Question about Home Fencing
How do I dry out an electric gate opener that got wet?
My remote opener fell into liquid and won't work. How do I safely dry it out? I opened it immediately, remove the battery and used a cool hair dryer inside and have them in a bowl of rice. (The circuit board looked wet when I started this). Any advice?
  • 40 Answers
What is the make and model of your gate motor or central unit it might have to be reprogrammed after you dry it with a hair dryer without the battery in it
Posted on Dec 13, 2014
How do i make my universal control work as my original one so it can open my electric gate
be careful here ( as I explained before ) as the remote you use for the inside may also open the gate when you use it inside
Sep 01, 2016 | Universal Home Security
Tip
Does not make espresso Superautomatic
3 things
1. Dumps the grounds dry. = Dosage lever or knob is to the max. Reduce by 1 click.
2. Dumps wet and pumps runs for a few seconds. = Needs to be programed. Hold coffee button until it starts to dispense liquid but only when it gets to the amount you want for that button, release the button.
3. Dumps wet and pump runs for 1 minute, then ventilate comes on. = Blockage in the brew head (needs to be taken apart and cleaned) or bent gate valve on injector nozzle (replace gate valve).
on Dec 17, 2009 | Coffee Makers & Espresso Machines
Open a tailgate lower on 2004 Aztec when it will not open with the handle
Can you open it with your remote key FOB? If that does not work you can try this.
Nov 10, 2014 | 2004 Pontiac Aztek
I have a 2010 jeep liberty the gate light is on in the dashboard and rear gate wont open with remote or push button on rear door
the gate lock has issues, get it serviced.
if a DIY person? get the FSM and read that page. under body chapter.
Jan 11, 2014 | 2010 Jeep Liberty
Tail gate won't open
Is it electric ? If so check related fuses
Jun 11, 2011 | 2000 Chevrolet Blazer
I have a liftmaster keypad and remote and my code all of a sudden won't work.....additional question...i have an apollo gate that the lift master is wired to ... how do i set up the remote to open the...
My first inclination is that your keypad and remote have been removed from the Logic board memory.
If you have the Opener's instruction manual, then go to the programming section for how to re-program your keypad and remote.
If you do not have your manual then you can go to the Liftmaster website and download / view the manual for your particular unit. You will need the model number for your unit. That can be found near the light fixture on the unit (if you have two light fixtures, then look for a data sticker that indicates Model number and Serial number. You may have to remove or lift the light cover in order to find it.)
This is the link to the Liftmaster website: http://www.liftmaster.com/consumerweb/service/manuals/instructionmanualslanding.htm
To answer your second question, I will need to know what model of gate opener you have, and also need to know if there is a separate Receiver box unit or not. Most Gate operators will have the receiver unit built into them. Some however do not, and an external one will be wired to the gate motor unit, and possibly mounted to a wall near the gate motor. question: do you use the same remote for the gate that you use for the Garage door opener or do you have a separate remote for each? If you do, I need the model number on the remote for the gate operator. That will tell me what kind of tx/rx you have and possibly where to locate the learn button.
May 14, 2011 | liftmaster Chamberlain Garage Door Opener...
The outgoing gate has a positive stop on it, but
Well it seems that their could be a limit switch problem. also if someone has replaced the limit switch they could have not connected the wires back up correctly. if your wiring and switch are correct than you have a bad circuit board. my opinion is to not even fix it and replace the whole opener with a gto-pto gp sl50 They are the most reliable opener out so far and come with all the features that elite charges extra for like a battery backup for instance.
Oct 24, 2009 | Elite Sl 3000 Ul Sliding Gate Operator
I-pod shuffle got wet and now wont switch on or charge
If ever you get any electrics wet,turn it off immediately and don't turn it back on. Try your best to take it apart as much as possible, putting the screws in a safe place like a zip lock or sealy bag, and taping them to the item so they don't end up in a safe place that you can never remember. Put all of the bits layed out on something like a towel in a dry, warm place. Airing cupboard is a good one. Leave them alone for at least a week. If when you come back to it there's any evidence of water at all, leave it for longer. When it's bone dry, put it back together with your fingers crossed. I've managed to do this a number of times and have saved 3 laptops, 2 iPods, a desktop pc, many remotes, 2 diskmans...the list goes on.
If you've got it wet and you try to turn it on when there's any moisture inside, you're very likely to short something normally rendering your item useless. Some parts may still work, such as LED's etc butthat's just an area that probably didn't get wet. If when you open the item there's any smell of electrical burning, or black residue then there's been a short.
Nov 19, 2008 | Apple iPod shuffle Second Gen. Silver (1...
CELL PHONE FELL INTO THE WASHER
If you have insurance, it will probably cover water damage. The warranty will not. If you want to try to fix it yourself, read on.
Taking the battery out immediately is essential in order to prevent short-circuiting between leads of delicate components or the components themselves. However, the common misconception of then drying all of the circuit boards and components without specifically cleaning out the moisture first will probably ruin your phone. Let me explain. When the circuits get wet, many unintended current paths are created through the liquid. That's why it is important to remove the battery ASAP and leave it off until the repair is finished. However, the most common type of damage occurs after the electronics dry off. Sure, the water is gone, but any dissolved solids in the water remain. These deposits (sugar, coffee, soap, minerals from tap water, etc) remain and dry on the electronics as a hard film that can't be removed. These deposits will affect the digital and radio-frequency circuits of the phone, rendering it junk.
The solution is pretty simple. If the phone gets wet (dropped in a toilet, soda spilled on it, gone through the washer, etc), remove the battery and keep the phone wet (put it in a ziploc baggie) until you can clean it with DISTILLED water. Distilled water has no minerals in it, so it will dry without any residue left behind. DO NOT USE TAP WATER. Disassemble the phone completely, and use a syringe to spray everything off. Pay special attention to the circuit boards, chip leads, ribbon cable connectors, and anything else that looks electrical. Don't be afraid to get the electronics wet. That's what we need to do. The idea is to ensure none of the original liquid is remaining. Once completed, shake off the excess water, and place all of the components in a warm dry place for 24-48 hours. Once dry, reassemble the phone and enjoy it.
I have used this procedure 6 times, and it was successful 5 times. One morning my wife called me and said my son's phone had just gone through the washer. I had her rinse it off under the faucet with tap water to get rid of the excess soap and put it in a baggie to keep it wet until I got home. That night i used this procedure to repair it and the phone worked fine. The 1 time it didn't work, some soda had already dried on the circuit board and I couldn't get all of it off.
Sep 13, 2008 | Samsung SYNC SGH-A707 Cellular Phone
Home Fencing Logo
1,038 people viewed this question
Top Home Fencing Experts
 Russ Hill
Russ Hill
Tom Chichester
ray gallant
Are you a Home Fencing Expert? Answer questions, earn points and help others
