt streached. The humming you hear is the motor spinning. If you cannot turn the drum by hand then something could be stuck between the drum and the frame of the dryer.
    I would also check that the dryer is wired correctly, because low voltage could be causing the motor to hum but not turn.
    Dec 23, 2009 | Samsung DV218AEW Electric Dryer
    TUB WON'T MOVE , EVEN BY HAND
    TAKE THE BACK COVER OFF, EITHER THE MOTOR IS SEIZED UP OR THERE ARE SOME CLOTHES STUCK BEHIND THE DRUM
    May 29, 2009 | Washing Machines
    Dryer will not move but power good
    Motor If the dryer motor only hums when you press the Start button, the motor may be burned out. Here's how to test the dryer motor:
    • Remove the belt.
    • Check for obstructions in the blower fan housing.
    • Manually rotate the shaft of the motor.
    If the motor is very stiff, or impossible to rotate manually, and the blower fan housing is clear, you need to replace the motor.
    If the motor rotates freely, run the motor momentarily with the belt removed and the blower in place. If the motor runs fine with the belt removed, there may be a problem with the idler pulley or the clothes drum. Try to rotate the drum by hand. If it is very difficult to move, correct any problem with the rollers or pulley, and then reassemble the dryer and try it again.
    If the motor hums but doesn't rotate on its own even with the belt removed--yet you can turn it freely by hand--you usually need to replace the motor or the motor start capacitor.
    Oct 05, 2008 | Samsung 7.3 Cu. Ft. Super Capacity...
    Zanussi washing machine drum will not go round at all
    Tracy
    The bearing may have siezed or you have something jammed between the drum and outercasing
    Mar 23, 2008 | Washing Machines
    Maytag performa pye/g2200,3200
    when you say the drum wont spin even manually. Do you mean the drum is too stiff to turn by hand? If so the bearings may have seized up solid. If the drum is free to turn by hand, the pump may be blocked, or burned out & not allowing the water out. If so the circiut wont allow the machine to spin. If thats the case, unblock or replace the pump
    Oct 20, 2007 | Maytag PAV2300 Top Load Washer
    Washing Machines Logo
    Top Washing Machines Experts
    Gerry Harvey
    Gerry Harvey
