I have sound card but i have still problems with my speaker
  • 55 Answers
Try re-seating your soundcard..... they can become dislodged... do this with the system POWERED OFF. Failing that plse explain exactly what is wrong with your speaker
Posted on Nov 25, 2014
No sound
Here are some things to check:
  • If you have external speakers, make sure that they're plugged into a working power source and that they're turned on.
  • Make sure your speakers are correctly connected to the computer.
    On your speakers, make sure that the cable that plugs into your computer is plugged into both the speakers and the correct jack on your computer (the jack that goes to your sound card). Most sound cards have at least three jacks. Plug the speaker cable into the line-out jack. This jack often has a symbol showing an arrow pointing away from the jack. If the jacks aren't labeled, check the information that came with your computer to see what each jack does.
    ?id=8440e487-7ae3-427b-a9b7-c861a5521758Most sound cards have at least one line-out jack to connect speakers and a line-in jack to connect an audio input device.
  • Make sure the speaker volume isn't turned down too low or muted. This is particularly important for laptops, which often have small speakers that can be hard to hear.
    1. Click to open Volume.
    2. Move the slider up to increase the volume.
      Make sure the Mute button is not turned on. If the button looks like this: ?id=6b62e2ae-431c-4fb5-8905-aaaea5b445a4, muting is turned off. If the button looks like this:?id=0f47efa2-ffcc-466d-a723-bd0ce4640578 , click it to turn off muting.
      Note
      • Some laptops have an external volume control on the outside of the case. If you're using a laptop, check the external volume control to make sure it's not turned all the way down.
  • Make sure your headphones aren't plugged into the line-out (headphone) jack of your sound card or computer (unless you want to listen with headphones rather than speakers). When you plug in headphones, most computers automatically cut the sound to the speakers.
  • If your computer is supposed to have a sound card, make sure that the sound card is installed and that it's working properly.
    You must be logged on as an administrator to perform these steps.
    To make sure that your computer has a sound card
    1. Click to open Device Manager.‌ ?id=18abb370-ac1e-4b6b-b663-e028a75bf05b If you are prompted for an administrator password or confirmation, type the password or provide confirmation.
    2. Double-click Sound, video and game controllers to expand that category. If a sound card is listed, you have one installed. If no sound card is listed, check the information that came with your computer to see if there's supposed to be a sound card installed. If there should be a sound card installed, you'll need to install one. See Install or remove a sound card.
      Note
      • If you think you have a sound card installed but you don't see it under Sound, video and game controllers, double-click Other devices to check for any audio devices listed there.
    To make sure that your sound card is working properly
      If there's a yellow question mark next to the name of the sound card, there might be a problem.
    2. Double-click Sound, video and game controllers to expand that category, right-click the name of the sound card, and then click Properties.
    3. Click the General tab, and then check the Device status box to identify problems with the sound card.
      If there's a problem, you might need a new driver for your sound card. For more information, see Update a driver for hardware that isn't working properly.
If these actions don't solve the problem, there might be a problem with the hardware for your sound card, although in most cases sound problems are caused by missing or out-of-date drivers, or a problem with your speakers. If you suspect you have a hardware problem, contact the manufacturer of your computer or sound card.
Feb 17, 2011 | HP Compaq dc7100 Small Form Factor PC...
Trying to connect BA735 speakers to a MacBook? No sound? Are they compatible?
Those speakers were originally supplied with Gateway computer system that had sound cards with digital outputs. While some versions had analog and digital sound inputs, most often the speakers had digital input only. The on-board sound in the eMachines is analog output only, so the speakers are most likely not compatible with your computer. If you want to use those speakers, you will need to locate a PCI sound card with digital output.
It's a matter of the output from the computer's sound card (built-in) being incompatible with the speaker input. The card is sending out analog sound wile the speakers are expecting digital input. Downloading a driver won't help because that doesn't fix the root problem. You need to get speakers designed for analog input, or a sound card with digital output. As it stands now, your computer just can't use those speakers.
Since your using a MacBook there is no option for this Pci Digital Sound Card.
Feb 03, 2011 | Boston Acoustics BA735 Computer Speakers
Music is playing - everything is turned on - fixit says there is no problem - sound card is active - speakers worked yesterday - now nothing, no sound is coming out of speakers
you might have hit by accident a windows mute key or a mute on your speakers themselves or maybe the wire that plugs into your speakers or computer got disconnected accidentaly.
try going in your Control Panel and check what u have in the Sound tab, it might give you some clues if the problem is inside the box.
you can also go into Control panel and Device manager and see also the sound Tab in there see if also your card shows up there...
if u have also an onboard sound card and also a pci sound card those can get into conflict if both are active at the same time.
good luck!
Oct 22, 2010 | HP (ED808AA) 2 Speakers
My hp 530 has a sound problem.its does not bring out sound
The sound card driver may not have been installed, the OS does not support your sound card or the speaker is bad . connect a headset to the speaker jack if there is sound then it is not a sound card driver problem, else replace the speaker or reinstall the sound card driver
Sep 27, 2010 | Computers & Internet
I don't have a sound card.but how can i connect logitech Z-5500 speakers to my pc
Since Logitec Z-5500 is a 5.1 Speaker System you need to purchase a Sound Card to be able to connect it with your pc. You can get a Sound card starting with a price tag of 20 Pounds.
Hope this will help you solve your problem Best Regards NextDoorNerd
Jul 28, 2010 | Logitech Z-5500 Computer Speakers
Igot REALY old speakers that used to worke perfectly well
The speakers themselves are probably not your problem. Some speakers use the USB connection while others use the Audio output jack of your sound card. The problem is likely with your sound card (assuming you use the Audio output jack). If you rebuilt your computer, chances are you're missing the device driver for your sound card (these are small programs that let your hardware talk to your operating system). You'll need to download the correct device driver for your exact sound card. You probably don't know the sound card make/model. You can download Belarc Advisor (www.belarc.com) which will scan your PC for all hardware and software. Once you have that report, you should be able to go to the sound card manfucturer's website and download the latest device driver. You can always find out if it's the speakers by connecting them to another computer. Good luck.
Aug 13, 2009 | Polk Audio AMR50 Computer Speakers
BA735 no sound but sound card works in analog mode.
this should be pretty easy to diagnose. both speakers have mini jacks right? if so, and you plug one pair of speakers in on say, port "A" and you get sound then if you plug your other speakers in on port "A" and you don't get any sound, the problem is with your speakers.
Oct 19, 2008 | Boston Acoustics BA735 Computer Speakers
Rear Speakers do not sound, other 2 do, and boofer.
There are several reasons why there is no sound coming from the rear speakers.
  • Improper connection of the signal cable is a possible reason why there is no sound coming from the rear speakers.
7949.jpgGreen connector is for the front left and right channel. Black connector is for the rear left and right channel. Orange connector is for the LFE (Low Frequency Effects) subwoofer and the center channel.
The connectors for the Logitech products are color coded as explained. The connectors on the sound card may not be color coded or a different color coding maybe used depending on the manufacturer of the sound card. Check the manual for the sound card to make sure the correct connector is connected from the Logitech speaker to the sound card.
  • After verifying that the connections are made correctly, the sound card needs to be checked to make sure it is setup correctly. There are many sound card manufacturers so we cannot possibly cover every make and model. We recommend contacting the manufacturer of the sound card to make sure the sound card is setup correctly for use with analog 5.1 speaker systems.
  • When a software DVD player is being used to watch a DVD, the audio output needs to be set to surround sound mode. Please refer to the user manual for the software DVD player to check the settings.
Many DVDs have more than 1 sound format available. Just as the sound card and the software DVD player, the DVD itself has to be set to the correct sound format.
  • Finally you can test to see if the speakers are working correctly by plugging the front channel cable coming from the sound card to the rear channel connector on the subwoofer. If sound comes out of the rear speakers, then there is no problem with the speakers. The problem could be with the software DVD player, or the audio setting on the DVD.
THIS article can be used to test if your speakers are indeed working.
Hope that helps!
If your issue is not resolved, please do not assign a rating just yet. Please post back as to what steps you took, results, etc, and I will try to assist you further as best I can. I am here at your service.
P.S. -You can rate this solution with one of four votes (remember that at times a bit of to and fro dialogue may be necessary to resolve an issue).
  • "FixYa!" - The solution provides great advice on how to solve the problem.
  • "Helpful" - The solution provides useful leads that helps solve the problem.
  • "Thanks for Trying" - The solution does not solve the problem but the effort is appreciated.
  • "Inappropriate" - The solution has absolutely nothing to do with the problem.
Thank you for using FIXYA!
IrishDruid
May 04, 2008 | Logitech X-530 Computer Speakers
Cambridge soundworks speakers
Happy Holidays Fredonna
Well, easy task, just put a music CD, on system and if you got an headphones, put in the green connector on your sound card, pop up the PC volume, and see if you heard sound, if you do, heard sound then the problem is your speakers. if don't is your sound card.
good luck
Dec 24, 2007 | Gateway Edison Computer Speakers
47 people viewed this question
 Grubhead
Grubhead
