Question about Cuisinart DLC-5 Food Processor
It seems that the plastic rod on the back of the bowl does not go down to engage the button on the base
    Problem Solver:
  • 10 Answers
The rod might be broken or the spring is not working (in the wrong position)
You should be able to get the part on line or at a local kitchen equipment store
Posted on Nov 26, 2014
I have used my magimix only three times since purchasing it in May. Today it will not work? I think there is something wrong with the motor, can this be?
Almost certainly the bowl and lid at not locked in the correct place. There is a button in the base and a rod in the handle that is pressed by a wedge on the lid. That presses the safety interlock button down into the base section. I have fallen foul of this and I am a professional chef :>)
Jun 23, 2018 | Magimix Food Processors
Magimix 4200 xl won't turn on
Check that the bit on the lid that activates the switch pushing mechanism in the bowl is working properly.
Aug 27, 2014 | Magimix Food Processors
Why Cuisinart mixer will not start?
All Cuisnarts have an interlock rod built in to the bowl assembly.
Make sure the bowl is positioned on the motor base correctly, and the actuator in the lid that pushes the interlock rod down is not bromen or damaged. If it is intact and working correctly, then check the switch it pushes on, or the main power switch.
May 20, 2014 | Cuisinart DFP-11 Deluxe Food Processor
Won't start
Make sure the work bowl handle is locked in place so that it is facing the front of the processor (same side as the on and off switches).
Make sure the feed tube of the lid is facing toward the back of the processor and that the plastic or metal rod of the pusher sleeve is facing the back of the processor.
Note: this assembly only applies to the Cuisinart DFP-14 series - every Cuisinart has a slightly different assembly for it to turn on.
Sep 13, 2009 | Cuisinart DFP-14BC Custom Food Processor
My braun 3210 food processor will not work with the large bowl and sharp blade. Will work with the blender/chopper but large bowl the on/off switch cannot be moved. All of the contacts seem lined up - very...
I had a similar problem. Part of the lid had a small piece of plastic chipped away. It was the part of the lid that rotates and locks into the machine base. If the lid is missing a small piece of plastic on where it connects to the base, the machine will not switch on. You can compare the lid for the food processor to the mixing lid and see if the piece that juts into the base is broken at all. If it is order a new lid. There are several online places that still carry them; or try a local parts store.
Aug 20, 2009 | Braun Food Processors
I have all pieces locked into place and it will not work! I have the prep 11 plus
First thing to do is check your base to make sure it's not something wrong there. If you take everything off the base and look on top, either in the 6 or 12 o' clock position there will be a black button set into the base slightly. You want to find a ball point pen, and with the base plugged in, press and hold that button while turning on the unit.
If that works, you want to go through each piece one at a time. First w/ the work bowl, and notice there is a plastic rod w/ a spring at the bottom set into on side of the work bowl. Make sure that is lined up over the black button. Then in the cover, usually on the back of the feed tube, there is a lever within the clear plastic, that should line up over the rod in the work bowl. Finally, you must add the pusher/sleeve portion at the very last, or else it all won't engage right and it won't work. Just make sure the tabs on the large pusher are locked into the cover last, and it all engages so that the spring in the work bowl is depressed. The processor won't work until all the pieces are in the exact place and put on one at a time (I can't stress that enough because these processors are very exact when it comes to that, some kind of safety mechanism).
If all else fails, call customer service at 800-726-0190, they can walk you through those steps if I haven't been clear enough. :)
Aug 06, 2009 | Cuisinart DLC-8S Pro Custom Food Processor
KitchenAid Food Processor 770 won't run
I am assuming the unit is getting power. The "power" LED should be lit up on the front of the unit.
The Kitchenaid food processors have a few safety features implimented. If the unit is not assembled properly, this may prevent the unit from turning on. Proper assembly is below:
If it isn't all ready, please disassemble the entire unit. This means removing the blade and/or disc, blade, removing work bowl, work bowl lid, and blade.
Start by placing the work bowl onto the motor base. The work bowl handle should be facing at 9 o'clock, which is out to your left. Rotate the handle downward until it locks in at the 6 o'clock position, which will lock over the center of the button panel.
Repeat the process with the work bowl lid. The blade does not need to be present for the motor to engage, if this is an assembly issue.
If this has not resolve the issue, please ensure the outlet is receiving power.
If the unit is still not functioning, take a close look at the bottom of the work bowl where it meets to the motor base. The work bowl, when locked in, depressed a gray plastic peg. This is the safety mechanism. You may trying depressing this peg on your own with a pencil. If this activates the motor, this may indicate your work bowl is no longer seating correctly.
Also check the work bowl handle to make sure nothing is cracked. There is a plastic assembly in the handle that acts as a second safety feature.
If either of these things seems to be the culprit, I would suggest seeking a new work bowl or work bowl lid to correct the issue.
Jun 18, 2009 | KitchenAid KFP670 Ultra Power Food...
Cuisinart dlc-7 superpro food processor won't run.
The DLC-7 SuperPro is awesome -- very powerfull. Be aware they are 1.5 horsepower; the blade can take your hand completely off in a blink of an eye. Because of the potential danger, SAFEGUARDS are in place such that everything must be aligned and in correct position or it WILL NOT POWER-UP. So, yes, is very likely the safety switch.
Simple test: Use just the BASE, (no work bucket, no top, no blades), such that if it starts, only the spindle will turn. There is a little black button on the base, just back of the spindle. Use a chop-stick to depress it. Plug-in, press the button w/chop-stik, press the PULSE button. It should power up.
Presuming it powered up okay, the "problem" is probably in how the unit is assembled; such that the button is depressed properly.
1. The work bowl must be all the way down on the base, and the alignment column in the back, work bowl base skirt turned to the "Hard Stop". It will feel very solid when docked properly.
2. The top inserts and rotates into and snaps into position while pressing the plunger into the button.
It all sounds too easy, but if something is just a little off, the plunger doesn't plunge ind the power doesn't go on.
These are FABULOUS machines -- spend the time into getting it working. The near- equivalent if something this robust and powerful in today's products will cost nearly a THOUSAND dollars - seriously.
May 04, 2009 | Cuisinart DLC-2014 PowerPrep Plus Food...
Motor switch not activating on a dfp-14ts
Is the cover assembly engaged and locked into place? If you can't lock the cover into place, it's possible that part of the plastic on the cover assembly is broken and not engaging the white rod inside the bowl. Determine which part is at fault (either the bowl or the cover assembly) and replace it.
Dec 19, 2008 | Cuisinart DFP-14BC Custom Food Processor
Cuisinart DLC-5 Food Processor Logo
147 people viewed this question
Top Cuisinart Food Processors Experts
Colin Stickland
Colin Stickland
Rommel Balcita
Are you a Cuisinart Food Processor Expert? Answer questions, earn points and help others
