Question about Refrigerators
I have a caolina wall hung fire doesn't seem to be getting any power
Model -LBDL2000A-DD5R EAN-5052931106981 REF-29158593
2 Suggested Answers
imufo2
  • 3773 Answers
SOURCE: hot point ref. model hss25gftc cc,makes ice but
NOTE: This
is a multi-solution answer since I don't have all the tech from your question to pinpoint your problem
But the solution is in here generically, if you read and study the solutions very,very carefully.
Check Temp inside freezer. It has to be down to about 10 or 15 degrees
This can cause slow ice making if its too high even tho its freezing everything else at 25 degrees
The ref. temp should be about 33-35
The Freezer temp should be 0 to 10 Any thing below these temps is overkill and a waste of elect
The higher the number you turn it up to is the coldest
The icemaker is 110v
See if water is in icemaker.
Pour water in Ice Maker and wait to see if it ejects.
If it ejects thenyou need to replace water valve in rear bottom of fridge(Its the part that
attaches to water line out of wall)
If it doesn't eject then it is a faulty Ice Maker.
If its leaking or no water at icemaker or door either one, then the valve at the rear bottom of ref needs replacing
First I would check the fan in the freezer. Listen to see if it is running
It moves air to the ref from the freezer
Then check to see if freezer control is turned WARMER, which makes the Ref. colder
Also if it is getting drinking water to the door but not to the icemaker (or vice versa) Then you need to replace
the water valve at the bottom rear of the fridge. It is a double valve and one side is not working
Also this might be a common Defrost problem, Ice
is not being melted by the defrost system.The fan can't blow through the coils into the fridge.
Take out back panel of freezer to check for ice buildup. The coils should be clean.
There are three components to a defrost system- a heater,heater thermostat, and a timer unless you have a defrost electronic card.
Its best handled by a Technician but you could possibly do it by taking your model number to the nearest appliance parts store and asking for the parts. They are mostly located in freezer ,behind back panel on freezer coils.except the card which is usually located in ref The parts store will have info
Also check fan undernearh Ref in the rear
Clean condenser coils underneath
If you still have trouble GO HERE:
http://www.applianceaid.com/procedures.html
I'm
including my article on Refrigerator Repair for your help and convenience.;
Please click or copy and paste into browser for Article
http://www.fixya.com/support/r5816737-fix_refrigerator_psychologically
Thanks for using fixya
Leo Ponder
imufo2
PLEASE GIVE A TESTIMONIAL AND VOTE FOUR THUMBS UP IF THIS WAS HELPFUL
Posted on Sep 07, 2011
Bylss 34hfu600grt electric fire. Where can I get instructions?
[PDF]LDBL2000A-DD5R EN - Free Instruction Manuals
www.free-instruction-manuals.com/pdf/pa_843360.pdf
CAUTION - Fire, electric shock, physical injury and material damage hazards: To use the appliance, always follow the instructions for and assembly, use ...
BLYSS 34HFU600GRT KURZ User's guide, Instructions ...
www.manualspoint.com/results.php?...BLYSS%2034HFU600GRT%20K...
User's guide, Instructions manual & Installation guide - Immediate download or search mode services.
Jan 07, 2016 | Home
Engine is not firing,motor turns over but doesn't seem to be firing
what year make model engine etc.................................
Feb 01, 2013 | 1994 Honda Accord
Model EG5000, one year old;last fire up in March, now it doesn't start. Has fresh gasoline
i'm sure you primed it - or go get a can of ether spray in carburetor
Oct 28, 2012 | Honda EG5000 Generator
Is sharp non-cfc refrigerator power saving?
Checked any gas leaked from compressor.
Oct 27, 2012 | Sharp Refrigerators
My fisher & paykel fridge freezer has stopped cooling. If i turn it off at wall & then on again it starts up & fans spin however it seems to turn itself of after about 5mins??
NOTE: This
Sounds like the cold control has stuck . Unplug the two wires from the cold control and plug them together. Turn one wire over and plug it into the other. away from the cold control.
The cold control is the knob in the ref that turns it on and off and has numbers on it. (Thermostat)
If it runs then that cold control (Thernostat) is the problem.
If that doesn't work DO THIS:
The relay on the compressor may need replaced
A relay starts the compressor with a higher voltage and then quickly kicks out
Thats what is happening with yours
Its best for a tech to replace The relay but you can do it
Take your model number to your Local Appliance parts store they will have a diagram
showing you how to install the relay. Its called a hard start relay
also try hooking the two wires together on the cold control to route around the cold control.
Be sure the BACK COVER is in place and hasnt been accidently removed.
If you need more help GO HERE:
.I'm including my article on Refrigerator Repair for your help and convenience.;
MORE TRICKS:
STOP PAYING FOR EXPENSIVE WATER FILTERS FOR YOUR REF. DO THIS____
http://www.fixya.com/support/r9962087-stop_paying_high_price_refrigerator
Leo Ponder
imufo2
Please VOTE FOR ME IF THIS WAS HELPFUL
Most overlooked dryer energy saving problem EVER!
http://www.fixya.com/support/r5739846-most_overlooked_dryer_energy_savingr
REF THERMOMETERS TIPS
http://www.fixya.com/support/r10177561-second_biggest_refrigerator_energy
Thank you for using fixya
Leo Ponder
PLEASE VOTE FOR ME IF THIS WAS HELPFUL
Oct 03, 2011 | Refrigerators
My laptop won't turn on, and the charger doesn't seem to be doing anything. even when plugged in, it won't start. ideas?
You've to replace the ac adapter, if it's brick doesn't get warm or LED does not glow on Power Jack on the laptop. offcourse, check with the wall different sockets
power jack can also be loose. so jiggle the cable to find out.
if notebook is getting power, you can remove the battery, ac adapter, hold and keeep pressing poer button for a minute, then, turn it on.
finally, you can take out hdd and ram, put them back again and turn on the laptop. hope it will help
Sep 17, 2011 | Compaq Presario CQ60-220US PC Laptop
My ice maker doesn't seem to be working... I pulled the fridge out to check that the lines were connected (and they are) & that there are no kinks in the lines ---- everything seems fine, but the...
NOTE: This
hhttp://www.applianceaid.com/procedures.htm
Leo Ponder
imufo2
Sep 10, 2011 | Amana ARB2217CSR Bottom Freezer...
Somebody hung my TV for me but, didn't put the power cord in so, I'm trying to navigate blindly, it's hung on the wall, to attempt to plug in my power cord but can't find it. Can you give...
Tries look near the square arm plate that have four screws holding the tv look for a hole with 3 steel prongs that ur tv a/c hole for power cord hook up.But if the tv it is very closed and hook up tight and flust to the wall will not able to hook up a/c power cord must take off wall to be able to hook up a/c power cord.
Aug 27, 2011 | LG 42LC2D 42 in. LCD HDTV
The ice maker doesn't work & water drips down from the freezer to underneath the vegetable crispers. It is not the plug. Is there a turn off valve on the ice maker line so that no more water can...
NOTE: This
Leo Ponder
imufo2
Aug 09, 2011 | Whirlpool ET1MHKXM Top Freezer...
Ok i got this exercise bike at a yard sale its the stamina R360's and I didn't notice it doesn't contain the petal straps for it i need them for pt at home, tkr so my foot doesn't slide off...
Fixya does not sell replacement pedal straps and would not know of sources.
For a manual, try Googling (stamina)(R360s)(manual) without parens.
Aug 10, 2017 | Cycling
Refrigerators Logo
41 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
