Question about Oreck LW100 Magnesium Upright Vacuum
What is the problem when the fan housing "tube" is not moving back and forth as it has been; it is very hard to move it. Already asked this question but thought I'd simplify it....
    New Friend:
  • 110 Answers
It could be something caught in the mating surfaces of the fan housing, or it could be cracked and getting hung up on the inside of the machine. The only way to know for sure is to take it apart. If you don't trust yourself to be able to do that then I would recommend a vacuum shop!
Posted on Nov 27, 2014
Why doesn't brush roller rotate?
The brush roller may have been reinstalled incorrectly, i.e., not seated. The brush roller may be binding on the bottom plate or the bottom plate could have been reinstalled incorrectly.
Mar 20, 2016 | Vacuums
I, too have Oreck XL that kicks off the belt
Thomas,
Check where the bearings mount in the housing and see if they are tight. If they move back and forth in the housing mounts, that could cause the brush to shift and cause the belt to come off. Which model XL do you have? Some of the models have extended warranty and you might have the possibility of having it covered.
May 25, 2015 | Oreck Vacuums
Spindle not coming off my kirby
it's a left handed thread watch this video
Oct 22, 2012 | Kirby G4 Bagged Upright Vacuum
The fan housing tube is cracked just below the bottom clamp. How to replace
Its not to difficult, its just requires some patience. The first thing Ill recommend is removing the handle from the fan chamber tube, it should come apart pretty easily simply by turning the flange that threads it together. Watch the video I've attached it explains the removal of the handle. The bottom of the bag has a small metal spring clip that holds it onto the handle, just lift that off. Set the whole thing to the side. The cord will still be attached to the base, which is fine, its just easier to work on it when all that's set aside. You'll want to flip it over like you're changing the belt, remove the baseplate screws and pull it off. That'll expose the motor, belt, brushroll, fan chamber and dirt intake tube. Remove the belt, set it and the brushroll aside. On the right hand side there's one screw that holds the dirt intake tube on and two screws on the other side that hold the motor in. Remove them all. The dirt intake tube should slide out, set it aside. You'll need to pull the motor off the other side by wiggling it back and forth until it pops free from the fan chamber. Its just a friction fit. The chamber should be free, you'll need to just rotate it around to remove it from the base and it should come out. To reinstall the new one you just put it back in the opening on the base, refit the fan and motor back into it, hold the dirt intake tube on the other side and fit it back in gently. Oreck's don't have a rats nest of wiring or moving parts so just keep an eye on the screws and be patient!
Dec 19, 2017 | Oreck XL21 Bagged Upright Vacuum
Goes slightly forward and then backs, turns and tries again. As though it is hitting something in front of it
Take a can of air with the attachable tube and blow it into the underside near where the guard attaches. If you move this back and forth you will see some pivots underneat the the device. These pivots block the electronic eyes, which are clouded with dirt, and making your DD think its hitting a wall. If this does not work, you will have to take the front guard off, which is 6 screws or so, and you will see the eyes directly, which you can then clean.
Jun 06, 2009 | iRobot 1100 Dirt Dog Bagless Robotic...
Back wheels not turning.
See if the pedal is set on D
Check if there is some resistance to move pedal from N to D and back - maybe pedal is broken...
See if handle slides back and forth a bit (maybe slide is rusted)
if everything is fine - Inspect primary drive belt. That will require to get inside the vacuum... See instructions HERE
If everything above is ok - you may need to replace a tech drive.
Good Luck
Nov 13, 2008 | Kirby G6 Bagged Upright Vacuum
Fan and bearing replacement on a Kirby G6
if you run your vac to long after the fan is broke it will cause excessive vibration and the bearings can go out. in almost all cases i replace the fan only. most of the time if you have a bad bearing the vac will make a grinding noise. you can also tell a bad bearing by grabbing the belt pulley on the end of the fan and pull up and down if it moves alot then your bearing is also bad. you can get the bearings separate witout ordering the armature assy. when talking of replacing any of these parts besides the fan i would advise you to take your vac to your local repairman. working on motor parts of a kirby can get pretty involved. to replace the fan first take the housing off where your belt and brushroll are. you should then see 5 screws on the front of your kirby. remove all 5 screws. then remove the handle. at the very bottom of your handle you will see a piece that allows you to move the handle, on the back side of this you need to push in with your thumb and the handle should pull off. then you should see a plastic piece directly below that snaps into the top housing. remove the 2 screws from this. one where the cord boot is and one above your power drive neutral/drive lever. then under this plastic piece is 2 more screws on your top housing. when these are out your housing should pull off. if not then remove the bottom plastic housing of your outer bag. then go back and look at the front again and you will find since removing the top housing you have exposed 2 more screws in the front fan cover housing that also need to come out. after this pry this housing off and you should be looking directly at the fan. grab fan with pliers in one hand and with the other hand apply pliers to the silver belt pulley and turn this piece clockwise. it should unscrew and then you can pull your bad fan off and attach the new one. i hope this helps and remember its not as hard as i probably made it sound. good luck!!!!
Sep 24, 2008 | Kirby G6 Bagged Upright Vacuum
Kirby Heritage 2 fan replacement
Take the bag asm. and handle off. Then remove the plastic strip covering the switch, remove the screw there, remove the 3 screws on the housing, turn it over and loosen the screw near the back, the housing should come off. Then remove the screws on the back of the fan casing. You shouild be able to get to the fan, hold the fan and turn the spindle to the right to take off. If it would turn off, then you may have to lock the armature so it can't turn to move it. Then re-asemble in reverse.
Jun 21, 2008 | Kirby Heritage II Vacuum
Oreck LW100 Magnesium Upright Vacuum Logo
56 people viewed this question
Top Oreck Vacuums Experts
Jim Parker
Jim Parker
xalint1
xalint1
Are you an Oreck Vacuum Expert? Answer questions, earn points and help others
