Question about Toshiba 40 Class 1080p 120Hz LED Smart HD TV - 40L3400U Black 40 to 49 in
What are the best picture settings for my Toshiba 40L34000 led tv
Best picture settings
5 Suggested Answers
  • 290 Answers
SOURCE: Best picture settings for toshiba regza 42RV500e
Go to menu on your remote control and select picture setting and try selecting "default" setting to seeif you like the color, if not adjust contrast to about two thirds of the way and brightness to your liking and color to about the middle.
Posted on Jan 17, 2010
  • 1156 Answers
SOURCE: To receive the best picture,
Hi, i guess the best picture quality to set the TV to is to set to a default setting is always the best quality setting a TV set could, because is the setting that came with original default setting ..
To know the default setting that will work best for your TV set,you can use the manual of the TV to check the default setting..
Hope that helps..
Posted on Jun 17, 2011
gopakumarg43
  • 74136 Answers
SOURCE: What are the best picture settings for my Toshiba 65" led smart tv 65L5400U
Picture settings will depend on the taste of the viewer. Do it as your preference. Gopakumar Gopalan Google
Posted on Jan 17, 2015
gopakumarg43
  • 74136 Answers
SOURCE: The best picture settings for a toshiba 50l3400u tv please help me
It will depend on the viewing preference of yours'. Set contrast to 70%, Brightness to 40% color to 30% might be good.
Posted on Feb 05, 2015
Vertical lines appear on toshiba LED 3D TV
U may have a problem with the T con board of your set. It digitizes info and when you have crazy distorted pictures it is responsible for the anomaly
Sep 26, 2015 | Toshiba 47" 1080p 120Hz 3D LED-LCD Smart...
How to fix the problem of half black screen on my toshiba led tv?
On your TV remote go to menu , either video or picture settings and make sure it is on HD ( high definition )
Aug 01, 2015 | Toshiba Televison & Video
Can't see picture in TOSHIBA LED TV, but still have sound and can see picture with flash light
try changing the back light inverter that's what light the screen some sets have separate back light inverter while some comes in he power supply...good luck
Apr 03, 2015 | Toshiba Televison & Video
Jan 16, 2015 | Toshiba Televison & Video
Toshiba 24" led tv mo. 24ps1e VGA is ok raster snow is ok ,after connection of cable only chroma picture seen,no Y signal.
Try to reset it to the factory settings and Them remove the power cable for atleast 5 minutes but Will be better to power OFF for 12 hours
Jul 18, 2013 | Televison & Video
Toshiba 37AV500U damaged thru HDMI input.
The lightning stroke has been effected to the main digital board to your TV. It will be best to replace the main digital board as card basis, rather than trying to repair it. Before replacing the board, a through checkup should be done. Contact any expereienced service technician for help, as this work is a very skilled one. No body can predict about the damages to a lightning stroke, as there will be trillions of voltage present for every stroke, and even a slightest voltage can damage so many components in a TV like equipment, as it is designed to work for 110 or 220VAC.
Jul 07, 2012 | Toshiba 37AV500U 37 in. LCD TV
42hl67
I had lcd 42" over a year it is working find before , but now it has very dark picture
can y help me to find out what is a problem and how much to fix?
May 01, 2008 | Toshiba 42HL67 42 in. LCD Television
Toshiba 43A61 - No Picture, no sound
If your set all of a sudden won't come on, e.g., the screen is blank, but the LED on the under the screen next to the on/off switch keeps flashing, then there may be an internal fault on the set that needs to be reset.
To force the reset, try this:
  • Unplug the set and wait a few seconds
  • Replug and see if the video returns
Whenever the set senses an internal fault through its monitoring circuitry, it essentially shuts down the set. The flashing LED provides the indication that a fault has been detected. Removing power to the set resets the monitoring circuitry. When plugged back in, the circuitry again does a check of the system. If it finds that there truly is a problem, then the set is shut down and the LED will again flash. In this case, you need to call a service tech. Most of the time, however, the unplug/replug routine is enough to get the set up and running.
Dec 11, 2007 | Toshiba 43A61 43" Rear Projection...
Toshiba MD20FP3 Combo does not turn on. Help!
Not unless you have taken the time to learn all the safety issues concerning the HI voltage safety facts, in the repair of electronics? It sounds like your tv has a problem in the sweep/power supply circuits, and since these sets have NO user serviceable parts< its best too leave these types of repairs to a certified electronic technician. Good Luck
Jun 25, 2006 | Toshiba MD20FP3 Combo
Toshiba 40 Class 1080p 120Hz LED Smart HD TV - 40L3400U Black 40 to 49 in Logo
57 people viewed this question
Top Toshiba Computers & Internet Experts
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
