Question about Tablets & eReaders
What would be a reason for my ACER Iconia A1-810 tablet not powering on with a full charge?
My Acer A1-810 tablet won't turn on. I have charged it and the battery charge screen comes on, but after that its just black. I have used the power button plus up volume button option several times and nothing happens. Funny thing is while it is OFF my morning alarm had turned it on just long enough for me to silence the alarm but then shuts off again.I don't get to the logo screen, just a black screen. :(
  • 846 Answers
If it doesn't turn on with a charged battery, you may have a broken logic board. If you're out of warranty, somebody has to open the device and replace the logic board. The part is available on ebay. On youtube you will find a guide on how to disassemble an Acer tablet. Maybe a tech savy friend can do it for you. If you want to pay to have somebody do it for you there are third party Acer Tablet Repair Services.
Posted on Nov 12, 2014
Testimonial: "Hi, thanks for the info. After many attempts of turning it on, the "Android System Recovery" screen came on; however, it won't allow me to select any of the booting options or at least it won't respond to selections. I highlight "Reboot system now" option and held the power button down to select it and it does nothing. Any suggestions. Does this sound more like the logic board being broken, as you originally suggested? I appreciate your help."
Why has my acer a3 screen gone blank ?
The program of your unit is wiped out. reprogramming is the solution.
Jul 27, 2014 | Acer Iconia A3 10.1 Tablet - 16GB
Acer tablet a700 manual
SO sorry to hear this. I have seen to many tablets go BRICK after they are left to charge and then either they stay on the android boot/battery screen or they stick on the logo screen. There is a few things u can try to rescue you tablet.
First is this a acer tablet a700 or is it a acer iconia a 700?
I will assume its the tablet since if it was the iconia phone you would of been more upset for the 300 dollars plus. SO here we go and by no means can i tell u the exact reason these tablets fail or brick after charging.
This is a upper end tablet and not the cheap china clone. so hear is your first thing to try.
DO a hard reset with the keys first. WARNING reset can wipe out all ur data and set it back to factory if thats what u had it set to do. So if u have a sd micro card in its slot.. remove it and disconnect it from the computer dongle too. There are several diff options in recovery settings..back to factory or restore you settings from a backup file.. or wipe it and start all over.
so be aware that by doing a hard reset u can end up reinstalling everything u had on there.
Factory reset is first done with keys. HOLD THE POWER BUTTON AND THE SOUND UP but make sure you have the sleep / lock button right. at same time until it powers off..if not try power/sound up..this is the most common android tablet reset.
If this fails, then
The right side of the tablet is home to a microSD card slot (under a plastic flap) and a micro-HDMI port. The power/sleep/unlock key and 3.5mm headphone jack are located along the left edge, while a volume rocker and orientation lock switch are found on the top edge of the tablet, .
The micro-USB charging and syncing port, as well as a pair of speakers and a reset button, are located at the bottom of the A700
If u have made sure u have the sleep /lock switch in correct position. U have only one option left..the dreaded reset button. its on botton next to the usb sync charge port. Use a paper clip NO SHARP OR POINTS that break off.ie PENCIL lead .
DIsconnect from power and remove any micro/usb bridges..hold it in until it powers on and off..then cross your fingers and push the power button and wait.
If this fails to reset it back to factory and revive it. There are some software tools..SDK ANDROID isnt for the weak at heart though..lots of info and things that you will pull ur hair out trying.
If the reset above doesnt work..and u made sure its not in lock/sleep.. u are best off contacting the help line first and then last.
good luck my friend..
I will follow ur case..so post what happens and i will get it
Oct 20, 2013 | Tablets & eReaders
Complaint department
Please refer this concern directly to Acer
May 14, 2013 | Acer Iconia Tab A510 Tablet
Tablet won't charge
If it's new bring it back on the warantee, if it is out of warantee, check to see if the power supply is putting out the proper voltage at the plug in tip to the Acer. Make sure the tip is put ALL THE WAY into the hole on the acer.
Jan 02, 2013 | Acer Iconia Tab A200 Series Tablet with...
Will a usb charge the cruz?
As far as I know the 101 does not support USB charging just the DC in jack works for charging it. Most smaller tablets do not support USB charging. I have a Acer Iconia as my personal and i doesn't do that. I can't say it is missed. I only have a 5-6 hour battery but can plug in any time to charge without having to have a pc or laptop running.
Mar 21, 2012 | Velocity Micro Cruz Reader R101 Tablet PC
Tablets & eReaders Logo
180 people viewed this question
Top Tablets & eReaders Experts
Are you a Tablet and eReader Expert? Answer questions, earn points and help others
