Question about Radio Communications
My hdmx jam classic wireless speaker, has a solid blue light with a blinking red light on the bluetooth indicator, and won't let me connect via aux or bluetooth, how do I fix this?
SOURCE: can't get charged
same problem
Posted on Jul 31, 2008
SOURCE: Bluetooth stopped connecting - solid light
I followed one of the solutions that I found on your website! I deleted and added the connection on my phone again and used 0000 as the pin number.
Worked great!
Posted on Apr 09, 2009
  • 5 Answers
SOURCE: Motorola bluetooth H270 solid blue light after pairing
I had the same problem. I plugged a USB charger into the headset and turned the power switch off. It worked as normal after that. I think it does not like to be "on" when the USB is disconnected. Anyway it seems the plugging/unplugging kick-started it.
Posted on Feb 12, 2010
chiplevel
  • 656 Answers
SOURCE: Plugged in all night and still has a solid red LED
can you see your headset in Bluetooth device if not add your head set in the Bluetooth devices by right clicking the icon in the task bar going to option click allow Bluetooth device to be connected to this computer and alert me when a new Bluetooth wants to connect
Posted on Nov 05, 2010
HDI Headsets
  • 537 Answers
SOURCE: When I try to charge
If this is not charging correctly it may be that the battery is no longer functioning properly. The batteries are non replaceable on this headset. If this is still under warranty (1year) you should be able to get a replacement
Here is a link to the User's Guide.
Good luck from Headsets Direct!
Posted on Oct 10, 2011
I can't get my jams hdmx speaker to pair with my iPad Pro. The speaker will not even list under "my devices."
If you can, erase the memory on the speaker and mark each Bluetooth listing on the iPad to Forget This Device. Do not be around any other Bluetooth devices. Turn your speaker and iPad off and back on. Let them discover like 1st time. Try again. Patience. Sometimes takes 20 to 30 min. RJ
Apr 25, 2016 | HDMX Audio HMDX Jam Plus blue
I have a portable wireless speaker model AWSBT7 will not go into the connect mode when pressing the button to sync up device I do not get the two beeps or the light does not flash faster
Hi Jerry, Are you using this method to pair your device?
Pairing
The Bluetooth-enabled device that you wish to stream audio to your speaker system must
fi rst be paired to the speaker. The process is simple, and in most cases the pairing process
needs to be done only once.
To pair your Bluetooth-enabled device with the speaker:
1. Make sure your device's Bluetooth is turned on. See the wireless and/or network settings
menu on your device to check.
2. If the speaker isn't already on, press the On-Off button to turn it on. You will hear a beep
to indicate the speaker is turned on. The indicator light on the back of the speaker starts
fl ashing blue.
3. Press and hold for 3 seconds the Pair button to enter pairing mode. You will hear 2 beeps
to indicate pairing mode is entered. The indicator on the back of the speaker starts blinking
faster.
4. Open the Bluetooth settings menu on your device. Select "AR SPEAKER" from the list of
devices available (you might have to scan for devices). If your device asks for a password,
enter "0000".
5. A confirmation screen will appear on your device once the speaker and the device are
successfully paired. The blue indicator turns solid blue to indicate successful connection.
The speaker is now ready for you to stream audio from your device.
Oct 24, 2014 | Audio Players & Recorders
Bluetooth won't come on hdmx jam party and sync with ipod touch 5th gen
Follow the instructions from the set up guide that came with your Bluetooth wireless speaker on how to pair and connect .the speaker with a Bluetooth-enabled media device such as iPod, iPad or iPhone.
Apr 21, 2014 | Apple iPod Audio Players & Recorders
HMDX Jam wireless speaker cannot be paired with my computer
Go to your Bluetooth settings, go to the "Audio/Video" tab, under the "Content Protection" section uncheck the "Connect to content protection enabled headset only" and your bluetooth speaker(s) should now work.
Feb 02, 2013 | Audio Players & Recorders
I can't get my Polaroid Bluetooth wireless speaker to work!
hold the button down and it will change to blue, then you need to make sure your phone is connected to the speakers bluetooth. then when you play music off you phone it will come out the speaker. the red light is for aux mode - where you plug your phone or ipod in.
Jan 27, 2013 | Polaroid Radio Communications
Ineed to know what blue light tells me that my router is working?
Hi jackmyrtue,
Here's what the lights on the front indicate:
A. Wireless Security
  • OFF Wireless security is off
  • Solid Blue Wireless security is on
B. Wireless-Computer Status
  • OFF Wireless computer is not present
  • Solid Blue Wireless computer is connected to the Router
  • Blinking Amber Problem with wireless computer onnecting properly to the Router
C. Wired-Computer Status
  • OFF Wired computer is not present
  • Solid Blue Wired computer is connected to the Router
  • Blinking Amber Problem with wired computer connecting properly to the Router
D. Router/Power Status
  • When you apply power to the Router or restart it, a short period of time elapses while the Router boots up. During this time, the "router" icon blinks.
  • When the Router has completely booted up, the "router" icon becomes a solid light, indicating the Router is ready for use.
  • OFF Router is off
  • Blinking Blue Router is booting up
  • Solid Blue Router is on and ready
E. Modem Status
  • This icon lights in blue to indicate that your modem is connected properly to the Router.
  • It turns amber when problem is detected.
  • OFF Router is NOT connected to modem
  • Solid Blue Router is connected to modem and functioning properly
  • Blinking Amber Problem with modem
F. Internet Status
This unique icon shows you when the Router is connected to the
  • Internet. When the light is off, the Router is NOT connected to the Internet.
  • When the light is blinking amber, the Router is attempting to connect to the Internet.
  • When the light is solid blue, the Router is connected to the Internet.
When using the "Disconnect after x minutes" feature, this icon becomes extremely useful in monitoring
the status of your Router’s connection.
  • OFF Router is NOT connected to the Internet
  • Blinking Amber Router is attempting to connect to the Internet
  • Solid Blue Router is connected to the Internet
I hope this helps figure out your PS3 issue.
Thanks and don't forget to leave a rating.
Mark
Feb 01, 2009 | Belkin N Wireless Modem-Router F5D8633au4A
Bluetooth keyboard and mouse not working with computer
Normal 0 Press the Receiver button (and the lights will start flashing.
Then if the Keyboard isn't working, press the small RESET/CONNECT button on the back of the board to connect the keyboard to the receiver.
If the MOUSE isn’t working, push the small RESET/CONNECT button on the back of the mouse to connect to the receiver. Then they should work okay.
Hope this helps. Bud
Jan 09, 2009 | Dell Inspiron 531 Athlon 64 X2 4400+...
Radio Communications Logo
41 people viewed this question
Top Radio Communications Experts
eradiostore
eradiostore
Are you a Radio Communication Expert? Answer questions, earn points and help others
