Question about Microwave Ovens
Is it normal for outside of microwave to get warm
MW93225SL
    Prodigy:
    An expert who has answered 500 questions.
  • Microwave Ovens Expert
  • 650 Answers
It could bet warm after use. The is a lot of heat generated from running and the case would get warm after a few minutes of use.
Posted on Nov 15, 2014
Use ifb microwave
You need to power down to 70% this will allow the inside
to heat as well.
Oct 11, 2013 | Microwave Ovens
I used my GE Sensor Microwave oven tonight to cook a frozen macaronni and cheese. The cooking time was 16 minutes on high. The oven was noticeably blowing out hot air and very warm to the touch on the...
It will normally get pretty warm after a minute or two of cooking, but the important thing is to be sure the vents are not clogged or blocked, and that the internal cooling fan is working.
Aug 18, 2010 | Microwave Ovens
Microwave felt very warm on top. after cooling
That's often a sign of impending failure of the magnetron or a failed or failing internal cooling fan.
One should never leave a microwave unattended while cooking, and it's even more critical any time there is a problem or potential problem.
With the model number, we can offer more specific advice or an estimate.
But since FixYa does not notify us of follow-ups, you will need to post a new help request.
May 31, 2010 | Whirlpool GH8155XM Microwave Oven
Overheating bottom Kenmore 66560652000
I would suspect that when the microwave oven was on the table the vent or air openings were restricted by the table. Without free flowing air the control and other components could build up heat. It is doubtful that you built up enough heat to damage anything as this unit has more than one over temperature safety devices built into it.
That being said, the excess heat could weaken something internally especially on the control that would cause it to fail sooner than later in life.
My advice would be to leave it unplugged until it is mounted back on the wall per the instructions and use it then as normal. If it fails in the next year or so replace it at that time.
May 03, 2010 | Kenmore Microwave Ovens
Kenmore microwave's exterior and buttons
Hi it is quite normal for the outside of a microwave oven to get quite warm to the touch. with regard to the buttons not working; this will be due to a faulty touch panel mebrane that will need to be replaced. They are not too expensive so is a viable repair
Hope this helps
Jan 07, 2010 | Microwave Ovens
My lg microwave is on but does not warm the foof
either the h.v. diode, h.v. capacitor,thermal switch,or the magnetron tube are faulty
Oct 30, 2009 | Microwave Ovens
Microwave heats outside too.
This is normal. However, if you are worried that your microwave is old and may be leaking radiation you may want to replace it, as they are actually under one hundred dollars for the most part; or you can get a little microwave radiation test kit at home depot or lowes for about twenty dollars.
May 20, 2009 | Microwave Ovens
Inside Microwave is Hot
Hi, What you noticed is perfectly normal...
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
Feb 26, 2009 | Hotpoint RVM1435 Microwave Oven
Microwave is new but it won't allow me to set the clock .
If you set the default for high heat, it will normally boil 8 ounces of water in 60 - 75 seconds.
Feb 04, 2009 | Emerson MW8102SS 1100 Watts Microwave Oven
Microwave message says to replace charcoal filter. User manual states charcoal filter is used if unit is not vented outside. Our unit is vented outside
External vent systems have the charcoal filter removed, generally at the time of installation, as it is not needed for this application.
The charcoal filter removes odors from internal recycled airflow.
There should be an aluminum grease filter that you can remove to clean in a warm soapy solution, let dry, and reinstall.
May 27, 2008 | GE Microwave Ovens
Microwave Ovens Logo
176 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Microwave Oven Expert? Answer questions, earn points and help others
