Technics sa-dv280 when pressing the standby button it turns off straight away what will be the problem and will it be costly
    Habit-Forming:
  • 166 Answers
Sounds like units going into protection due to a fault in the pa stage
Posted on Nov 26, 2014
SOURCE: technics SA-AX720 AMP
The audio amplifier IC of your device are damaged you need to replace it.
Posted on Jul 04, 2008
  • 4234 Answers
SOURCE: Technics SA-DX950 intermitently sounds blown out
There are poor solder connections at the output amp pacs and the voltage regulators. Once these are resoldered the problem should go away. If you can solder, resolder any connections that appear grainy or have rings. If you can not, this should be effectively a labor only repair for any shop that works on audio gear.
Dan
Posted on Feb 18, 2009
SOURCE: Technics sa 400 Receiver
Checked fuses then sprayed contact cleaner on the fuses and the fuse holders. The speakers began to work correctly.
Posted on May 29, 2009
  • 118 Answers
SOURCE: Technics SA-EX600 reciever shuts off and goes into
repairable, but not worth it
Posted on Nov 03, 2009
  • 4 Answers
SOURCE: technics sa-gx670 reciever sound drop
it could be that your amp chips are gettin hot
Posted on Jul 23, 2010
Output ic for Technics model SA-DV280
You can try this site. Be wary though. http://www.manualspoint.com/document_order_init.php?search=TECHNICS DV280 PARTI RICAMBIO SCHEMI&doctype=4
Sep 28, 2015 | Technics Audio Players & Recorders
How do I know if oys a fuse blown
I had the same trouble to reset this machine into factory setting and finally, I found out. Let's do this way.
- Leave your remote away as you won't need it
- Turn off the the unit to STANDBY mode
- Press and hold STRAIGHT button on the unit and press Power button while you are holding it. This will turn on the machine.
- Once the machine turns on, press PROGRAM to select the items on LCD display until it shows INIT **** CANCEL
- Press STRAIGHT button until it shows INIT **** ALL
- Press Power to turn off the machine.
- Leave it for 2 sec. then turn on the machine again.
Now your unit turns to factory default setting.
Sep 22, 2013 | Panasonic SA-HE70 Receiver
Mty tecnics
Maybe the audio amplifier IC are fried
Jul 03, 2009 | Technics SC-DV290 System
Technics sa dv280, input selection
You can try starting the music on your computer before trying to change the input on the receiver, maybe it needs to recognize some input before it will change if this doesn't help double check your connections & settings ?
Jun 25, 2009 | Audio Players & Recorders
Technics sa dv280 hard reset
DESOLDER THE REGULATOR AND CHECK IT OUT AGAIN IF IT'S OK THEN REPLACE THAT BIG GREY AMP PART STICK TO THE RADIAROR ON THE BACK
Nov 16, 2008 | Technics SC-EH780 CD Shelf System
Cuts out
Check your speakers. your speaker may be defective
Dec 17, 2007 | Technics SUV500 2-Channel Amplifier
 Grubhead
Grubhead
