Question about Lexmark E120n Laser Printer
I have problem with printing. My printer prints with black spots sideways and in the middle . I have changed my toner cartridge since 1 week before . How can i solve this problem ?? I would like a rep
I have problem with printing. My printer prints with black spots sideways and in the middle . I have changed my toner cartridge since 1 week before . How can i solve this problem ?? I would like a reply !! Thanks!!
The e120 has a second supply part, called a photoconductor kit. It sounds like the one in your device is worn out. Go to Lexmark.com, enter the name of your printer in the supply finder, and look for a photoconductor. It installs as in the same area of the printer as does the toner cartridge. Order, replace, and it should solve your problem.
Posted on Nov 13, 2014
BondoFox
  • 40 Answers
SOURCE: Unisys UDS 25 Printer Problem - Identical to Lexmark T614
Your Unisys UDS 25 is actually a Lexmark Optra T612. Are you using OEM cartridges or recharges? If you're using recharges, that would explain the print quality issues. Was it light with the first cartridge as well as the second? The drum "being on its way out" is a moot point since the drum is replaced when you replace the toner, it's all one cartridge. If you have another printer of the same model, try the cartridge in it and see if the problem follows. If it does, it's the cartridge, take it back and get an OEM one. If the problem does not, then you may need a new image transfer roller. Let me know what happens!
Posted on May 29, 2007
  • 300 Answers
SOURCE: spots on paper
Look on the image drum (bottom of toner cartridge) are there spots on that?? if so clean carefully so as not to damage it or replace the cartridge. If this is not the case open the cartridge door during a print, but before the paper fully enters the fuser and check if the spots are already there, if not the fuser is causing the problems.
Posted on May 17, 2008
SOURCE: Lexmark x 1270 & x1290 printer won't print black after using re-filled cartridges.
hmmm...paperman..that's unusual to say the least..
Posted on Aug 19, 2008
crayzeetrayn
  • 837 Answers
SOURCE: Lexmark E321 Laser Printer
Check pages 76-80
Posted on Dec 07, 2008
  • 990 Answers
SOURCE: When I print, only the
if your document only black and white , the machine only use black ink, no going withdraw the color ink. but you have had to leaved the full color ink in the machine.
Posted on Dec 09, 2008
Faded print on right side of page. When I copy/print in black, why is the black print faded on the right side of the paper?
Your toner cartridge may be the culprit.
Take the cartridge out and shake sideways and up/down. Reinstall it and try again.
If it's still printing faded side, replace the cartridge.
Jul 30, 2014 | Brother MFC-9840CDW Laser Printer
I have a HP LJ 4700 printer set up to a network. It will print black but not colour
1. Go to menu set as default.
2. Do color calibration.
3. Print PQ test pages, observe the colors, chk
4. Print demo page. chk
5. Print from different file/system..
Nov 28, 2012 | HP LaserJet 4700 Printer
I'm getting an error code 59.60 on our HP 3015 printer. Last week I had to change the toner cartridge because we were getting a smudge on one side of the print. Could this be related? A bad printer...
Error 59.60 is an issue with the black cartridge motor starting up.
Check that connectors J5006 on the black print-cartridge drive motor and J208 on the driver PCA are seated correctly. Replace the black print-cartridge drive motor. Replace the driver PCA.
Feb 28, 2011 | Office Equipment & Supplies
PRINT QUALITY IN THE MIDDLE OF THE PAGE IS ABNORMALLLY DARK AND ALSO LIGHT
open the printer upper assembly and get the printer toner cartridge, shake it sideways to shake the stock-up mixture of toner inside the cartridge.... set-back the cartridge at the printer, and Wella!!!!.... I always done this to our company printer!!!!
Feb 27, 2011 | HP LaserJet 1015 Printer
Our printer is leaving black spots on everything it prints and no matter what I do (change cartridge/clean out) they get worse and worse. What do I do?
hello, you might want to do a half test, i will explain, when the printer starts printing, open the front cover after paper has started to pick up and has gone halfway into machine, pull toner cartridge out, and check print, if the black spots are there, then the problem is toner, if not then it would be fuser.
Sep 30, 2010 | Lexmark Optra T610 Laser Printer
Printer sqeaks loudly when printing. Also there
Sqeaks are hard to fix over the computer but if the black spots are random change the toner cartridge. If they are 3 or 4 to the page change the drum.
Feb 04, 2010 | Brother HL 2140 Laser Printer
Everything is printing black n dirty
Most likely cause is a bad toner cartridge. It's likely dumping excessive toner inside the printer. try taking the toner out and hold it sideways and tap it, if toner falls out then your cartridge is defective. try vacuuming the printer and wipe it clean with a dry cloth and and replace the toner with a new one.
Oct 05, 2009 | Brother MFC 7420 All-In-One Laser Printer
Four dots middle of page
How do I clean white or black spots on printed documents? Description: First make 10 to 15 copies of a blank, white sheet of paper.
If you still see the spots on printed documents after making multiple copies, clean the drum unit as follows:
  1. Remove the drum unit and toner cartridge assembly, and then remove the toner cartridge from the drum unit.
  2. Position the print sample in front of the drum unit so you will know the exact position on the drum that is causing the poor print.
  4. Turn the black gear on the drum as you check the surface of the OPC drum.
    The OPC drum is photosensitive so do not touch it with your fingers.
  6. When you find the substance on the drum surface that matches the print sample, gently dab the surface of the OPC drum with a cotton swab that is lightly dampened with isopropyl alcohol.
  7. Note
      • Do not use a scrubbing or wiping motion because this might damage the drum.
      • Do not try to clean the surface of the OPC drum with a sharp object, such as a ball-point pen, because this might cause permanent damage to the drum unit.
  8. If the print quality still has not improved you need to install a new drum.
Sep 11, 2008 | Brother MFC 7420 All-In-One Laser Printer
Spots on paper
May 14, 2008 | Lexmark E321 Laser Printer
Lexmark E120n Laser Printer Logo
73 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
