How do I install a temostat - Heating & Cooling
    Welcome Back:
    Visited the website for 2 consecutive days.
    Problem Solver:
  • 6 Answers
FIRST TURN THE POWER OFF TO YOUR UNIT. Then note what color wires are connected to the labeled connection points at existing T-stat, ( R Y W G X O B, ect.) Wright it down ie red wire to R terminal ect. Remove existing T-stat and install new one. Insure you have the correct T-stat for your application.( gas furnace, electric furnace, heat pump ect.
Posted on Nov 12, 2014
How to fix head gaster
Head Gasket. Vehicle equivalent of open heart surgery.
May 27, 2014 | 1999 Jeep Grand Cherokee
Unit exactly one year old. Was interruped by lightning strike last night. Afterwards air handler blowing, but not cooling? Turned unit of at temostat, waited a few minutes, turned back on and unit (both...
Marion, if there was a lightning strike and then a power surge when the power came back ON, I don't doubt what the servicemen had to say. The age of the unit plays no role in it, when something like this happens. Power surges can be killers to electrical appliances. That's why it always wise to turn the unit off during a power outage. Just ask anyone who was in Irene's path a couple of weeks ago. Power went out for days & weeks for some, when it came back ON, electrical appliances were damaged or ruined or started house fires.
Hope this helped you and thanks for choosing FixYa.
Sep 19, 2011 | Amana Heating & Cooling
Running hot replaced temostat
When hot, check to see if the fan clutch is engaged fully, if the fan is spinning slower than the engine, it may be bad and needs replacement.
Sep 02, 2011 | 2005 Jeep Grand Cherokee
Low heater air temperature, which gets even cooler with increased fan speed.
could be your temostat, the water pump, blend door or motor, try the termostat first and then see what happens. try to bleed the cooling sistem too. maybe air in the sistem.
Feb 25, 2011 | 1986 Isuzu Trooper
My 2005 chevy monte calro has been overheating it has hot coolant on dash but fluids are cold, goes off when applied gas hard to get fluids pumping, heater doesn't work and recently replaced radiator and...
Check the thermostat, if it isn't opening when engine warms up, the coolant in the engine will overheat and make pressure in the cooling system but the fluid in the radiator will still be cold.
Dec 02, 2010 | 2005 Chevrolet Monte Carlo
Sudden engine overheating . I replaced the radiator with a new one because it was leaking at the tank core. I have driving 150 miles sence and had no problems. Today I was stranded because my check gauge...
it sounds like the temp switch for the fans isn't working properly & or the heater core could be clogged as well the best thing to try is get a cooling pressure tester to see what the pressure is holding at since theres no thermostat
Jul 02, 2010 | 1999 Jeep Grand Cherokee
My 02 Oldsmobile Silhouette is over heating what could be the problem
Overheating problems usually warrant some troubleshooting. First, check your antifreeze level. If it's low, replace it, run it for a couple of minutes with your heater on, then recheck it. Next, your thermostat could be stuck. For about 30 minutes worth of work, and about $10 of parts, you can do this replacement yourself. This will usually give you the symptoms of having one coolant hose being hot and the other cool, if it's the thermostat that's stuck closed. The next place to look is the water pump. There aren't too many reliable ways of testing one of these at home, so it's pretty much a replace and pray, because if it isn't, then it's something more serious like a blown head gasket or a cracked head. These last two can disclose their presence by evidence of oil or antifreeze leakage, or white smoke when you first start up your vehicle in the morning, but will not always do this.
Oct 19, 2009 | 2002 Oldsmobile Silhouette
Heating & Cooling Logo
46 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
