Question about Vehicle Parts & Accessories
The ac compressor on my 2003 Mercury Grand Marquis stops rotating after I start the engine. Is there a way to disable the ac compressor?
The ac compressor stops rotating after I start the engine.
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 78 Answers
Find the wires that go into the clutch on the front of the compressor and unplug it.
Posted on Nov 13, 2014
2003 grand marqui ac operation
turn on ac , open hood check the cold side pipe. an is the air compressor turning .
need more info
Sep 11, 2014 | 2003 Mercury Grand Marquis
Air suspension compressor sounds bad and wont pump up the rear on a 2003 mercury grand marquis
What is odd is the compressor stopping after so short a time. It may be your only problem.
When you have a leak in the system, the compressor keeps running because the sensors do not signal for it to shut off. On your vehicle it is either being told to shut off prematurely or the compressor is triggering a circuit breaker.
There are ride height sensors on the rear. If the vehicle was lifted without turning off the Air ride, the sensors may have been stretched.
You can check for air leaks in the suspension bags, and air lines using a spray bottle of soapy water. There is also a Master dump valve that should be ahead of the Drivers front tire/radiator well area. It is not a concern unless there is no pressure in the system.
Finally, just as the engine can express diagnostic Codes, so can the suspension. You need a better scanner to do this function. It is the quickest way to find the problem.
Please rate my info.
Jan 22, 2013 | 2003 Mercury Grand Marquis
A/C compressor not coming on 1996 Mercury Grand Marquis
The first thing to do is check the connector at the AC compressor to see if it has power whwen the system is turned on. Then check the pressure switch as well for power in and out.
Aug 24, 2012 | 1996 Mercury Grand Marquis
Ac on 96 grand marquis continues to blow hot air with new compressor and freon?
The first question is do you know if the ac compressor is running ?
If one ac line is hot and the other is cold you may have a blend door problem under the dash.
Jul 01, 2012 | 1996 Mercury Grand Marquis
2000 grand marquis turned ac on and car died
The compressor could be locked up which would stop the engine when the a/c clutch engages.
Jun 23, 2012 | 2000 Mercury Grand Marquis
Serpentine belt came off. ac compressor , can it be bypassed when putting the belt back on?
Some companies make a AC delete adapter for mustangs, It should fit, but you will have to remove your AC compressor.
Oct 20, 2010 | 2003 Mercury Grand Marquis
Engine Squeak on 1986 Grand Marquis
Yes. Squeal is from a/c compressor. Belt too loose.
Dec 07, 2009 | 1986 Mercury Grand Marquis
Y does my ac clutch keep freezing up on my 03 grand marquis
Two things will cause that. 1. compressor is bad 2. sysrem over charged.
Sep 27, 2009 | 2003 Mercury Grand Marquis
Believe ac compressor pully is locked up not sure where located a
front of engine down low on passenger side (access from under the car), there is no AC delete option so the compressor should be there and not bypassed, what is the question about the AC? it doesn't work?
Mar 24, 2009 | 1995 Mercury Grand Marquis
Vehicle Parts & Accessories Logo
53 people viewed this question
Top Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Vehicle Part and Accessory Expert? Answer questions, earn points and help others
