Question about Plumbing
Electrical motors - Plumbing
  • Josh
    Josh Dec 24, 2014
    Hi MONEIWA MOKWA, I want to help you with your question, but I need more information from you. Can you please add details in the comment box?
Could sure use a wiring diagram for a Dayton 5k961c motor.
Electric Motors: dayton motor, Electric motor repair Kansas ...
en.allexperts.com > Industry > Machine Tools > Electric Motors
Aug 24, 2010 - Electric motor repair Kansas City MEAR Service 816-650-4030: Tyler, it is ... i have a dayton motor with no wiring diagram. i need a wiring diagram for a dayton motor with a model # 5k961c and a reference # r67745ck733 ... 1992 Dodge Dynasty Blower Motor Wiring Diagram · 1998 Ford Escort Blower ...
wiring diagram (ideally color) for Dayton belt drive motor Model ...
www.electro-tech-online.com > ... > General Electronics Chat
Apr 29, 2012 - 9 posts - ‎3 authors
There is a sticker on motor indicating wiring, but seems only an. ... This is a motor for vented - big blade ceiling fan -- a belt driven Dayton Motor ...
DAYTON 1/4 HP Condenser Fan Motor,Permanent Split ...
https://www.grainger.com/.../DAYTON-1-4-HP-Condens...
W. W. Grainger
Rating: 3.8 - ‎6 reviews
Shop DAYTON 1/4 HP Condenser Fan Motor,Permanent Split Capacitor,1075 Nameplate RPM,208-230 ... Typical HVAC Condenser Fan Motor Wiring Diagram ...
DAYTON 1/3 HP Direct Drive Blower Motor, Permanent Split ...
https://www.grainger.com/.../DAYTON-1-3-HP-Direct-D...
W. W. Grainger
Jan 23, 2016 | Dayton Dryers
Tip
How to Reverse the Rotation of Single Phase Capacitor-Start Electric Motors
Reversing the rotation of electric motors can be done easily with 3-phase motors. This can be easily achieved by swapping the connection of any two motor leads. But 3-phase motors are usually found and used for industrial purposes. The ones found and used in our homes, from water pumps to electric fans, are single phase capacitor-start type motors. Unlike 3-phase motors, reversing the rotation of single phase electric motors is no easy task. Swapping any two motor leads will not result in the reversal of the motor rotation. Analysis of the motor windings and connections are necessary before any modification can be done to achieve the desired result. Let's take a 3-speed single phase capacitor-start electric motor with electrical diagram shown below as an example. Make sure the motor is disconnected from the power supply before attempting to follow this tip. This tip is intended only for individuals with electrical knowledge, necessary tools, and understand the risks associated with handling electrical equipments and devices.
The first step in the process is determining the start winding which is connected to the line (AC white) and to one side of the start capacitor. To accurately determine the start winding, disconnect all motor leads from the start capacitor and the speed switch for multi-speed motors and then setting your ohmmeter to the lowest scale (R x 1), measure the resistances between the AC white line and each of the motor leads connecting to the start capacitor. The one with the least resistance is the starting winding lead.
Once the start winding lead going to the capacitor is determined, reconnect the capacitor then connect the black AC line to the found start winding lead (marked X). Connect the white AC line to L of speed switch, the motor lead formerly connected to AC white to 3, red to 2, and white to 1 as shown below. Leave the green/yellow ground wire connection as is.
Below are the wiring modifications for 2-speed and single speed single phase capacitor-start electric motors.
on Jan 11, 2011 | Dryers
Need fan motor for model 2E440
Try Grainger
dayton 2e440 heater Questions & Answers - Fixya
www.fixya.com > Forum > Tags
... a Dayton Model 2YU40 electric heater Need manual for Dayton. ... looking for a replacement fan and fan motor for a Dayton model 2E454B electric wall heater.
Dayton rheostat fan motor Heaters Questions & Answers ...
www.fixya.com > Forum > Tags > rheostat fan motor > Heaters
Dayton heaters rheostat fan motor related questions and answers. ... UP BUT FAN WONT KICK ON Could be one of several problems dependant on the model you have.... The motors are noisy in 2 Dayton 2e440 heaters. I ... I'm looking for a replacement fan and fan motor for a Dayton model 2E454B electric wall heater.
DAYTON Electric Wall Heater, Recessed or Surface ...
www.grainger.com/.../DAYTON-Electric-Wall-Heater-3...
W. W. GraingerShop DAYTON Electric Wall Heater, Recessed or Surface, Voltage 208/240, Watts ...Item # 3UG56; Mfr. Model # 3UG56; UNSPSC # 40101814; Catalog Page # 4277; Shipping Weight 20.65 lbs. ... Additional features include a built-in thermal cutout andfan delay switch for added safety ... Need Help Finding Repair Parts?
Jan 09, 2016 | Dayton Electric Heater
Type electric motor research TY 50B E212993
This looks like your motor. With these smaller specialized motors sometimes you can't just make an easy change like they do with larger industrial motors.
MOTOR 23 2013 ZHS23 TY50B E212993
Nov 24, 2013 | Office Equipment & Supplies
Electric motor make, lamco, model no.EC34-1(93) reversing 120v 16.5amps
Here are electric motor links that might help.
Or not.
http://waterheatertimer.org/Color-codewire.html#motor
You have to test the windings with multimeter to identify start winding, vrs run winding.
Both windings receive power at same time.
The start winding is like first gear on a car. It starts the motor rotation.
The run winding brings motor up to rated speed.
Sometimes categories at Fixya are muddied, and people do not say which product they have, or give UL number instead of product number, and sometimes fixya questions are truncated onscreen ... so person answering question thinks the product is a gasoline powered bobcat, instead of hybrid car, or 120Volt single-phase electric motor.
Nov 25, 2012 | Hardware & Accessories
My 1996 Jeep Grand Cherokee Laredo just stopped starting. All lights, fan, sensors work but engine does nothing when I turn it to start position. What is wrong? Please help.
Assuming that when you turn your key the motor doesn't even try to start.
To start the combustion motor, an electrical motor is used to give it inertia, there are 2 possibilities: one, this electrical motor is not getting the electrical power required, or two, the electrical starter motor is broken. For the first option, check cables all the way from your battery, trough the switch you open or close with your keys, trough a capacitor, to the motor. This motor is generally below or next to the combustion motor, their shafts are mechanically connected by gears. Only the positive pole goes all this way, the negative terminal of the electrical motor is connected to your car's chassis, and so does the battery's negative terminal. If all these connections are OK, then your electrical motor is gone, in which case you'd better buy a new one and replace it, because fixing it would not be an easy task. You can try also replacing the capacitor, which must be on the way between the electrical motor and the key switch, if this is broken, your car should be very weakly trying to start as if the battery was low.
May 15, 2010 | 1996 Jeep Grand Cherokee
How to replace the blower motor fan assembly in a 2000 GMC Yukon XL K1500 4X4
Blower Motor Removal & Installation Delphi
Blower Motor Replacement (Delphi)
To Remove:
  1. Remove the instrument panel sound insulator panel (if equipped).
  2. Disconnect the electrical connector from the blower motor.
  3. Remove the blower motor insulating cover screws.
  4. Remove the blower motor insulating cover.
  5. Pull the retaining tab down and rotate blower motor counterclockwise to remove.
To Install:
  1. Position the blower motor and turn assembly clockwise until tab locks in place.
  2. Install the blower motor insulating cover.
  3. Connect the electrical connector to the blower motor.
  4. Install the instrument panel sound insulator panel (if equipped).
Visteon
Blower Motor Replacement (Visteon)
To Remove:
  3. Remove the blower motor screws.
  4. Remove the blower motor from the HVAC module.
To Install:
  1. Position the blower motor and install mounting screws.
  2. Connect the electrical connector to the blower motor.
  3. Install the instrument panel sound insulator panel (if equipped).
Oct 02, 2009 | 2000 GMC Yukon XL
My electric lawn mower starts briefly and then trips the circuit
check cord from plug to the electric motor.if it has a reset or breaker check for damage. if no obvious damage problem is electric motor.may be cheaper to buy new 1
May 06, 2009 | Electric Lawn Mower
Plumbing Logo
51 people viewed this question
Top Plumbing Experts
Donni Steen
Tom Chichester
Are you a Plumbing Expert? Answer questions, earn points and help others
