I have replaced all sequecers and blower relay, my furnace heats up but the blower wont come on. i am pretty sure its a wiring problem i need a clear dagram of how to do this. it will blow when you tu
I have replaced all sequecers and blower relay, my furnace heats up but the blower wont come on. i am pretty sure its a wiring problem i need a clear dagram of how to do this. it will blow when you turn it to "on" but nothing on "auto"
    Master:
  • 571 Answers
The fan relay should isolate the 2 speeds hi & low use for cooling & heating. Normally closed should be the low speed, and normally open (closed when the relay is energized) should turn on the fan in high speed. Make sure the fan (isolation) relay is wired correctly.
Posted on Nov 23, 2014
  • 49 Answers
SOURCE: Intertherm E1EH-015HA FURNACE no heat
Sounds like a downflow electric furnace? If so it sounds like you have 15kw worth of electric heat, you might have a defective heating sequencer, witch is what they call a dual on one plate.
Posted on Nov 28, 2007
the dr
  • 447 Answers
SOURCE: Furnace Blower Motor Specs
That information is usually on the data plate on the furnace and on the motor itself. All you need to know now is the HP. Other than that a universal consolidator motor is an easy fix too. It can handle 1/6-1/3HP.
Posted on Dec 18, 2007
  • 61 Answers
SOURCE: problem with furnace, air but no heat
the hot serface igniter may nead to be replaced again . if the is a lack of air
[ have this checked} getting to and frome the furnace it may be causing the furnace to cycle off the burner duing call for heat. it recycles back on and off untill the thermostat is saticfied. this means you are reusing the igniter more often the once a call for heat . therefore shorening it life expectancy.. make shure you are not blocking the air flows with over filtering ..whitch i have found to be the most common mistake . this and not changing or cleaning air filters often enough.
Posted on Oct 20, 2008
Accurate Joe
  • 61 Answers
SOURCE: Electric furnace blows cold air before and after warm air.
It is normal. Your house has to go down a couple more degrees because the heat pump is not working. You can solve this by rewirng you thermostat. Take off the wire that goes to Y and tape off. Then take the wires that are marked w and e or w1 and put the wires to yellow. Do not run ac with it wired like this. If you need more information please post me back
Posted on Nov 29, 2008
SOURCE: 24v wiring for RHEEM heat pump
Brown wire connect to com C on terminal block in your furnance (0VAC from 24VAC transformer)
Yellow turn on compresor (hot wire from 24VAC Transfrormer)
Blue switch Valve from AC to Heat (hot wire from 24VAC Transfrormer)
Purple prevent starting compressor in Heat pump and furnace in same time
Posted on Aug 28, 2009
Why does blower only operate manually?
Not wired correctly, if we are talking about a out side hot water furnace. The blower needs to be connected to a relay and transformer that connects to the inside thermostat.
Sep 04, 2015 | Heating & Cooling
Put in a second t-stat to run just my blower on my
To avoid all sorts of wiring problems use only one two stage heat thermostat and wire outdoor boiler to first stage of heat or disconnect white wire from original thermostat and run 2 wire thermostat cable (white and blue , Heat and common to control outside water furnace control ) from original furnace to outdoor 24 v furnace relay .
Oct 01, 2014 | Heating & Cooling
RHEEM OIL FURNACE MODEL ROBD 067 LBEA BLOWER
You will likely need to install an isolation relay in the W circuit from the thermostat. Some thermostats rob a small current through the W circuit to power the thermostat. This small current can be enough to start the fan circuit timer. You can test this by disconnecting W at the furnace and allowing the timer to shut down. If the fan shuts off with the W disconnected you can install a simple relay.
The relay coil will be connected to Common on one side and the W from the thermostat to the other. Then you will run a wire from R on the furnace to the relay and from the N.O. Contacts to the W terminal on the furnace. This will kill that signal that is starting the timer and the W can steal it's power through the coil back to common.
Dec 23, 2009 | Honeywell Electronic Programmable...
Rheem RHQA Heater:Blower works but no heat.
Is there a setting on the thermostat for Auto or Fan? If so, make sure it is in the Auto setting. You will have a contactor that turns on the elements and a relay for the fan. Follow the wiring diagram to see which relay energizes the fan then unplug it to see if the fan stops.
Nov 02, 2009 | Heating & Cooling
Fan will come on for heat(auto), but not for AC or set to ON
You have a blower relay in the furnace that's probably bad. In the heat mode the blower is on a temperature relay, in cooling mode the blower has to come on immediately so there is another relay for cooling. The green wire on the thermostat feeds that relay, so if you go to the furnace and shut the power off and find the green wire from the thermostat that feeds that relay and replace it, being careful to mark all the wires before removing them, also the relay terminals have numbers for identification.
Apr 07, 2009 | Heating & Cooling
1970's Rheem electric furnace
no the older rheems had a sequencer for the heat that turned on the blower at the same time that the heat strios are energized. so the first thing that you need to do is figure out the sequencer that is keeping the fan running and get it replaced.
Jan 30, 2009 | Honeywell CT3200 5-2 Day Electronic...
Blower motor
follow the wires back from the motor to either the relay or the circuit board. normally a furnace has a board. check to see if there is any power leaving relay/board to the mtr. if it is a furnace you may need to push in the door saftey switch to get power to system. heat pump mtrs need 230 vlts furnaces 115vlts. If the power is going through to mtr properly than problem is either capacitor or mtr. capacitor can be checked for you by a local hvac supplier or buy a meter that can check it.
PLEASE rate or solution thanks. Brian S.
Nov 28, 2008 | Weather King Heating & Cooling
WIRING
why did the wiring burn?Id have the heat exchanger inspected before rewiring.better to be safe.
Sep 17, 2008 | Intertherm P3RA-048K Air Conditioner
Heating & Cooling Logo
44 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
